DIY Valve cover removal N55 E92
11-19-2016, 05:14 PM | #23 | |
Rep 1,073
Squealing is gone on MAP 5; or any MAP for that matter. Took it out for some adaptation runs, got it to temp; it's all good now! |
01-28-2017, 09:43 PM | #24 |
44
Rep 340
Thank you for this DIY. I'm going to test tomorrow if its my PCV valve. I already replaced the serpentine belt/tensioner/idler pulley and to my dismay, it didn't fix anything LOL
02-11-2017, 10:55 PM | #25 |
Rep 671
I was having this same exact problem on my 11' n55 335i since last october and finally had my valve cover replaced a few days ago and the squeal is all gone and car runs like new now. For me even after I turned off JB4 by setting it to map 0, I was starting to have the squeal too. So glad this is fixed now!
2011 335i with M-Sport Performance package, Carbon Fiber interior trim, gloss black kidney grills. 18" Apex Arc-8, JB4, ETS Charge pipe
06-04-2017, 05:52 AM | #26 | ||
Rep 2
Hey vespa, thanks for the excellent write-up. I've just used it to replace a leaky valve cover seal on my RHD 2012 E91. I don't know if it's due to having the steering wheel on the right side of the car, or it being an E91, but I did a couple of things differently:
Refitting the windscreen base cowl did involve a bit of swearing though... |
06-04-2017, 12:03 PM | #27 |
218
Rep 245
Thanks for the feedback fasterer. I can certainly imagine how completely removing the windshield base makes everything else much easier and it probably isn't much more effort than just partially loosening it as I did. Even the partial loosening involves swearing as that thing just does not want to go back into place.
I haven't heard of leaky gaskets on the N55, did you find the cause? |
08-01-2017, 01:50 AM | #28 |
Rep 790
Just did this on a friends car and had to buy all the tools. Here's the links if anyone needs them:
Crowsfoot wrench tools: https://rover.ebay.com/rover/1/711-5...MAAOSwcUBYTzwU Gasket Plate: https://rover.ebay.com/rover/1/711-5...22%26_sop%3D12 Self tapping screws: https://rover.ebay.com/rover/1/711-5...4AAOSwNNxWFTpt |
01-10-2018, 02:01 PM | #30 |
Rep 120
My cover seems to be on very tightly and doesn't want to budge. Any tips for getting it off or should it slide right out if all the screws are loose? 2011 n55 x-drive e92
edit: Got it, and my project completed Last edited by RoarinForeign; 01-12-2018 at 07:16 PM.. |
01-17-2018, 09:53 AM | #31 |
117
Rep 255
How did you diagnose this problem? I smell burning oil pretty much every time I drive. I noticed a bunch of oil and dirt at the front of my engine (circled in red in the photo). Would the valve cover leak be noticeable near the exhaust (circled in blue). Any help would be appreciated!
03-11-2018, 09:57 AM | #32 |
Rep 405
Guys, I desperately need your help.
I did this - all was going well - too good to be true. But when torquing up my valve cover, the bolts suddenly went loose as I was tightening (bolt 1 - and it feels like 2 is the same). Is this normal or have a stripped the thread? I was using a torque wrench but 6 ft/lb is very low and I'm worried my wrench isn't accurate and has over torqued them. What are my options? Thanks. Edit. And now a bolt has snapped Last edited by dannyjones; 03-11-2018 at 11:55 AM.. |
03-26-2018, 10:42 AM | #34 | |
Rep 19
Plastic clip under valve cover N55
05-23-2018, 04:59 PM | #35 |
Rep 40
Drives: 2011 x-3 28i x-dr, 2012 335i
This DIY is positively OUTSTANDING!! only a couple minor tweaks did the trick on my 2012 F30 motor. My stealership quotes $1000 for this. Pelican parts had a $25 gasket. 1/2 a day later, it's FIXED!!
the injector wiring connector advice is priceless. many thanks...regards, Dan |
07-09-2018, 11:11 AM | #36 |
Rep 220
hello I just did this over the weekend. But the vent piece inside my valve cover is different from the one I received and looks different from the pictures you guys posted. Or did I break a piece and is still inside my cylinder head It doesnt look like it's broken though
See pictures below. I knew it was different but I went ahead and installed the new cover anyways because I needed to get car running. Upon first start up, i noticed something was wrong. It hesitated and the diverter valves was releasing air. After It idles down, the idle itself was rough and half engine light comes on. 2011 N55 335xi Please help!
Andriod 10.25", CA retrofit, Msport front bumper, msport steering wheel.
