Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Fault Codes 3100 & 30FF
      05-09-2009, 08:46 PM   #23
dmurray14
The Stig
dmurray14's Avatar
Drives: Quickly
Just got this today, am getting it constantly (with limps) as soon as I give moderate throttle in any gear. No tune. I can tell I'm building no boost whatsoever, it feels like a 325!
Any clues guys?
      05-09-2009, 09:06 PM   #24
TXSurfer
TXSurfer's Avatar
Drives: 335i E92
Wow i just placed an order for FDV should i cancel?
      05-10-2009, 12:13 AM   #25
kptaylor
kptaylor's Avatar
Drives: '07 335i Coupe
No, it's not the valves it's other things. If you think about it, the OEM valves can't hold the increased boost, so they leak and don't allow it to build as much. Throwing on the Forge valves makes it more efficient, so any boost leaks the OP has due to the other installed items will become apparent. Like everyone else has said, check the other hoses or do a real leak test to find the underlying issue.
      05-10-2009, 02:56 AM   #26
Panoz
Panoz's Avatar
84
Drives: E92 Space Grey 335i ,Aero Kit
u cant really say its valves or not
Procede V4 , Catless DPs, Forge FMIC, Injen Intake, VK Oilcooler, Hartge Quads Exhaust, Modded CDV, Synapse BOV Kit, BMW Performance 335i SSK Kit, P3 vent boost gauge
Space Grey 335i -> See more pics HERE
      05-10-2009, 02:39 PM   #27
kptaylor
kptaylor's Avatar
Plenty of Forge valves out there on many, many cars. (Not just BMW's.) What I was saying was you can't assume it is definitely the valves. (And it probably isn't.)
      05-11-2009, 09:44 AM   #28
pat@forge
Drives: Miata
And if it is the valves we warranty them for life. It isn't a problem with the design, it has been proven on thousands of cars, it would have to be either a manufacturing defect or a failure of some sort for the issue to be caused by the valve, wither of which we will take care of.
      05-09-2010, 06:32 PM   #29
stef335i
Drives: 2008 335i
same ploblem here
Any clues guys?
my car is stock and i have same issue plus no power at all! i should put a 325 badge on. anyone solve this?
      05-09-2010, 07:52 PM   #30
badass335
badass335's Avatar
109
Drives: 2017 540i Xdrive
Just a thought but have you guys with the forge DV's making sure it's greased up? My Forge DV's were sticking so i greased it up with some high pressure red grease and all is great again. No more issues.
      06-03-2010, 02:40 PM   #31
Kolyan2k
Drives: 2006 S2000
Just got both Codes 3100 & 30FF. I am 100% stock with JB+ running at 50% and 93 octane. Got this on highway and after turning the car off everything is OK.
      06-03-2010, 03:45 PM   #32
Kolyan2k
Drives: 2006 S2000
Originally Posted by coldasicex5 View Post
i had same code recently and the replaced the "exhaust solenoid"
do you have a tune ?
      06-03-2010, 04:07 PM   #33
Easternedge
Easternedge's Avatar
Drives: 2012 Mini Coupe S JCW
2011 BMW 335is  [0.00]
30ff was wastegate issues with mine.
"Performed turbo wastegate test plans. neither wastegate closed at 200mb. adjusted wastegates- road test ok."
Was happening everytime I floored the car.. went away with turning off and starting up.
Back again after 10 yrs!
Daily: 2012 Mini coupe S JCW
Baby: 2007 BMW M6 Vert
Wifey's: 2006 BMW 650I
Family: 2007 Chevy Suburban LTZ
      06-03-2010, 04:16 PM   #34
335si
335si's Avatar
Drives: 335i
Originally Posted by Sniz View Post
do a boost leak test, you'll know what clamp is leaking if any, also will test your DV's.
How do you perform one of these tests?
2007 BMW 335i Cpe AW 6MT - All Stock
1972 Yamaha R5 (350 2-stroke)
      06-05-2011, 03:49 PM   #35
kiteboy
kiteboy's Avatar
France
12
Drives: E92 Stage 2 BR Performance
Question
i have same fault code...and i don't know wat it could be due ? sometines when driving normaly i've got engine warning light.
i've got also wastegate rattle only on deceleration , on front turbo, but no problem performance on my car ?
I think when it's a solenoid case fault code is 2A82 etcc and not 3100 ou 30FF ?
I verified pipe etc but it seems no leak...
if it cam be a dump valve ??
      06-17-2011, 04:10 PM   #36
kiteboy
kiteboy's Avatar
France
12
i verified if leak intercooler, charge pipe.. no leak,
So i clean it, and also i replace my DV, because my car has 109 000km....
when i compared old DV and new, the old seems be easier to open when depression....
no new fault code... since one week....so wait & see...
      04-19-2016, 09:10 AM   #37
n54brasil
n54brasil's Avatar
Drives: bmw 335i 2008
Hello everyone,
Someone managed to solve the codes 3100 and 30FF ?
I have a 335 2008 100 % stock and I'm the same mistakes.
Appears every 10 days the half-light injection , when I turn off the car and turn back to normal.
I spent the INPA and accused these codes I said.
Thank you.
      04-15-2024, 11:29 PM   #38
danik335
Drives: 2008 335i E92
I got this issue with my 335i, finally put on my downpipes and everything was running smooth until I did a pull when someone cut me off to get around them. I heard some pop out of my exhaust and ever since it’s been running weird. On idle it’s not making this sound, only when I accelerate decently fast, I’m hearing some kind of sound that sounds like a fan blowing loud or something but I don’t hear my blow off valve anymore. I’m getting a 3100 code and a 30ff code and I know it’s a boost leak but I just don’t know where it’s coming from or how it happened, hope someone can help.
7.5 in intercooler
Catless downpipes
Mhd stage 2
Charge pipe, blv
Dual come intakes
I looked around for leaks and I couldn’t find any, smoked my system through my bov which idk if that was the right way to do it.
      04-21-2024, 04:55 AM   #39
OMEGA412
OMEGA412's Avatar
12
Drives: BMW 335i Coupe
7.5 in intercooler
Catless downpipes
Mhd stage 2
Charge pipe, blv
Dual come intakes
Boost leak, or blown turbos. 30ff is low boost. And the 3100 is boost control deactivation cause by the 30ff
