Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > DIY Guides > DIY - BMW MOST iPod Adapter Install
      11-20-2009, 12:34 PM   #45
FrankoQ
Deny everything
FrankoQ's Avatar
Drives: 2006 330i; 2015 X6, S1000RR
2015 BMW X6  [0.00]
2006 330i  [0.00]
Originally Posted by siscobmw View Post
I 'd like, please, the picture of the bridge you told about the stage 1.....
anyone? please?
Francesco from North Italy
The programming before the install is no longer needed.
I wrote another DIY for the MOST adapter with a few more details and pics.
Hope this helps you.
http://www.e90post.com/forums/showthread.php?t=184807
I need a drink
      11-23-2009, 03:55 AM   #46
siscobmw
freude am fahren ....scheiden freude...
siscobmw's Avatar
Italy
17
Drives: Z4 Sdrive30i tiefseeblau
Thank you very much!
My dealer told me that he gave me instructions and there's everything ...not true!
thank you....this is the confirmation you are better than dealers!
thank you again!!!!
Francesco
      09-01-2010, 05:38 PM   #47
dlr944
dlr944's Avatar
Drives: 335i Coupe
Installed ipod interface kit per the instructions above from (Evan and Franok) over the weekend. Installed kit 65 11 0 439 429 and it powers the ipod 3G. Did not pre-load any software. Took it to the dealer today and they coded the radio - charged me 1.5 hours of labor but considering the money saved above, it was well worth it. '07 E92
      01-31-2011, 09:43 AM   #48
mjd5
Australia
Drives: white e90
great write ups, like pics!
      05-11-2012, 12:58 PM   #49
F31cruisin
Drives: 330i
Does anyone know where I can get a new harness plug? I broke the tab on mine that holds in the fiber optic plug. It is plug X13812 in the instructions. Is this something that is sold separately?
      07-09-2013, 04:53 PM   #50
Olagüe
Olagüe's Avatar
Spain
106
Drives: 333i e92
Anyone know if you can update the interface? I connected a usb but the display shows UPDATE. Do not understand why the screen gets update, I need to update the firmware? the ipod works but the usb connector to the pen drive does not work. You can update? I have an ipod and I do not charge the battery and another ipod if I charge the battery.
thanks
      11-10-2013, 07:08 PM   #51
EverybodyWildOu
Drives: 2007 335i
I hooked mine up but there is no sound coming out from the headunit. And the SOS with the slash came up on the dash. Will the coding fix this?? Or did I botch up the install perhaps?
      11-13-2013, 12:47 AM   #52
EverybodyWildOu
Drives: 2007 335i
Figured out my issue. The optical input was switched with the optical output cable on the ipod harness itself... Thanks BMW...
      03-30-2014, 01:14 PM   #53
Obioban
Emperor
Obioban's Avatar
1614
Drives: M3, M3, M5, M5
2008 BMW M5  [0.00]
2017 BMW i3  [0.00]
2005 BMW M3 Coupe  [0.00]
2001 BMW M5  [0.00]
Is this all accurate for LCI cars?
2005 M3 Coupe, 2004 M3 Wagon, 2001 M5 Sedan, 2008 M5 6MT Sedan, 2012 128i M sport
      07-04-2014, 02:23 PM   #54
Obioban
Emperor
Obioban's Avatar
1614
2008 BMW M5  [0.00]
2017 BMW i3  [0.00]
2001 BMW M5  [0.00]
I retrofitted the MOST iPod interface to my wife's e91, including adding IPOD to the vehicle order. This was done by me using NCS Expert, and, when that didn't do it, by my shop using auto logic. Every module was also updated to the latest version by the shop when they couldn't get it to work, thinking maybe a newer version was require.
Anyway, this issue: Currently it is still identified on the radio as "CDC" instead of "iPod". Music is played, play/pause and next/previous track works, and meta data (song name) is displayed on the screen...
but
Playlist selection does not work (entire library only), shuffle does not work, and it starts at the beginning of the library every time "CDC" is selected.
Any idea what I could be missing?
Thanks!
      11-10-2014, 05:25 PM   #55
Obioban
Emperor
Obioban's Avatar
1614
2008 BMW M5  [0.00]
2017 BMW i3  [0.00]
2001 BMW M5  [0.00]
but
Thanks!
bump!
