08-19-2020, 06:51 PM | #1 |
Rep 143
Dynamic Handling Pkg-will it improve "boaty" feel?
The car I want to love is the X6 with luxury seating, but it is bigger than anything I've ever owned (318, 535, 530,roadster,. When I test drove an X5 xDrive 40i x-line (as X6's are just not available), it felt really floaty with steering feedback very disconnected from what I am used to after 8 BMW's.
I've been told that the X6 will ride the same and feel the same as the X5 (true/not true). SO MY QUESTION IS: If I add the Dynamic Handling Package, will the whole steering feel and drive performance be tighter? Mind you I am mostly a suburban driver and not interested in more power or 22" wheels...I still want a comfortable ride similar to my 2020 X3. Thanks for your feedback!! Last edited by lair12; 08-19-2020 at 07:44 PM.. |
08-19-2020, 07:31 PM | #2 | |
Rep 4,246
X6 will ride similar to the X5 but I wouldn't generalize it as riding the same or feeling the same. My personal opinion is that the X6 rides a more sportier than X5 due to lower standard ground clearance 8.4" (8.1" for X6M50i) versus 8.7" (8.4" for M50i) for the X5 Depending on the stock X5 - which we don't enough details to provide you with a more contextual answer, eg was it 40i xLine, M Sport or M50i; what year model MY19, MY20, MY21 – you test drove could have the following suspension options: 1. Base suspension with electronic adaptive dampers (steel springs/struts) - 40i xLine, 50i xLine 2. Adaptive M Suspension, standard with M Sport Package (steel springs/struts) - 40i M Sport, 50i M Sport (MY19-20), M50i 3. Air Suspension, optional on all models (air springs/struts) - 40i xLine, 40i M Sport, 50i xLine/M Sport (MY19-20), M50i 4. Off-Road Package, no longer available (air springs/struts) - 40i xLine, 50i xLine 5. Dynamic Handling Package (steel springs/struts) - M50i If you test drove a X5 with the base suspension or air suspension and in COMFORT driving mode, then yes, it could feel "boaty". By pressing SPORT driving mode on all X5/6 models, will tighten the steering wheel, adjust electronic dampers to sport damping and in the case of air suspension lower the X5/6 ride height by 0.787" to Sport ride level. Steering wheel feel for all X5/6 models can be tightened by just press the SPORT drive mode button or customized in the iDrive under SPORT Individual. Opting for Dynamic Handling Package adds electronic active roll stabilization which will significantly reduce body roll on a high center of gravity vehicle. Adaptive M Pro works in conjunction with ARS and affects the electronic dampers. DHP also adds IAS or integral active steering which is rear wheel steering - this adds high speed stability and turns both front and rear wheels in the same direction for lane changing ease and at lower speeds turns the rear wheels opposite of the front to ease maneuverability for parking and shorter turning radius. Sounds like opting for Adaptive M Sport suspension or Dynamic Handling Package is what you're looking for in your next BMW.
puckybadger345.50 |
08-19-2020, 07:49 PM | #3 |
Rep 143
Thanks. I updated the original post with more info...X5 xDrive 40i x-line. My plan was to just get the X6 sDrive until this came into consideration. I've got an sDrive X3 4-cylinder with plenty of power for me. My alternative is to get it's X4 clone, but the X6 luxury seats are phenomenal for my wife's bad shoulder.
08-19-2020, 08:08 PM | #4 | |
Rep 4,246
Optioning either Adaptive M or DHP with Adaptive M Pro will provide you a much more sportier ride and comfort when needed. What you gain with DHP is reduction in body roll via electronic active roll stabilization plus M rear differential for increased traction and integral active rear wheel steering. Ja, luxury seating in X5/6/7 is one the reasons I stick with the larger BMW platforms. Definitely opt for luxury seating in Merino - you're wife will be very happy.
08-19-2020, 08:16 PM | #6 |
12884
Rep 19,395
08-19-2020, 08:31 PM | #7 |
Rep 143
It is my first BMW I actually do not like the M Sport package...and the incremental cost is $4500 for relatively little...but I may need to go that direction. Thanks.
