      04-21-2020, 01:58 PM   #1
puraj83
Drives: 2022 x5 m50i
Dash view
Anyone know if there's a way to get the x5M gauges via coding?
hkleyman135.00
      04-22-2020, 05:55 AM   #2
hkleyman
hkleyman's Avatar
Drives: 2019 BMW X5 50i M-Sport
I'd be interested in this as well. It's gotta be in there.
prthak6.00
      04-22-2020, 07:52 AM   #3
maczrool
Drives: 22 M50i Carbon Black
Have you looked in the files? What’s the point of the dual tachs? Seems pointlessly redundant to me. Would they not read the same thing? This isn’t a plane.
      04-25-2020, 09:51 PM   #4
James_G0540i
Australia
446
Drives: 2021 X5 G05 40i M Sport
Very true, but I guess its just for the novelty.
If you did this, you would lose the Map and Assisted Driving View.
With all the information available on the HUD these days, coupled with a Smaller Instrument cluster like this one, you could probably make the center head unit wider to extend more over in front of the driver. Only problem would be the steering wheel would obstruct the view.
      05-21-2020, 11:16 PM   #5
Hideada
Hideada's Avatar
Japan
23
Drives: BMW X5(G05) 2019
2019 BMW X5  [0.00]
I'm also interested in this DashView.
I heard a rumor that this has been implemented in some Mtype models and that this display will appear when the mode is changed.
But I don't know the truth because I and my friends don't use M.
I'm guessing that this display can be changed with the BC button.
I'm looking forward to the day when it can be analyzed and used in coding.
      05-22-2020, 05:17 AM   #6
GeniusAdam
BMW Genius
Ukraine
116
Drives: BMW
This one is used in the BMW M models. Started with M8, X5M/X6M.
It is only available through M Mode Sport or Track (with BC ju just change the information on the right side of the display), left side os configurable through settings. In M Mode Road it is similar to normal Live Cockpit Professional, just with different graphics.
      05-25-2020, 11:22 PM   #7
novablackm3
Drives: Performante, G05 M50i, RR SVR
Got to cose the m dash on a m50i , although it changed the fonts a little bit I couldn't get the m dash screen. another note it also doesn't display the drive mode and the bottom right anymore
      05-26-2020, 01:32 PM   #8
novablackm3
coding back to the default m50i , with the m dash the hud doesn't display rpm and the dash also doesn't display redline or the drive mode...
Huracán Performante 18- Novitec Springs | RR SVR 19 | G05 X5 M50i | E70 11 X5M retired |
Jerez Black E92 10 m3 RE SSK | AFE Filter | Fabspeed XFC / Xpipe | AA ECU 1.5v | BMW PSW | Envy Charger | Megan Exhaust
      05-27-2020, 03:08 AM   #9
Hideada
Hideada's Avatar
Japan
23
2019 BMW X5  [0.00]
Good afternoon.
Thank you for the good information.
Does that mean that there are M-mode sport and track modes in addition to the sport mode?
Is it viewable in coding unless it's triggered by a physical button?
I'm curious about this.
      05-27-2020, 05:06 AM   #10
GeniusAdam
BMW Genius
Ukraine
116
Drives: BMW
Good afternoon.
The M modes are available in X5 M (F95), there is Road, Sport and Track (only Competition model) - it changes the behaviour of the Driving Assistence Systems, with Track disabling them all. And also changing the display graphics.
You have a separate Setup button for your Engine, Transmition, Suspension and Brakes settings.
It is totaly different layout that in normal X5 (G05) where you have only normal driving modes with Experience Switch.
I can not comment about coding, no experience there.
      05-27-2020, 09:40 PM   #11
novablackm3
Good afternoon.
Yes it want changer the drive modes at all, only the font etc.. not worth coding on non m cars
      05-28-2020, 02:27 AM   #12
Hideada
Hideada's Avatar
Japan
23
2019 BMW X5  [0.00]
GeniusAdam
novablackm3
Thank you very much.
If the display is changed by the physical button, it may be difficult to change it by coding.
I was hoping that this could be changed as well, as some of the dash views had coding options.
I hope to ride a real M someday.
