07-13-2019, 04:50 AM | #1 |
Rep 67
Grille vents open, fan on full after ignition off - 30D
Last night wife arrived after normal commute home. 25km (~15 miles) drive, cool 7 degrees c (~ 40 degrees f), free flowing traffic 110kph/80kph (~65mph/50mph), parked in garage, shutdown, radiator fan was on full (very loud roar btw) and grille vents open. Car smelled hot. No check lights on, car status all green and engine temp was at about 1/2.
Rang BMW service at local dealer who suggested possibility of a regeneration burn in progress just before arrival - that seem logical? New G05 30D only on 3rd tank of diesel, regeneration happens that often? Why would regeneration effect radiator fan and grills? Any other ideas? All seemed normal today. Round trip commute, no similar occurrence either outbound or on return home - normal shutdown at both ends of commute. |
07-13-2019, 05:58 AM | #2 |
210
Rep 323
Drives: BMW X5 G05 30d/BMW M5 F90 Comp
It has happened to me a few times before.
It is quite annoying and embarrassing to park your car near friends/family and your fan is on full blast. |
07-13-2019, 06:36 AM | #4 |
Rep 49
It happens to me quite often. Usually after normal trip between 10-15km. I was worried at first time but somehow seen many people having this so I'm not the only one.
07-13-2019, 07:26 AM | #5 |
Rep 3,507
Completely normal for today's Turbo vehicles. It is to prevent coking inside the turbos by allowing them to cool down. On my 50I there is two radiator systems, one for the typical engine another for the aux/turbo. Here in AZ I have parked inside the garage left the door open until the fans stop and then I can close the door.... I have seen it run up to 15 mins after.
2022 M8 Comp Convertible
07-13-2019, 08:33 AM | #6 | |
Rep 5,322
07-13-2019, 09:04 AM | #7 | |
Rep 3,507
My neighbors model 3 overheated in his garage this week... Yes a battery can overheat.. LOL He started doing what I've done and leave it open. I just tell Alexa to shut the door when I get the 15 min notification its been open.
07-13-2019, 10:49 AM | #8 | |
Rep 294
It's never been cause for concern to me because it's only associated with my driving or occasionally on some of the near 100 degree Fahrenheit days we've had here last month on very short trips (<1mi).
'13 Raptor (sold); '14 Raptor (sold); '15 A6 Quattro (sold); '19 X5 xDrive 40i (sold); '20 4Runner TRD Pro (sold), '22 MDX A-Spec (sold); '22 MDX A-Spec (sold); '24 X5 M60i
07-13-2019, 03:57 PM | #10 |
Rep 67
Exactly my thoughts on conditions that might need an extended cool down but as I said in my post it was a cold day, free flowing drive (not stop and go) and after the wife's normal commute (she is a comfort mode driver never hard on the throttle). The fan has never remained on before (and as noted quite obvious when it does) under worse conditions for cooling, warmer days, shorter trips, and traffic. The G05 is still relatively new and has yet to have had the turbo exercised
07-13-2019, 04:01 PM | #11 |
Rep 21
I believe this is normal. Still waiting for the BMW 30d but the Volvo D5 diesel engine does that as well. As normal procedure I let the engine run on idle 30 sec/1 minute before shutting it down after high speed driving. The radiator fan continues and can run up to 5 - 10 minutes depending on the engine and ambient temperature outside.
07-14-2019, 10:23 AM | #12 | |
Rep 3,507
