05-13-2023, 01:22 PM | #23 |
Rep 832
On the watch, did you long hold the watch face until edit shows up? Then scroll L/R to complications, pick the location desired then scroll down the apps to myBMW.
Two is One and One is None
05-13-2023, 02:01 PM | #24 |
Rep 68
This icon is useless. Also both, Apple Watch and iPhone apps.
I'd expect to have metrics for the petrol and the electricity percentage, not an icon that directs me to the app. The same app itself. What is the purpose of lights blink/horn? Maybe I'm too old to understand ;-) But we can't set precondition temperature for example. Why? Why BMW thinks they know better than me what temperature is right for me? ;-) Or why I can't start/stop charging remotely? Why I can only "charge immediately" or in the time slot? I want to decide. I know when my PV installation is producing power during the day - but not always I can just go and plug it into the charger. |
05-13-2023, 02:46 PM | #25 | |
Rep 8,767
Drives: eVeRyOnE mAD!
05-13-2023, 02:59 PM | #26 | |
Rep 8,767
2) lights and horn are often used to locate vehicle if you forget exactly where you parked 3) the preconditioning temp is whatever was set on your thermostat before you last exited the vehicle. I find the vehicle comfortable whenever entering, so I don’t quite see the need to tell the vehicle what temp to set if you were already comfortable at that temp on your most recent drive 4) the command to supply power to the vehicle’s on-board charger is initiated by the EVSE, so it’s not the fault of the vehicle that it can’t do what you’re wanting. you need a ‘smart’ EVSE capable of turning the power supply on or off wirelessly. I have a JuiceBox level 2 EVSE, and even though I set my vehicle to charge immediately, I can stop or start charging from the JuiceBox app. the level 1 EVSE that comes with the vehicle isn’t a ‘smart’ one so once it’s plugged in, charging will start immediately or in the time slot if scheduled; the same goes for any aftermarket level 2 EVSE that doesn’t have this capability. |
05-13-2023, 03:45 PM | #28 |
Rep 8,767
05-13-2023, 05:39 PM | #29 | |
Rep 68
2) thank you. I can imagine it can be useful for some people, but luckily looks like I'm not that old, as I still remember where my car was parked ;-) 3) I don't care what I had set when I left my car. I want to precondition it for my next trip. For my daily commute, I'm jumping in a hood, but when I'm driving longer trips, I prefer T-shirt only, so it means I need to stop and drop my hood after some time, because my €100k car can't be set to pre-condition on my requested temperature - but it can be set to pre-condition for a specific time; with a schedule! (EDIT: sorry, time slot definition only, not real schedule) 4) it can be set to start charging with a schedule, and the charger is built-in in a car, so it is possible to schedule, but it can't be triggered manually. Try to do not explain to me why it is not possible when it could be easily :-) EDIT: it's like with Digital Key. "Hey, you can use your phone or watch to unlock and start your car and we were first on the market", but they forgot to mention it works only from the driver's door, and all the comfort access idea is broken by design because someone decided it is "super cool enough", so there is no need to put additional NFC reader on the passenger side (front) and trunk handles at least. Last edited by zsap; 05-13-2023 at 05:50 PM.. |
05-13-2023, 06:15 PM | #30 |
Rep 832
de nada
05-18-2023, 08:15 AM | #31 |
Rep 8,767
preconditioning via the Watch app is much faster than the iPhone widget
the iPhone widget still has to open and log into the app first |
05-20-2023, 08:01 PM | #32 |
34
Rep 46
I think my watch app is working OK. However, I have two BMW vehicles, no problem changing in the app.
Is there a way to change vehicles on the watch app? Thanks. |
05-20-2023, 08:32 PM | #33 |
Rep 8,767
I also have two bimmers. can’t change between them in the Watch app. I’ve sent a feature request to the app developers. you should do the same. the more, the better!