08-19-2020, 08:36 PM | #8 |
Ring Leader of G8X Haters
25051
Rep 8,761
I would find one to test drive nearby or at another dealer. If you don't like the way it drives, I wouldn't take the risk of ordering a car only to be disappointed. As for steering feel, all modern BMW's pretty much have none so you will have to adjust to that (or of course look elsewhere).
Current Garage: 2022 Mercedes-Benz S 580 / 2023 Genesis GV70 2.5T / 2007 Mercedes-Benz E 350 / 1999 Mazda MX-5 Miata
Retired: '95 E36 325i 5MT / '04 E46 330i 6MT / '05 E83 X3 3.0i / '11 E90 335xi / '17 G30 540i / '19 F87 M2C 6MT / '19 MB CLS 53 / '20 MB GLC 300 |
08-19-2020, 08:54 PM | #9 | |
Rep 4,246
The only way to option Dynamic Handling Package for MY21 X6 is on the M50i model. If you're going sDrive40i? or xDrive40i? You'll need M Sport line which includes Adaptive M Suspension.
08-19-2020, 09:00 PM | #12 |
Rep 4,246
Ahh thanks for correcting me - usually reference the order guide, but I was using the online Builder......... this time, LOL...
08-19-2020, 09:00 PM | #13 |
12884
Rep 19,395
08-19-2020, 09:01 PM | #14 |
Rep 143
On order and pricing guide, you can get DHP on xDrive for $3650. It seems from what I read that DHP is worthy in many ways, including Integral Active
steering. I would love to feel the differences for myself. |
08-19-2020, 09:02 PM | #15 |
25051
Rep 8,761
Definitely a hard option to find. You'll have to see whether you would take a chance on ordering one and not being disappointed with the handling.
08-19-2020, 09:04 PM | #16 |
Rep 4,246
+1, dealers rarely will option a model with DHP.
08-19-2020, 09:06 PM | #17 | |
Rep 4,246
Also test drive with driving dynamics in SPORT mode.
08-19-2020, 09:09 PM | #18 |
Rep 101
2. Adaptive M Suspension, standard with M Sport Package (steel springs/struts) - 40i M Sport, 50i M Sport (MY19-20), M50i 3. Air Suspension, optional on all models (air springs/struts) - 40i xLine, 40i M Sport, 50i xLine/M Sport (MY19-20), M50i 4. Off-Road Package, no longer available (air springs/struts) - 40i xLine, 50i xLine 5. Dynamic Handling Package (steel springs/struts) - M50i So from the following options above, if one chooses Adaptive M suspension it will be steel springs/struts and 2-axle air suspension will be air springs/struts? Just wanted to make sure I didn't get air suspension/springs on my order. |
08-19-2020, 09:11 PM | #19 | |
Rep 4,246
Even though the suspension tech doc says G05 - it's also relevant for G06
08-19-2020, 09:14 PM | #20 |
Rep 8,774
From every single thing i've read DHP makes the X5/X6 handle like a BMW. I don't think i've come across one negative review of DHP here where as i've seen some posts about people complaining its too floaty with the standard or air suspension.
Alan
SmartSaves459.00 |
08-20-2020, 05:14 PM | #21 |
///M
270
Rep 385
Yes, DHP aka active roll stabilization will completely transform character of the car, like steering wheel feel and make 5000lbs fat cow handle like small car.
90% of bmw cars is specs without it unfortunately. But one is sure, when people try it, they must have it.
not rich enough to buy cheap
nvsocr755.00 SmartSaves459.00 |
08-20-2020, 11:00 PM | #22 |
Rep 143
OK, I was able to drive an X6 xDrive 40i without M-sport and DHP, and then drive an X6 xDrive with M-sport and DHP. The DHP seems to be a rare beast and that is a shame.
I think there was a huge amount of difference, which I believe comes solely from the DHP. When doing tight circles in an empty parking lot, the X6 with DHP stayed almost flat. I also enjoyed the steering and tighter suspension. I did not feel during my test drives that the loaded car was any worse on bumps or rough road, which was a nice surprise. The base model had upgraded to 21", while the loaded car was upgraded to 22". I would stick to the 21" if I chose to upgrade. |
SmartSaves459.00 |
