07-14-2019, 09:27 AM | #1 |
08 X3 6spd
28
Rep 112
Finalizing order for X5 M50i (M adaptive suspension vs airsuspension)
I have decided on the following options but my only issue is leave the M sport or get the airsuspension. Any comments on rear world experience between the two. How much of a sporty feel do we loose with the airsuspension route? How much of a luxury ride feel do we loose with the adaptive M suspension? Anything you guys would delete or add? Any way to conceal the ugly hitch on the M sport? I think the night vision isn't worth it. We have a lot of deer in our area but from what I hear it is not as good as it sounds.
C3Z Tanzanite Blue ZBHF Coffee Full Merino Leather Anthracite Brown Popular Matte Wood ZDH Dynamic Handling ZDY Driving Assistance ZLS Luxury Seating (Massage/heat/vent) ZPX Executive Package 2VR 2-axle air suspension 300 Space Saver Spare 3AC Hitch 4A2 Glass Controls 4HB Heated Front Arm Rests / Steering 6F1 Bowers and Wilkins 3KA Acoustic Glass 4M5 Leather Dash (Included with ZBHF) 1SM 22" Cerum Gray 4HA Heated Rear Seats |
07-14-2019, 09:48 AM | #2 |
Techie
16
Rep 105
I've found it reliable alerting for deer at night. It doesn't alert audibly however until you're real close. I wish it did some sort of sound as soon as it detected something since I don't see the visual alert quickly enough.
07-14-2019, 09:55 AM | #3 | |
Rep 91
Don’t believe you can order the Air Suspension WITH the Dynamic Handling Package on the X5. Think you can on the x7. The dynamic handling package should give you the best of both worlds. Superior comfort as well as superior handling and flat cornering. Your choices sound great. Will be an awesome car. Good luck. |
07-14-2019, 10:09 AM | #4 | |
Rep 4,246
You've selected ZDH Dynamic Handling Package which should exclude the option to add 2VR 2-axle Air Suspension (despite build notes not indicating otherwise) - based on current 50i M Sport with ZDH option rules. What I mean is that 2VF and ZDH use conventional spring struts versus 2VR comfort air struts. In short, BMW hasn't offered ZDH with air struts on a G05. I would confirm with your dealer. 2020 M50i suspension options: 1. 2VF - Adaptive M Suspension: this is standard 2. 2VR - 2-axle Air Suspension: selecting this will delete 2VF 3. ZDH - Adaptive M Suspension Profession, includes IAS (integral active steering aka 4 wheel steering), active roll stabilization: selecting this will delete 2VF or 2VR. The primary reason for optioning ZDH is that you want the best cornering and handling X5 available. The X5 is a SUV and will lean hard when you push it through a corner or curve. Active roll stabilization in ZDH counters that and delivers a flat cornering response. It works really really well. The primary reason for optioning 2VR 2-axle Air Suspension is that you want the most comfortable riding X5 available. The 2VR ride height adjustment allows you lower it to the lowest setting for ease of entry/exit and cargo loading. You can tune the air suspension a bit more sportier with DEC which will firm the up the air strut dampening. Owners are mixed with 2VR - some like it and some feel it's a bit floaty. Here'a a sense of what the suspension options will provide you: Ride comfort with heigh adjustment > Sport Handling > Sportiest Handling and active body roll control 2VR Air > 2VF Adaptive M > ZDH Also all 3 suspension options have BMW driving experience control which gives you to ability to adjust the electronic dampers - COMFORT, SPORT, ADAPTIVE. You're not giving up comfort with 2VF or ZDH.
07-14-2019, 10:30 AM | #5 |
Rep 691
@Auricom , thank you. This is has been most helpful.
I’m in a similar position as the OP but between 2 axle air vs DHP / M adaptive professional. I have not optioned for DHP because I did not know if it would be any more comfortable than the standard adaptive setup. Adding air suspension seems to remove the M rear diff. |
07-14-2019, 10:41 AM | #6 | |
Rep 4,246
07-14-2019, 12:00 PM | #7 | |
Rep 4,503
Drives: 2022 iX xDrive50, DGM
07-14-2019, 04:22 PM | #8 |
1053
Rep 1,952
I always though of DHP as a step above the other suspensions... So if your budget allows you definitely get it. If it's not in the budget then it's a personal preference between air and m adaptive. Air offering the more plush ride and M offering the sportier ride.
07-17-2019, 05:35 AM | #10 |
Rep 4,246
06-23-2021, 01:40 AM | #11 |
Rep 1
DHP
I got a 2021 X5 M50i and since neither the BMW USA website (used for the build), nor the dealership, told me DHP was available, I did not get it. All I can say is BY ALL MEANS, get it. I feel like I'm driving a Cadillac Escalade with an M motor. I have about 1500 miles on it now and my dream vehicle feels loose at high speeds, has more body roll, and a LOT less tightness than my 2016 X5 with DHP did. Is it fast AF? Sure. Does it look great? Absolutely. DHP changes the game and I regret not getting it everyday.
06-23-2021, 05:12 AM | #12 | |
Rep 2,631
06-23-2021, 10:37 AM | #13 |
11
Rep 34
I have almost the exact same build except I have the 21 " M wheel 741. I live in a pothole mine zone and would be worried about the 22's. Wish I had the acoustic glass I did not see it as an option. Stealth Hitch is aftermarket and Im thinking about getting it. I really like this SUV its perfect.
Good Luck |
06-23-2021, 11:36 AM | #14 |
PANIC!
482
Rep 823
I got the 2-axle air suspension. I agree that it's floaty on the normal/adaptive setting (subjective). I put the suspension in sports mode and it's perfect: not too stiff and it glides over road imperfections without any judder.
To me, air suspension is the only way to go. It offers great variability, can raise and lower on demand and, unlike metal springs, glides down the road and can hide road imperfections (even with 22" wheels) with absolute aplomb. Our cars weren't meant for cornering like a sports car; it's a tall, boxy SUV that weighs more than two tons. If that is what you want, then maybe you should be buying something else. Air suspension offers the best compromise and suits this car perfectly in my opinion. |
