03-27-2023, 11:29 AM | #1 |
Driver
200
Rep 516
Under seat subwoofer upgrade from HK
I have the HK system and while it is decent (non-audiophiles would say GREAT), the under seat subs leave something to be desired. I can hear the bass, but can’t really feel it. I have already tweaked the EQ settings.
I’m looking for a recommendation simple plug and play under seat drop in’s (if possible) - without upgrading the amp. AUDIOPHILES, what would YOU recommend? |
04-04-2023, 12:49 AM | #2 |
Rep 1,143
Drives: 2022 x5 40!
I replaced them all with the Bavsound huge improvement
04-04-2023, 12:55 AM | #4 |
Rep 1,143
Drives: 2022 x5 40!
04-04-2023, 02:03 AM | #5 | |
Driver
200
Rep 516
Thanks for sharing your experience. |
swainbmw525.50 |
04-04-2023, 04:21 PM | #7 | |
Driver
200
Rep 516
04-05-2023, 03:50 PM | #8 |
27
Rep 40
f32_27, i've not upgraded my HK but I have done a lot of other full audio system upgrades over the years. It just depends on what you want and are willing to spend. If you want a little more bass and a bit more accuracy, a sub upgrade might give some pleasure. But you'd not going to get to that "Feel it" level, not in a solid X5. And you'll be cranking it high enough you're now stressing the rest of the system. SO then you'll be looking at upgrading the other speakers of system. Which would be a nice upgrade. But to get significantly more accuracy and volume you'll need more power.
Once my warranty is up I'll probably go the full Match amp + a full speaker upgrade, otherwise to me, it's not worth the expense without adding an amp and I'm happy with the HK for no more than I drive my X5. |
04-13-2023, 10:30 PM | #10 |
Driver
200
Rep 516
05-03-2023, 12:47 AM | #11 |
Rep 1,143
Drives: 2022 x5 40!
On standard stereo hi if wont see much because of amp but if you have hk you will because there is a bigger amp on those cars .I have changed every bmw with hk over the year some bavsound and and used a shop in Portland also that was thousands so for the price it a better clarity with some bass response for your money 💰
05-03-2023, 08:33 PM | #13 | |
Driver
200
Rep 516
You grabbed the subs from a forum member right? |
05-03-2023, 08:39 PM | #14 | |
20
Rep 35
05-03-2023, 08:52 PM | #15 | |
Driver
200
Rep 516
Definitely share thoughts when done |
05-20-2023, 12:33 PM | #16 |
83
Rep 360
I have HK audio and the bavsound woofers and there isn’t much difference to me. I think the person that mentioned these need an amp would be right. Also these 8” woofers with tiny magnets are pretty limiting.
gx5_027200.00 |
