07-13-2020, 06:15 PM | #1 |
ghey
483
Rep 2,041
Just arrived! Going to install it now. Will post more in a bit.
Edit: install is done, took a few hours. Some notes: -it's possible to do without removing the entire door panel (still remove all screws and pop it out, but it can remain attached at the window). I just worked from the bottom, sitting on the ground. -the tweeter covers require you to sort of push down and slide in at the same time to ensure you catch them in the slots and minimize the gap -the cover on the side of the door panels is stupid. I broke a clip on. Every. Single. One. Despite following bav's directions and removing them from the back -definitely make sure you have an interior trim toolkit, a pick, and a right angle ratcheting driver (bav sells a kit with all of this, I happened to have some already minus the angle driver. Found it on amazon for $8). I am happy with them. They're not louder of course (need an amp for that), but they are much clearer to me, especially at volume, and has good bass without being muddled. Tl;dr if you have the base 10-speaker I recommend this upgrade. If I had HK I wouldn't have touched it, though some HK people upgrade as well and say it's great.
21 G05 > 20 G05 > 17 G30 > 14 F30 > 08 E90
07-15-2020, 11:55 PM | #3 |
ghey
483
Rep 2,041
Nothing different to see - just hear
(I didn't take any photos etc because there are a ton of photo comparisons of bav vs. stock speakers, and bav has an entire youtube video on replacing speakers in the G05).
07-16-2020, 12:02 AM | #4 | |
Rep 113
Is it big difference? |
07-16-2020, 12:05 AM | #5 | ||
ghey
483
Rep 2,041
Cure4All2cX53.50 |
07-20-2020, 03:19 PM | #6 |
Rep 3,341
I finally installed my stage 1 this weekend. I was lucky, only breaking 1 door clip in the process. I'm glad Bavsound included some extra clips, 5 of them I think. I ended up taking the door panels completely off, taking my time and rewarded myself with a couple of beer breaks. I pretty much followed their instructions. I ended up dressing extra wire length with tie wraps but that isn't needed.
I agree, it's a nice improvement in the overall sound, especially the highs. They seem extended, more present and smoother. The sound enhancement isn't what I'd call dramatic but sure is enough to satisfy me. It would be nice to get a plug and play Amp upgrade too, maybe one of these days. |
timmahh483.00 |
10-27-2020, 01:28 PM | #7 | |
Rep 223
10-27-2020, 04:31 PM | #8 |
ghey
483
Rep 2,041
The clips they supply they are fine. What I inadvertently broke, despite being extra careful, are the small pieces that cover the side screw hole, however, they are still holding in place despite losing one tab.
10-28-2020, 05:15 PM | #9 |
Rep 485
I think the HK system is muddy. Clarity is the main thing the stock system needs. If Bavauto improves the clarity, then that's a good upgrade.
