      01-30-2024, 11:23 AM   #1
TonyB58
Drives: M340i RWD
Front End Creaking Noise
https://www.youtube.com/shorts/i_BAB1R6oVE
Does anyone know what the cause of this creaking noise can be? Noise is present whenever I lightly tap the accelerator and brake pedal at parking lot speeds. Must need headphones to hear
      01-31-2024, 01:47 AM   #2
TonyB58
Drives: M340i RWD
Originally Posted by peterflemming View Post
Hello, it's probably your exhaust system underneath the car. Put it up on a lift and bang around and I think you'll find it. I think it's just a vibration of metal to metal causing the noise. it should be easy to find and fix!
Are you saying that it is like the exhaust shield causing this noise?
      02-16-2024, 09:18 PM   #3
RMcoolX
Drives: 2014 528i
Probably your front and/or rear control arm and ball joints.
2014 X5 35i (w/N55 Stage 1 Tuner)
2012 C6 Vette (w/Supercharger)
      02-17-2024, 08:18 AM   #4
DaveyGJ
Drives: BMW X3
Sway bar end links. All 4 or my BMW's had this problem fixed under warranty.
      02-17-2024, 11:18 AM   #5
Rafichicago
Rafichicago's Avatar
Drives: 2018 M5 2009 E63AMG Wagon
My bet is on sway bar bushings.
      02-18-2024, 08:54 AM   #6
TonyB58
Drives: M340i RWD
It ended up being the front tie rods and there is a TSB out there for it.
      02-18-2024, 08:58 AM   #7
Rafichicago
It’s good they could actually replicate it and solve the problem cause that’s not always the case we just had our M5 dropped for yearly service and few other things including weird sound. Sounded like some vacuum leak of some sort. Over course of 5 days it couldn’t be duplicated. We had it on video but it seems like it has to start happening on daily basis. Oh well. What matters is that we have that in writing in the system and they have video of it.
      02-18-2024, 09:05 AM   #8
TonyB58
Drives: M340i RWD
Yeah, I had to ask my advisor if a technician could ride with me. The technician knew what I was talking about before driving the car since he had the same car.
Tags
340i, accelerator pedal, brake pedal, creak, creaking noise, m340i, noise