07-25-2018, 04:29 PM | #37 | |
Rep 2,499
You need to test out your torque wrench on a different higher torque bolt to make sure you get a feel for the click at such low settings. It's very different from the very loud positive click you get when tightening your wheel lugs at 100 ft-lbs. |
08-08-2018, 04:36 PM | #38 |
BMW Fan
290
Rep 838
OP, thank you very much for the DIY. I've got a 5/2012 135i with n55 and, although the n54 procedure is very similar, I could not have done this without you!! There are a hundred n54 write ups and videos but I didn't see any for the n55 even after months of research while at work.
I had everything going smooth until I realized that the valve cover would not come out....period. That's when I did more Google-ing and came across this thread. One thing I would add: in addition to removing the passenger wiper, lifting up the black plastic trim under the wiper, and removing the center piece where the strut bars go through, I found that moving the additional black plastic trim on the passenger side was critical to getting the cover back in without knocking the gasket out of place. It took 3 failed attempts to then see this additional piece was in the way. Loosen the one nut and just lift out of the way, same as the wiper trim piece. Thanks again.
2012 135i Mods: air scoops, CP, K&N filter, PS1, ADE FMIC, BMW PE, JB4, 1M front body, full M3 suspension front and rear, M3 brakes front and rear, M3 rear subframe and LSD
Owned so far: 88 M3 x 2, 95 325is, 95 M3 x 2, 06 Mini Cooper S, 08 335 xi, 09 Z4 35i, 01 M3, 12 135i Last edited by drwillb; 03-27-2019 at 05:47 PM.. |
08-09-2018, 12:16 PM | #39 | |
Rep 1
Anyways, I hope you were able to fix your situation. Good luck on the fix my dude. |
08-13-2018, 04:46 PM | #40 |
Garage Pimp
Rep 19
Great write up! I never removed my passenger wiper. Just lifted up the plastic piece high enough with a rubber bungy to the hood support. Came right out. Also don't forget to swap the engine cover ball/socket screws from old to new if you are replacing cover. I highly suggest replacing valve cover since the PCV will fail around 80k miles and its molded on the cover. Don't care for the valves that you have to cut and glue. To seal off the injectors, I cut the fingers off rubber gloves and zip tied them.
Also a good time time to replace the plugs. Went with one step colder NGK 97506 plugs for the N55. Price is around $15 each. Coils are optional. 2011 E90 Last edited by rodent; 08-13-2018 at 04:55 PM.. |
01-05-2019, 11:29 PM | #41 |
Rep 4
Hello fellow E90 brothers I have a concerning question. As cahme mentioned, I also broke that plastic piece off the valve cover gasket by accident I was only planning on changing the valve cover gasket and not the VC itself. Is it alright to put VC back on with the new gaskets? vespa mentioned how this piece is a drainage for the PCV system, but shouldn't it drain with no issues without the one way valve? Any help is appreciated, I love this car, but am concerned about damaging something. thank you all for any help!
2011 BMW 335i E90 AT MHD Stage 1+ |
01-06-2019, 11:42 AM | #42 |
218
Rep 245
That valve is at the end of the oil separator and forces air to be drawn into the beginning of the separator while allowing oil to drain back into the crankcase at the end. Without it, the oil will still drain just fine but some oily air will be drawn into that passage, bypassing the oil separator. The net result is that you will have significantly faster carbon buildup on your intake valves. It won't damage anything, but you'll probably want to clean your valves every 30K instead of 100K miles.
01-06-2019, 06:17 PM | #43 |
Rep 4
vespa Thank you for the quick response! Would installing a oil catch can help this situation? I intend on pushing the car to MHD stage 2+ and the last thing I would want is gunked up carbon in my intake valves.
01-09-2019, 07:02 PM | #44 |
Rep 4
I wanted to add that I went ahead and replaced the valve cover gasket and spark plugs on the N55. After I assembled everything back and put the negative terminal back on the battery, the car crank, but does not start at all Using MHD i looked at the DME codes and this is what i am getting
2C89 - Diverter valve, actuation: short circuit to earth 2D52 - Intake VANOS solenoid valve, actuation: short circuit to earth 2D9C - Exhaust Vanos solenoid valve, actuation Short circuit to earth 2E4B - Exhaust gas flap, activation: Short circuit to earth 300C - Intake camshaft sensor electric, short circuit to B+ 300E - Exhaust camshaft sensor, electrical: Short circuit to B+ 332F - Terminal 87_2: No voltage 3400 - Oil- pressure control valve, activation: short circuit to earth In addition, I noticed that the number 38 fuse in the fuse box keeps blowing even after replacing one time. I am lost at this point and frustrated with the car, any type of guidance and help from the community is very much appreciated! |
