02-28-2021, 08:52 AM | #1 |
Rep 681
Annoying G06 wind noise & no fix
Over the last month my X6 M50i has developed a persistent wind noise from the right side at speeds over 50mph which for me is 90% of the time. Wasn't sure if it was wind or tire noise so I opened and closed all the windows, doors, & sunroof with sunshade open and closed just to see if it made a difference. NOT. I also thought that perhaps that with the extended below zero temps and snow storms, that was causing the issue but now that the weather has broken it's still there.
Went for a drive with the SA who confirmed I was not nuts (what does he know) & brought it in for an inspection. SA called to say that despite everyone hearing this obvious wind noise they could not figure it out and so they want to bring an engineer in. Of course I will have a no charge loaner. I suppose replacing all the weather stripping might be in order but any thoughts would be greatly appreciated. |
02-28-2021, 01:44 PM | #2 | |
Rep 459
Still working from home, so I don't get above 45 miles an hour every day, so it's been a bit hard to track. I haven't had it looked at yet, so very curious to hear how things turn out for you.
2020 BMW X6 (G06) M50i - Manhattan Green/Coffee - 11/2022.63
03-01-2021, 11:18 PM | #3 | |
Rep 459
So, my plan was to have it checked out at the same time I also have my Summer's put on (a before/after drive), as it's quite possible that given the slightness of the wind noise, it could be tires...
03-03-2021, 08:27 AM | #4 | |
Rep 681
Not sure where to go on this but at $97,365 MSRP it is not acceptable. |
kkratochvil313.50 Pumxee104.00 |
03-03-2021, 08:49 AM | #5 |
Rep 62
I wonder if its a stuck door in the dash or footwell. There are numerous electromechanical doors to route air, heater or otherwise. Have them do a reset on the Vent/AC system. Might be as simple as the Cold temps worked a gate too much and its out of calibration....Just a thought. Good luck, I hope they figure it out.
528I 1998 SOLD
528Xi 2009 SOLD 535Xi 2013 ----- Daily driver 2020 X5 G05 i40 -- Family car |
puckybadger356.00 |
03-04-2021, 12:02 AM | #7 | |
Rep 459
I took a little time the last 2 nights and did a little joyriding on the highway, ranging from around 60MPH to 85MPH with the radio turned off and the heating/cooling fans turned off to eliminate any noise I could. I heard nearly zero wind noise. At least for now, my issue seems to have been a temporary, transient issue or I'm going crazy. I suppose it could have been numerous items, something related to some ice, cold seals, cold Winter tires, a particular cross-wind or some combination of those items and more. At the moment, I can't really in good conscience ask BMW to take a look at it. I'll do a bit more joyriding and then have my local dealer take a look at it when I switch to my Summer tires in a couple of weeks.
puckybadger356.00 |
03-13-2021, 08:46 AM | #8 | |
Rep 681
It was 28*F this morning so the heat was on for my 25 minuet, all Interstate drive to the office and the noise was as unbearable as ever. Really annoying. Well, I shut the heat off and sure enough the noise virtually disappeared. Turned it back on and the noise returned, Shut it off and it went way down. You get the message. |
kkratochvil313.50 |
03-13-2021, 09:58 AM | #9 | |
Rep 62
528I 1998 SOLD
05-11-2022, 08:45 AM | #10 | |
Rep 295
05-11-2022, 12:30 PM | #11 |
Rep 681
05-11-2022, 11:41 PM | #12 | |
Rep 459
Shawzy44158.00 |
05-12-2022, 01:37 PM | #13 |
805
Rep 1,790
Here's an SIB for wind noise on the X6. https://static.nhtsa.gov/odi/tsbs/20...05090-9999.pdf.
Shawzy44158.00 |