      11-10-2014, 05:45 PM   #56
enforcerman
The Man
enforcerman's Avatar
Drives: 2007 328i / 2014 328i MSport
2007 328i  [0.00]
It will always show up as the cd changer (CDC). Don't know about the playlist. Never messed w/ those. I just hook mine up and use the music app to play music. I never go through the stereo interface. its WAY to hard to use.
2007 328i (01/07 Production)
Monaco Blue / 2014 MSport 328i - Glacier Silver
Modifications:
Blacked out Kidney Grill || Bluetooth Retrofit || Ipod Retrofit || Rear Power Outlets || Euro Switch || Blacklines
      11-30-2014, 02:31 PM   #57
SMOKE EM IF U GOT EM!!
SMOKE EM IF U GOT EM!!'s Avatar
Drives: 06' E90 330, 20' F97 X3m
2006 330i SPORT  [7.34]
Put this in years ago when the iPhone 3 first dropped. Now I'm wondering does anyone know if BMW makes a lightning cable to connect to the most interface so we can use 5 or newer phones for this? I bought the lightning to 30 pin connector adaptor but that didn't work. It didn't recognize it at all. Sucks that this is almost useless unless I plug in an absolete phone or iPod.
LIVE FAST..DRIVE FASTER!!
      11-30-2014, 06:03 PM   #58
enforcerman
The Man
2007 328i  [0.00]
You have to get an adapter that makes the BMW 30 pin into the "new" 30 pin that charges. Then you get the 30 pin to lightening wire/adaptor. I have this setup and it works just fine. I even ran the wire up to the roof.
Modifications:
      12-03-2014, 10:30 AM   #59
hey thanks for the reply. would you be able to point me to a link to something. as stated i have the 30 pin to lightning. but i guess you mean i need one before the adapter i bought also. thanks for the help.
I also bought the belkin Bluetooth aux input jack. works great to wirelessly stream with but id also like to be able to use the port in the glovebox to keep an old phone in there too.
      12-03-2014, 01:58 PM   #60
enforcerman
The Man
2007 328i  [0.00]
I bought mine from cablejive.com years ago. Not sure if they still have it.
Modifications:
      02-27-2015, 11:24 PM   #61
NBTBRV8
Drives: LCi E60 530i
Guys,
I have installed my ipod in a E90 with CD changer. I have followed and double checked my install against the instructions, but it won't code, the SSS says that the module isn't responding correctly. I have checked that I have power to the ipod interface, I have checked the fibre optic cable, the input cable is in port 1 on the plug in to the interface (i.e. that is the one with the red light following the arrow pointing to the interface.
There are some posts on here that the fibre optic cables in the retrofit loom are wrong, can somebody explain this a bit better as from what I can tell the cable comes from the car in to the CCC out to the ipod interface and then bridged back in to the car loom.
The ipod shows the BMW roundel. I have also bridged my CD changer out of the loop.
Any clues?
      03-02-2015, 02:45 PM   #62
lolligaggins
Drives: 2007 E92
is there a fuse for this? Mine works but only when the ipod is charged. it used to provide power and recharge the ipod but it doesnt anymore. wiring all looks fine, is there a fuse or something i'm missing for this?
      03-07-2015, 05:12 AM   #63
NBTBRV8
Originally Posted by NBTBRV8 View Post
Guys,
Any clues?
Bump. Here are my coding issues in the attached screen shots.
      03-21-2015, 08:02 PM   #64
Could you link me up w the right stuff please?
      03-29-2015, 01:57 AM   #65
NBTBRV8
I got mine coded in the end on the SSS. The problem was me not coding it correctly (trying to code the CDC which I had disconnected instead of the retrofitted ipod) and new coding software.
Did anybody work out if it was possible to have the ipod continue on from where it was last stopped instead of starting from the beginning of the track again? I keep 1 hour + sets on my ipod, so this is an issue.
      07-26-2015, 01:32 PM   #66
EvanL
Drives: '07 335i, '23 330e
I'd be quite surprised if this were possible; the bridge interface that connects the iPod to the MOST system initializes the iPod and reads its index whenever the car is started.
Interestingly enough, the iPod bridge reinitializes whenever the DME is power-cycled, so if one could spoof the bridge into thinking the DME was still on, it might be possible. Long shot though...
