03-01-2021, 09:33 PM | #1 |
126
Rep 304
Running X5 45e with no gas in the tank?
Hello, my car just got delivered to the dealership. Since it is shitty outside, I am planning just to keep it in garage until end of April. My dealer is asking me about should they put gas into tank or no?
Can I drive the car to my home just using electric engine with no gas in the tank? |
03-02-2021, 03:35 AM | #3 |
Rep 159
Either option will be fine. There will always be a minimal amount of gas in the tank from factory, and if electric range is enough to get you home that will work.
On the other hand, gas is good for at least a year in normal cars, and the X5 has a pressurization system in the gas tank to preserve gas on top of that. see also this discussion |
03-02-2021, 03:58 AM | #4 |
Rep 95
Better to keep the tank filled, less room for condensation to form.
03-02-2021, 04:39 AM | #5 | |
Rep 8,670
Drives: eVeRyOnE mAD!
45e, Ethanol Fuel, and Fuel Degradation over time https://g05.bimmerpost.com/forums/sh....php?t=1761514 |
PeterPuitG98.00 turbotoy4me131.00 |
03-02-2021, 05:17 AM | #6 |
Rep 183
03-02-2021, 07:56 AM | #7 |
199
Rep 353
This is why we have to press and hold the fuel refilling button, so the tank depressurizes before opening. That button is unique to the hybrids I believe.
03-02-2021, 08:04 AM | #8 |
Rep 8,670
exactly, though some folks thought that button actually opened the fuel tank door.
03-02-2021, 08:09 AM | #9 | |
Rep 95
03-02-2021, 08:14 AM | #10 |
Rep 8,670
how does moist outside air get in to fill the void when the tank is a closed system due to pressurization?
03-02-2021, 09:05 AM | #11 |
Rep 95
Let’s say you fill the tank, then go on a long trip in ICE mode, and burn up all the fuel. Something has to fill the void from the missing fuel or, the tank would likely be crushed by atmospheric pressure.
Also, as the fuel is used faster than it can evaporate and fill the void, and pressure drops in the tank, the rate of evaporation will increase. Which is exactly what you don’t want. I have done some reading on the system. From what I understand, the system is pressurized to prevent gas vapors from escaping. But, there is a control vent on the charcoal canister to allow outside air in to prevent a low pressure situation as I described above. Hopefully the air is dried along the way, but the canister is called a “charcoal” canister not a “desiccant”, so I’m not sure. |
nZtiZia4635.50 |
03-02-2021, 09:30 AM | #12 |
Rep 8,670
I'm just thinking aloud...
so your standpoint is looking at fuel degradation due to condensation from moist air coming in as fuel is consumed during ICE use. we agree the pressurized tank addresses fuel evaporation. inside while the sitting fuel lets off vapors, it'll get to a point where the pressure inside the tank is high enough to prevent further evaporation regardless of how much fuel is in the tank, but the tank's pressurization doesn't address the possibly condensed air in the "space" above the fuel, which can lead to fuel degradation. folks in the link I posted earlier stated it was better to have a smaller amount of sitting fuel degrade than a full tank of fuel, but this post seems to address this: "Yes Im sure about that. G20 and G05 both have pressurized tanks. Official reason for introducing that is for emissions reason: By pressurizing the tank and removing the evaporation system, you are stopping the fuel favors from escaping into the atmosphere. The bonus "side-effect" is that you create a fully sealed system, preventing oxygen and condensation from getting in, thus stabilizing the fuel for much longer periods." |
03-02-2021, 09:56 AM | #13 |
Rep 95
I think we are kinda on the same page.
Evaporation is a bad thing, it leads to fuel degradation. The system uses evaporation to create the pressure to prevent more evaporation. Which is good. But, a lower fuel level creates a larger void, which needs more evaporation to happen to create the pressure that prevents even more evaporation. Now, this is much better than venting the tank to the atmosphere. But, it’s even better to keep the tank fuel, and not leave a void for evaporation or condensation. |
volodp196.50 |
03-02-2021, 10:35 AM | #14 |
Rep 1,382
I run a PHEV now, would never do so with zero gas, they are not designed to operate as a BEV. It should be fine with a 1/4 tank, but never run on empty. Per Toyota, but applicable to all PHEV systems: "Though a hybrid vehicle can operate in electric-only mode when gasoline is in the tank, it is not designed to run without gasoline. Doing so could cause severe damage to the hybrid system, so drivers should be sure to keep gas in the tank at all times."
2024 BMW XM
2023 Porsche Taycan Cross Turismo 4S 2023 BMW iX M60 (sold) 2020 Porsche Cayenne E Hybrid (sold) 2018 X3 M40i (sold) |
ksavostin125.50 |
03-02-2021, 10:52 AM | #15 |
Rep 744
Not sure how the X40e does self maintenance/diagnostics but my Chevy Volt would periodically run the gas engine to clear the system and run self checks. Also even if the engine hadn’t been used ~yearly it would run to burn fuel in the system to avoid (I assume) varnish build up in the ICE system.
03-02-2021, 10:55 AM | #16 | |
Rep 8,670
Stoshu494.00 |
03-02-2021, 11:33 AM | #18 |
Rep 8,670
more solid discussion points in here:
45e - Gas engine 'run maintenance' ? https://g05.bimmerpost.com/forums/sh....php?t=1783616 |
Stoshu494.00 |
03-02-2021, 12:04 PM | #19 | |
Rep 485
03-03-2021, 05:40 PM | #22 |
Rep 6,789
There’s a one-way valve to let air into the tank as gasoline is used up, or you’d create a vacuum and damage the tank. That incoming air will have some moisture in it, and condensation is an issue long-term. I refilled my tank for the first time after about 6-months...the engine did come on reliably, but I will probably start to put some fuel stabilizer in the tank, but that’s probably not required, but I don’t think will hurt as long as you’re careful about the compounds in the stabilizer.
The fuel pump in BMWs is usually submerged in the tank and relies on the fuel to cool, lubricate, and stabilize it...you really don’t want to actually run out of fuel with a BMW. |
