02-03-2021, 10:51 AM | #1 |
Rep 903
Winter tires or All Season/Weather
We've decided to get a set of 20" square set of wheels and tires to go up north to colder with high possible snow/ice weather. Probably will plan on a few long road trips to where there might be snow. I would say less than 50% of the time there wont be any snow/ice, but colder weather for sure.
Currently we have 21" stagger summer RF tires. Should we get winter tires and swap back summer tires in warmer temps OR Get All Season/weather. drive till its time to rotate and swap back the summer tires. Last question, recommended options for winter tires and All-Season/Weather tires Size is 275/45R20/XL, no preference on RF or nonRF since we have a spare THanks!! Last edited by dream54ing; 02-03-2021 at 11:47 AM.. |
02-03-2021, 11:03 AM | #2 |
Rep 8,690
Drives: eVeRyOnE mAD!
I've read Michelin Pilots are excellent all-season tires, though not all-weather. they're not run flat (if that's a preference for you). Folks that live up there likely have distinct winter sets. If you have the space to store separate sets, go for it. If not, I'd recommend all-weather (no run flats currently) over all-season.
Ideally and personally, I want run flat all-weather for my use case, vehicle type (no spare tire), and storage space limitations. |
dream54ing485.50 |
02-03-2021, 11:49 AM | #3 | |
Rep 903
Any All-Weather you recommend? We have a spare, so RF or non RF we are okay with. |
02-03-2021, 12:02 PM | #4 |
Rep 8,690
I've read good things about Nokian. I wish they offered run flat with these:
https://www.nokiantires.com/tires/by...s/?s=275-45-20 |
dream54ing485.50 |
02-03-2021, 02:11 PM | #5 |
Rep 1,449
Are you getting an additional set of rims/tires or replacing the 21s you have?
If you are planning on a second set I would go with dedicated winter tires over all-season/weather tires for best snow performance, they will also be fine in just cold weather. If you are replacing your 21s then all-season or all-weather tires are the easiest option which you can run year round, but unsure how readily all-weather are available in the US in spec sizes. You also have the option of just putting all-season tires on your 21s for cold weather. 315 rears aren't the best for snow driving, but you could always add chains if needed. Not sure where you plan to go, but some states by your require chains in certain conditions regardless of your tire choice if I remember correctly.
No. Try not. Do. Or do not. There is no try.
-Yoda |
dream54ing485.50 |
02-03-2021, 02:57 PM | #6 | |
Rep 903
this set is for only when we go up north. We were told that driving in winter tires over 40 degrees is bad for the tires. not sure how true that is??? would hate to have to swap between tires each time we go up north, which is probably going to be every other weekend during the winter (Nov-Jan). |
02-03-2021, 03:14 PM | #7 | |
Rep 1,449
If it was me I would do winters. I live in PA and at times during the winter we have temps above 40 degrees and can get snow into march/april when we do have warmer temps. I would typically run winters from Nov-April. I thinking about trying all-seasons on my 22s for the G05 instead of a dedicated winter set with this new ride.
-Yoda |
dream54ing485.50 bigals40062.00 |
02-03-2021, 05:36 PM | #9 |
Rep 20
For winters I would suggest you also look inot the Nokian Hakkapeliita R3 SUV
dream54ing485.50 |
02-04-2021, 08:53 AM | #10 |
Rep 903
Here are a few on our list so far...
Leaning towards Michelin CrossClimate SUV because it can be used in non winter season if we really need to... All-Season Michelin Pilot A/S All-Weather Nokian WR G4 SUV Michelin CrossClimate SUV Winters Michelin Latitude Alpin LA 2 Bridgestone Blizzak LM001 Nokian Hakkapeliita R3 SUV |
02-04-2021, 09:41 AM | #11 | |
Rep 117
dream54ing485.50 jackman10290.00 |
02-04-2021, 10:22 AM | #12 |
Rep 185
If you have a set of summers then would go with the winter/snow option vs. all-season or all-weather. Another good option for winter is the Michelin Pilot Alpin5 SUV.
02-04-2021, 03:38 PM | #13 |
Rep 903
02-04-2021, 03:43 PM | #14 |
Rep 903
yeah, but we were told winters are bad in weather above 40 degrees. we will be driving below 40 degrees less than 20% of the time, so we might be leaning towards all weather, since they are the next best thing down from winters and decent rest of the time.
02-04-2021, 08:30 PM | #17 | |
Rep 185
Watch this video: Last edited by Fennario; 02-05-2021 at 12:04 AM.. |
dream54ing485.50 |
02-05-2021, 02:19 AM | #18 | |
Rep 117
dream54ing485.50 |
02-05-2021, 12:27 PM | #19 | |
Rep 903
I told them my situation again, which is explained above, and they again recommended best to stay with all season/weather (if we dont want to swap tires for each trip). most if not all winter tires are not meant to be driven in Phx AZ because of the temp is way too high. We will be driving in 60 degrees+ temps, 80% of the time and be driving below 40s, 20% of the time. Last edited by dream54ing; 02-05-2021 at 12:44 PM.. |
02-05-2021, 02:20 PM | #20 | |
Rep 185
If you will be 60+ for 80% of the time and don't want to switch wheels for your trips north then the CrossClimate is your best bet. Thought you were swapping sets specifically for the trip north vs. leaving them on in AZ all winter. Last edited by Fennario; 02-05-2021 at 03:50 PM.. |
dream54ing485.50 |
02-07-2021, 12:39 AM | #21 |
10
Rep 32
After quite a bit of research I opted for the Vredestein Wintrac Pro winter tires, one of only 2 or 3 options without buying a second set of rims. I really like the look of my 21" rims and did not want to buy a set of 20's where you get a whole lot more tire options. The Vredesteins have been great in the dry and wet so far, snow not yet tested. I live in WA state where I only need these tires for a few months a year (Dec to Mar-ish) and then I can put the summer tires back on.
02-07-2021, 05:20 AM | #22 | |
Rep 25
Drives: 2021 BMW G07 40d
https://alltyretests.com/continental...7-test-review/ |
dream54ing485.50 |
