02-07-2021, 05:36 AM | #23 | |
Rep 25
Drives: 2021 BMW G07 40d
Mr.Pringle194.50 dream54ing485.50 |
02-07-2021, 06:49 AM | #24 |
Rep 117
Snow in Netherlands
It was snowing a little, which here is a huuuge problem , usualy it does not.... Pirelli s are ok, good traction, good braking.
dream54ing485.50 cptcolo102.00 |
02-07-2021, 10:16 PM | #26 |
Rep 185
02-08-2021, 04:19 PM | #28 |
Rep 8,656
Drives: eVeRyOnE mAD!
I've read running out of spec tires can harm the xDrive system, drivetrain, or something like that. 265/50R20 may be a little much?
dream54ing485.50 |
02-09-2021, 11:03 AM | #29 |
Rep 200
nZtiZia4629.50 dream54ing485.50 |
02-09-2021, 11:06 AM | #30 |
Rep 200
when I checked it, it was available for that size for alpine tires...
dream54ing485.50 |
02-09-2021, 11:12 AM | #31 |
Rep 903
02-09-2021, 01:38 PM | #32 | |
Rep 200
Local discount tire suggest me go with 2654521 for my front and get 295 for rear That size is identical to 265/50/20 for diameter... Only problem is how many xl load rating are there? For 20, I would just go with 275 |
dream54ing485.50 |
02-09-2021, 03:08 PM | #33 |
Rep 173
I took delivery a few weeks ago with 22s. Lucked out and my SA hooked me up with a previous client who just bought an M50i with the standard 20s AS who was looking to get rid of those. Picked them up for 2k.... Was looking at getting the Nokian Hakkapeliitta R3 SUV next year
dream54ing485.50 gqgambler716.00 |
02-09-2021, 05:13 PM | #34 |
Rep 903
thanks, i rather go with oem specs as well, but he insist that 265/50/20 is comparable. just want to make sure there nothing he or i missed
02-09-2021, 05:30 PM | #35 |
Rep 8,656
dream54ing485.50 |
02-09-2021, 05:33 PM | #36 |
Rep 903
there's a chance he is comparing it with what's on the door panel (21s staggered) i currently have on. which doesnt make sense since, like you said, oem 20s have 275/45R20
02-09-2021, 05:35 PM | #37 | |
Rep 8,656
your use case would be better served to get a square 20" setup with 275/45R20. Bridgestone Alenza Sport all season are OEM. tire chains are more readily available for 20" than 21" wheels if you need them in deep snow. take them off when you don't need them. |
02-09-2021, 05:45 PM | #38 | |
Rep 903
from what i remember he was typing in number from the 21s and finding comparable spec for weight, etc. |
02-09-2021, 05:51 PM | #39 |
Rep 8,656
highlighted in green below are the 20" alternative tire sizes to OEM 21". these are considered "comparable" versus anything else outside this green zone. just note the width of wheels a specific tire size can accommodate (far right column). not pictured are the tire load range (XL) required for the G05 in addition to the load index for the front and rear tires (refer to "max tire load" in owner's manual).
the issue with any tire size is finding ones that meet all your needs: wheel size, use case (all season, all weather, winter, etc), load range, load index, run flat or not. Last edited by nZtiZia; 02-09-2021 at 09:27 PM.. |
dream54ing485.50 |
02-09-2021, 07:17 PM | #40 | ||||
Rep 200
It's not all about size that matters... You also need to look at load rating as well as if it is xl... rule of thumb is usually stay within 1percent if possible. If you go with 265/50/20, you are going bigger and potentially rubbing... For example, 2754020 load rating of 111 but 275/35/21 only rated 107. I tried to put 2753521 square and was out of spec for rear because most of them were rating 104 or 107... It can get complicated if you want to play around with tire size that is so called factory spec.. |
02-09-2021, 08:01 PM | #41 | ||
Rep 200
02-09-2021, 08:22 PM | #42 |
Rep 8,656
true, i should've mentioned load range and index (addended above) and stated that 245 is too narrow for G05. OEM spec or slightly (1%) larger is best (safest), but like you said before, there is much more to consider than just size alone.
dream54ing485.50 |
02-10-2021, 08:27 AM | #43 |
Rep 903
so was able to get some clarification last night. Discount's policy doesnt allow them to sell any tires that are outside of the spec that came with the car. in this case the 21's. as mentioned by bimmerwerks, they have to have comparable load rating. the front is fine, but the rear has higher load rating and thats what they need to get minimum.
They said that he's unable to sell me tires, even if he wanted to. just becuase it doesnt meet the load rating. he does understand it's a minimal issue, but if something was to happen, they would be liable. Do you guys thinks it will be an issue with the taller and more narrow tires? Should i call the dealership? |
02-10-2021, 08:42 AM | #44 |
Rep 8,656
Discount will sell you any sized tires as long as they meet OEM specs, which include rolling circumference and load range/rating. my car came with 21" staggered, and i had no problems ordering a 20" square setup of tires/wheels from them. (i cancelled last minute due to change in wheel choice, though.) you aren't limited to 21" tires just because your car came with them. some folks mount their 22" during warm weather and switch to their 20" during winter. below are the various OEM tire sizes depending on wheel size, which Discount will sell to you long as your wheels fit inside them, and they have the proper load rating:
19" 265/50-19 (all 4 tires) 20" 275/45-20 (all 4 tires) 20" FRONT 275/45-20 20" REAR 305/40-20 21" FRONT 275/40-21 21" REAR 315/35-21 22" FRONT 275/35-22 22" REAR 315/30-22 u may run into issues going narrower/taller such as load rating or fender rubbing, or finding a merchant willing to sell you non-OEM-spec tires for your car. there is a guy here who is happily running taller tires for his staggered 21" setup: 275/45R21 FRONT and 315/40R21 REAR "with no drivability issues" according to him, though he did have issues with one merchant not willing to sell/mount those tires, so he kept shopping around until someone would. Last edited by nZtiZia; 02-10-2021 at 08:55 AM.. |
