04-26-2022, 12:17 PM | #177 | |
Rep 6
04-29-2022, 08:11 AM | #178 |
38
Rep 45
Some colder weather updates, temps back to high 20s/low 30s...range down to 39/40 miles under this weather. Highest charge shown was 49 with 60s
05-06-2022, 09:50 AM | #180 |
Rep 54
Flashed my vehicle this morning and went from 10mi remaining to 23mi remaining after the flash. 23mi appeared to be at almost exactly 50% on the visual meter. It's about 50 degrees here this morning.
Plugged it in and says 4 hrs 5 min to go from 49% to 100%. Last edited by ThomasShelby; 05-06-2022 at 09:57 AM.. |
05-06-2022, 10:01 AM | #181 |
9
Rep 45
Interesting in doing this, would love the extra 20 miles. Can you easily flash back to stock yourself, if you need to take care in for service, or trade it in, etc.?
05-06-2022, 11:52 AM | #182 |
Rep 54
My understanding is yes, though I doubt I'll do it until I sell it. Putting the flash on there took less than 15 seconds and I assume reloading the backup would be similar. As an update, I'm at 84% charged and 43mi of range.
05-06-2022, 04:49 PM | #183 |
Rep 1,340
If the EU spec supports a higher usable battery capacity that means the battery was originally designed for that. I cant see how unlocking the EU spec capacity can hurt the battery.
nZtiZia4749.50 comebackidlci32.50 |
05-06-2022, 05:57 PM | #184 |
Rep 8,857
Drives: eVeRyOnE mAD!
one guy initially unlocked the full 24kWh but got errors. he backed down to 23kWh
05-06-2022, 06:09 PM | #186 |
Rep 8,857
05-06-2022, 07:09 PM | #189 |
Rep 6,930
The EU has a shorter battery warranty than the US does...it would be a major selling point to make it longer, so there is likely a good reason why they shortened it.
silverstar335503.00 doyall48.00 |
05-06-2022, 07:13 PM | #190 | |
Rep 6,930
So, depends on what you want. NOte, if you aren't using all of the battery capacity on a daily basis, you might be able to fully recharge, but if it's at zero indicated, no, it could take upwards of 19-hours or so with the supplied device in the USA. |
curiousbmw16.00 |
05-06-2022, 07:14 PM | #191 |
Rep 1,340
05-07-2022, 08:01 AM | #192 |
Rep 8,857
he initially chose max capacity but kept getting errors, so they decreased it to 23kWh. whether or not that's true is unknown, but that's what he told me. on an ideal day he gets 60+ miles of electric range on a full charge.
silverstar335503.00 |
05-07-2022, 09:16 AM | #193 | |
Generalissimo
665
Rep 1,437
With the EU spec flash, you get about 40-50 miles when it’s in 60s-70s T outside in stop and go local driving. You only get 60-70 miles when it’s like 70-80 F outside and you drive 50-55 mph on the highway. |
05-07-2022, 09:57 AM | #194 |
Rep 274
That feel to be the person who buys it used from him when he's done with the car
05-07-2022, 10:36 AM | #195 |
Rep 1,340
I am going to wait to see the new specs of the 2023 X5 50e before deciding what to do. If the $7500 federal tax rebate is still applicable I may upgrade.
Not sure how true the rumors are but apparently it will have 480hp (confirmed) with a 70-80 mile electric range (speculation), that's pretty significant of a difference if accurate. |
05-07-2022, 04:04 PM | #197 |
Rep 1,340
05-07-2022, 05:02 PM | #198 |
Rep 6,930
Energy density has been increasing, so it's possible new cells could have more range in a new version. That would almost dictate a bigger onboard charger. Previously, prices stayed about the same for the cells, but with the way things are going, that is not a given, so the cost/benefit ratio may not be good.
