05-17-2023, 01:50 PM | #2 |
Rep 3,600
i think you would have to pull the starter relay. or unplug the start stop button inside the console. dont think there is a fuse for the in cabin circuit, there is probably a fuse under the hood (a very large fuse) for the starter
Present: 2023 G07 40i ZDH/ZDU/ZMP/ZMQ/2NH/ZPK/ZPP/ZRC/300/3AC
Past: 2013 335i 6MT ZMM/ZDH/ZTP/3AG/494/508 Past: 2016 F34 335i xDrive ZCW/ZDA/ZDH/ZTP/ZMP/2V5/5DL Past: 2019 G01 M40i ZDA/2VF/ZPP/ZPX/688/3AC |
05-17-2023, 02:09 PM | #4 |
Rep 878
Every button isn’t going to have a separate fuse, so pulling the starter relay or something else is probably the best/only approach.
It would probably be useful to understand the goal here, though.
M3 - X5 - 911 - Miata - Raptor - Edge
05-17-2023, 03:00 PM | #5 |
Rep 6,935
Very, very few things in a BMW use high current switches...almost everything is just a digital input to the computer, and it does the actual implementation of the desired effect...IOW, that button, unlike say the start position on an old key switch, is NOT sending power anywhere...it's an input to a circuit that performs that. Same with the headlight switch...it's not applying power, it's sending a message to get the job done, all by computers and serial data lines.
tooloud10790.50 |
05-18-2023, 12:50 PM | #7 |
Rep 3,730
2022 G05 B58/PHEV
+ a few very old BMWs |
05-18-2023, 06:39 PM | #10 |
13672
Rep 20,323
05-18-2023, 08:04 PM | #11 |
983
Rep 1,562
If you want to stop the car from being started by someone in the car, have you thought about the brake switch since you need to depress the break peddle to start the car? Don't know if it has a fuse or not (I doubt it does), but you may be able to put a hidden switch on it.
2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, HT, TC Kline DA Shocks & Camber Plates, w/H&R Springs, Stromung Exhaust, SSR Type C. Looking for new home.
2022 Z4 M40i, Misano Blue Metallic, Driver Asst Pkg, Prem Pkg 2023 X5 M50i, Phytonic Blue, Black Extended Merion Leather, Driving Asst Pro Pkg, Park Asst Pkg, Exec Pkg, Climate Comfort Pkg. |
Marty in NY2810.50 |
05-18-2023, 09:27 PM | #13 |
Rep 6,935
There are devices that can capture the signals from your fob if they're near enough when it is used for access. At least, that's what some news articles have indicated.
So much of the modern BMWs is controlled by computers...it's not at all like that anymore. There's not a simple path from a switch to the device it eventually activates. Most computers control more than one thing, so it tends to be very hard to impossible to disable one function. On an older vehicle, the start directly activated the starter relay, and the headlight switch actually powered the headlights...not on a modern BMW and most others. That is evident if you look at the wiring going into the headlight switch...maybe 24g wire, nowhere near large enough to power anything, even trigger a relay. When you looked at the start switch and found the fuse, that one fuse disabled all of that panel, which is likely only powering a small computer. What you might do is break the line to a hidden switch that made the start switch inoperable. But, that switch may be on a circuit board, but if you're lucky, you might find that there's a plug going into it specifically for that, |
05-18-2023, 10:11 PM | #14 |
Rep 3,600
you could also unplug the brake pedal position switch. car wont start without the pedal depressed. not sure if that integrated with the brake booster or if its a separate switch thats in the footwell.
05-19-2023, 12:01 PM | #15 | |
Rep 3,730
2022 G05 B58/PHEV
05-19-2023, 04:06 PM | #17 |
Rep 415
I know you don’t want to mess too much with wiring harnesses but your best bet is to tap into the start/stop button line and add a manual switch. Can you share the picture of the harness you talked about before which was for the center console? I don’t have my car yet but I might be able to trace which particular wire needs to be checked.
05-19-2023, 09:26 PM | #18 | |
Rep 3,600
2007 monaco blue 2013 estoril blue 2019 carbon black ( cmon, its really just a very dark blue) 2023 Tanzanite Blue II i'm guessing Orient Blue isnt PC anymore.... and i still remember how that car handled, i had the year they returned it closer to the E36 hydro steering rack. compared to the corollas i learned to drive on, it was (to my very limited experience) like it had no power steering. but that thing handled, you could feel exactly what the tires were doing through the steering wheel. and 22 years later i'm driving comparatively a couch on wheels
Past: 2013 335i 6MT ZMM/ZDH/ZTP/3AG/494/508 Past: 2016 F34 335i xDrive ZCW/ZDA/ZDH/ZTP/ZMP/2V5/5DL Past: 2019 G01 M40i ZDA/2VF/ZPP/ZPX/688/3AC Last edited by Orient330iNYC; 05-19-2023 at 09:35 PM.. |
05-19-2023, 09:30 PM | #19 | |
Rep 3,600
i still remember eating through a set of summer tires every year, i was very young and very stupid... I've had this handle since E46fanatics- joined in 2001/2002 and just left it
05-20-2023, 05:31 AM | #20 |
983
Rep 1,562
In the sticky posts -
https://g05.bimmerpost.com/forums/sh....php?t=1563063 It was last updated in 2020, so it may be out of date.
Marty in NY2810.50 innovaciones9.50 |
05-21-2023, 08:38 AM | #21 |
983
Rep 1,562
I just ran across this diagram for a kill switch. I don't think it is what you are really looking to do, but I though it was interesting. When someone tries to start the car with the switch active, it just blows the horn.
05-21-2023, 01:07 PM | #22 |
983
Rep 1,562
The challenge you have is coming up with a way to deter the professional thief as well as the teen joy rider. It is easier to thwart the joy rider just by making your car harder to take than the one down the street. The determined professional thief may also move on to a different car if they think your car has additional protection, but if they want your specific car, they are going to find a way to take it.
