03-10-2022, 02:09 PM | #1 |
Rep 54
45e Charge Time is borderline criminal
Hi all,
Have had my 45e since December and actually really enjoy it. My only complaint (other than the car sometimes not really wanting to fully turn off) is the limit that BMW put on the charge rate. I have a Level 2, 240v 60a charger at home and it is nearly CRIMINAL what BMW did to limit the speed at which this car charges. Makes me mad almost every single day. Carry on. |
03-10-2022, 04:11 PM | #2 | |
32
Rep 42
03-10-2022, 06:12 PM | #3 |
Rep 464
It's a PHEV. It's meant to be charged overnight. 5 hours is fine for an overnight charge.
If you're actually using the battery 100-0 multiple times per day, I don't think this is the correct product for you. An EV would make more sense, and those all have more expensive & faster chargers. |
03-11-2022, 03:26 AM | #4 |
Rep 3
80 percent
I’m shopping for a 45e now and heard this complaint before.
My sales person I spoke with yesterday mentioned setting a limit for the max battery charge to 80% in the settings, then the charge rate goes up. Perhaps it charges faster from 0% to 80% then 80% to 100% like most batteries, IDK Also heard the charge rate is set lower in the US vs Germany. I apologize in advance if I’m repeating incorrect info from my salesperson. They are not always truthful. |
03-11-2022, 05:02 AM | #5 |
Rep 114
The computed charge rate over the full charging time is higher if you limit to 80%. The actual amount charged until you hit 80% does not change.
03-11-2022, 06:04 AM | #6 | |
Rep 8,700
Drives: eVeRyOnE mAD!
1) you can't limit the end charging point in the vehicle. it always charges to 'full'. certain smart EVSE can do this, though. 2) by nature of charging lithium batteries, the first 80% is the fastest while the last 20% slows down. 3) the charge rate by default is 6A in the vehicle which is applicable to the level 1 EVSE. with level 2 EVSE, it will likely always charge at 16A (regardless of the lower vehicle setting) because it'll likely be in a dedicated circuit without fear of tripping the breaker. 4) the 45e has the same 3.7kW on-board charger worldwide. the level 1 or 2 "charger" is not a charger but rather a 'smart outlet'. they're more accurately called EVSE |
03-11-2022, 07:17 AM | #7 | |
Rep 114
03-11-2022, 07:20 AM | #8 | ||
Rep 8,700
03-11-2022, 08:40 AM | #9 |
Ex Moddy
119
Rep 145
What the hell has this thread got to do with "Pricing, Ordering & Tracking"?
If you're going to have a moan at least have the forethought do it in the correct forum!
X5 45e in Arctic Grey with Merino Leather, Technology Plus Pack, Comfort Pack, M Sport Pro Pack, Shadow Line Pack, Sky Lounge, Acoustic Glass, Tow Bar, Sun Protection Glass, Sky Lounge, Carbon Mirror Caps and Laser Lights.
03-11-2022, 09:24 AM | #10 |
Rep 114
Something must be different then. We don't have 120V here at all, so won't be a testing issue. If the charger is the same as the US one, maybe some things are coded differently.
03-11-2022, 09:26 AM | #11 |
Rep 114
03-11-2022, 12:52 PM | #13 | |
Rep 8,700
03-11-2022, 01:02 PM | #14 |
13275
Rep 19,805
It is under the floor in the cargo area.
03-11-2022, 01:06 PM | #15 | |
Rep 114
The charging cable plugs directly into the X5, we're not using the stuff that came with the car. |
03-14-2022, 08:19 AM | #16 | |
Rep 54
In fact, I can't find it anywhere on their website where it states this vehicle is meant to be charged overnight. Can you please post link? |
03-14-2022, 08:49 AM | #18 |
Rep 54
03-14-2022, 09:30 AM | #19 | ||
Rep 8,700
ThomasShelby31.50 |
