DIY M3/OEM Upper & Lower Control Arms
08-14-2016, 12:00 PM | #89 |
Rep 234
Drives: Estoril Blue F22 M235i
08-19-2016, 10:34 AM | #90 |
Rep 15
HAALLLPP!!
Ok so after ordering all the recommended parts I get it all together (drivers side first) and the passenger side is a pita to get on. After muscling the parts on my wheels are sitting far back in the arches and are both pointed at a 15-20 degree angle outwards! Where the hell did I go wrong?
Might also mention this is a 335i e93 and I also changed out the strut for koni yellow and springs are eibach pro. Last edited by nickitp; 08-19-2016 at 10:36 AM.. Reason: added info |
09-06-2016, 07:15 PM | #91 | |
Rep 23
Fingers crossed its sharpe and very responsive unlike before! I can then get on with ordering my new steering wheel👌🏻 |
10-04-2016, 04:31 AM | #93 |
Rep 11
TRW Control Arms - E93
Hi Guys, my upper and lower control arms arrived and intend installing them this weekend. I have been reading several posts that mention filing/Dremel burrs so the control arm will slide into the sub-frame. Wondering if I would expect the same or happens on occasion?
10-16-2016, 09:58 AM | #94 | |
Rep 233
2010 BSM 335i 6MT M-Sport w/ MMP Stage 3 Turbos
10-19-2016, 03:08 PM | #95 | |
Rep 422
15 to 20 degree angle! How does that happen? I can see a 2 to 5 degree outward angle if something was done wrong but not that much. Mine were done and I had the strut tower redrilled to clock the strut to get the angles right. Below are 15 degree and 20 degree angles just to show how much that would push out the tires.
I am just here to help! |
12-10-2016, 10:03 PM | #97 |
Rep 465
Just did this upgrade, and so far so good. I also did the BMW performance shocks at the same time.
Also, in case anyone is about to do this, I have the headlight leveling arm thats needed for this upgrade, You really only need the piece to bolt into the arm. If anyone needs this, and do not want to spend the $30 for a whole arm, message me. |
03-16-2017, 11:55 AM | #98 |
Rep 1,002
Thinking of doing this on my car but there is something I can't understand... if the M3 control arm is shorter how does it give more negative camber? I thought it would have to be longer and push the hub out a bit to give more negative camber
03-16-2017, 01:35 PM | #99 |
Rep 6,968
Drives: 2007 Black/Black 335i e90
The m3 control arms are longer
03-16-2017, 01:53 PM | #100 |
Rep 1,002
03-16-2017, 02:00 PM | #101 | |
Rep 6,968
The m3 lower control arms are straight all the way through, where as the OEM 335i control arms have a bend at the end. The lack of bend at all or reduced curve makes them longer and gives you a -.75 camber. It has to be longer or you would not get a negative camber. |
tadaska113.50 Jaronbwall284.50 |
03-16-2017, 02:20 PM | #102 | |
Rep 1,002
I'm looking to refresh my suspension (arms/bushes/balljoints) to tighten things up a bit. It's the full height suspension, I don't want to lower it. I am after a nice sophisticated feeling ride. Some people say the M3 arms make it feel a bit harsh. What do you guys think? OEM or M3? I don't really do fast driving anymore. |
03-16-2017, 06:37 PM | #103 | ||
Rep 6,968
Get them from FCP Euro. I'd also do the tie rods too. That's a "while you are in there" item. |
tadaska113.50 |
03-17-2017, 12:21 AM | #104 |
Rep 641
Thank you for this! Along with spacers the handling is and fixed my steering wheel shaking issue!
Alignment is needed after +1000000 on this, I could barely drive the damn thing after and had alignment setup for 7am next day. After you first drive it you will think you installed the arms backwards...lol
X5 40i
mweisdorfer1904.50 |
03-17-2017, 09:56 AM | #105 |
Rep 1,002
You tilted the scale in favour of the M3. This morning on the way to work I drove round the roundabouts faster than normal and the front handling felt disconnected from the steering and dull. I just ordered M3 arms from eBay (I am in the UK so no FCP Euro for me, though I like their website, over here online car part websites are so bad). But I forgot about the tie rods... Should I replace the inners as well? My car has almost 130k miles. Also shoyuld I get the M3 tie rods or just normal ones?
03-17-2017, 10:00 AM | #106 | |
Rep 6,968
Yes, if you have 130k on your car, I would replace them. They are probably not dead yet, but by 160k or 100,000 miles they will be. |
tadaska113.50 |
03-17-2017, 10:09 AM | #107 | |
Rep 1,002
03-17-2017, 03:49 PM | #108 | ||
Rep 6,968
http://www.hotchkis.net/product/e92-...r-endlink-kit/ |
07-23-2017, 03:58 AM | #109 |
Rep 648
Drives: 2012 335is
Thanks for the DIY! Question; how wide of a tire would you guess could fit on a 10 inch wide rear wheel? I want to go 295 in the back on a 19 inch wheel. Thanks
2012 E92 335is | BSM/Coral Red | Moonroof Delete | 6MT BQ Tuning | ar design DPs | M Performance Spoiler | Michelin PSS | Cyba Ram Air | VRSF CP | Fuel-It! Stg 2 LPFP Split Armrest | LUX Reverse Lights | Rear Fog Lights Enabled TOOK DELIVERY 24 OCT 2011 [FIRST PICS] [INTERIOR PICS] |
08-13-2017, 06:04 PM | #110 |
Cometh
1090
Rep 1,308
Drives: Boy's Soul
Thanks for the DIY. Just replaced my tension struts and wishbones on my 2009 E90 328i with 70k miles and it only took 2 hours at a slow pace. My tension strut bushings were both leaking and I started noticing that the steering feel wasn't as tight as it used to be. My wishbones were still fine though. For whatever it's worth, the factory control arms on my E90 were TRW.
I didn't want to deal with M3 wishbones (new headlight level, issues fitting the bushing end into the subframe and an alignment) so I just used the TRW M3 tension struts with new Lemforder stock wishbones. The M3 and stock tension struts are the exact same dimension so no alignment is needed. This is a sensible compromise as my original wishbones were still in good condition. The fluid filled bushing on the tension strut are the main problem, which is addressed with the M3 tension strut. The M3 tension struts alone are a great upgrade. Handling is much tighter and more responsive to steering input. Fore and aft movement is reduced and the car feels rock solid under heavy braking when it would previously wander. Road feel is increased and so is NVH, with slightly harsher bumps and a bit more vibrations transmitted to the cabin. I have Michelin AS3s for reference. I soaked all the hardware with penetrating fluid overnight and my Mastercraft 7.5A impact wrench (240 ft-lb max) took the 21mm balljoint locknuts off without any issues. A short extension was required to access the wishbone balljoint nuts. All parts were from FCP who pricematched RMEuropean. Leaky tension strut bushings at 70k miles: Stock tension strut vs. M3 tension strut: Last edited by The Nightman; 08-18-2017 at 01:48 AM.. |
