10-26-2023, 08:11 AM | #23 | |
Rep 275
[QUOTE=yzhou2004;30597372]
'24 X5 M60i Tanzanite Blue II/Coffee
'21 X5 M50i Tanzanite Blue II/Coffee (RIP) '21 M240ix Long Beach Blue Metallic/Red '14 X5 s35i Lux Line Mineral White/Mocha (re-homed) |
10-26-2023, 10:01 AM | #24 |
Rep 216
Now that the weather has gotten colder here, I've noticed some squeaking in the rear of the car. I do have an air suspension. Will setup a visit with a dealer before warranty runs out in a couple of months.
11-27-2023, 02:12 PM | #25 |
Rep 268
My rear suspension on my2021 45e squeaks as well. It's very noticeable at low speeds. If I press on the tailgate repeatedly while parked, I can replicate the noise - hoping the dealership won't dismiss my concern and say this is "normal."
11-28-2023, 09:01 AM | #28 |
Rep 216
11-29-2023, 02:55 PM | #30 |
Rep 268
Dealership is replacing one air strut. I asked about the other side but no response yet. Should I push for an alignment? I know an alignment is recommended when any suspension part is worked on.
11-30-2023, 08:07 AM | #32 |
Rep 216
Depending on a part that is being replaced, the alignment may or may not be required. You can ask if it will be performed this time.
11-30-2023, 02:18 PM | #33 |
Rep 268
SA said alignment is not needed but I may push for one regardless.
Update: SA called back and said an alignment was also performed. Last edited by amus3d; 11-30-2023 at 05:02 PM.. |
12-01-2023, 09:05 AM | #34 |
Rep 216
12-07-2023, 11:31 AM | #37 |
Rep 216
I did some troubleshooting last night on the squeaking in my car. It's coming from the rear left upper section (above the wheel well). I was able to recreate the noise by pressing down on the rear of the car with a lift gate open or just bouncing on the rear seat. Will take it in shortly. Suspecting it's a strut also.
12-20-2023, 03:42 PM | #38 |
477
Rep 359
I’m having this too. Took it to the dealer today and was determined it was the front struts. They are covered under cpo- 2020 x5 40i with air suspension at 37k miles.
Of note I also had the steering rack replaced under warranty as that was causing squeaking as well. |
01-11-2024, 12:17 PM | #39 | |
RichP512
Rep 1
I told them, this was the exact noise we were getting. Now, to see what they come up with. |
01-11-2024, 01:05 PM | #40 |
Rep 882
Are there two different issues being described here? The video seems to reflect a 'clunk', but I have a very high pitched 'squeak' (from the front right?).
M3 - X5 - 911 - Miata - Raptor - Edge
01-11-2024, 01:12 PM | #41 |
244
Rep 375
Several months I posted about my front end suspension noise, and when I took the car to the dealer they didn't hear it. Then my warranty expired in October, the noise was getting worse, so I took the car back to the dealer in November. They determined 3 of my air struts were bad. Since I was technically out of the warranty period the dealer had to get BMW's authorization to do the repair. It took two weeks but BMW came through and two of the struts were replaced...the third is now on back order. I was told it would cost $12,000 to replace all 4 struts if the warranty didn't apply! A realignment is definitely necessary after the repair. 38,000 miles on the car.
03-01-2024, 05:40 PM | #42 | |
Rep 3
I have the same issue and also fixed it by changing the lower control arm. Thank you for your info, it helps. My car sounds the same as the video"yzhou2004" post but it's not air air-struck issue. Also one of my friends with a BMW 430 had this issue too. It seems a common consumable parts issue. If you are out of warranty, here are the pare lists. Hope these help people who have the same issue. 31-10-6-878-082 07-14-6-875-114 33-30-6-760-349 33-17-6-760-342 07-11-9-906-100 33-32-6-760-346 |
04-18-2024, 01:39 AM | #43 |
Rep 14
Add a data point in case others saw this post in the future.
My 2021 X5 with air suspension ran into similar issue, noise come from front suspension area at low speed on bumpy road. I took it to the dealer and they replaced both left and right air suspension structs under warranty which resolved the issue. |
