09-25-2023, 03:28 PM | #2 |
Rep 6,838
If you're lucky, your salesperson might be talked into including it with your sale. It's a parts department thing, and some of the online BMW shops will discount it some.
09-27-2023, 07:47 AM | #4 |
Rep 83
Drives: 2024 X5 50e M-Sport
Here is one you can buy online. It is the correct one for the Flexible Fast Charger 2.0 that comes with the 2024 X5 50e. It has a NEMA 14-50 plug but there are others out there depending on what electrical service you have available at your house. I believe the 45e came with the FFC 1.0 and these adapters are not compatible with each other.
https://www.getbmwparts.com/oem-part...50-61448490525 |
09-27-2023, 08:26 AM | #6 |
Rep 8,724
Drives: eVeRyOnE mAD!
in the U.S., only the adapter for plugging into a common household outlet (110/120V) is included. this is level 1 charging.
if owners want to do level 2 charging (220/240V), then they need to purchase the adapter for that level since the plugs are different due to the voltage difference |
09-27-2023, 08:33 AM | #7 |
1228
Rep 1,350
^^^^^^along with running a 220 line to feed that plug and with an appropriate breaker if there is room in your home panel, a sub panel could be needed also.
09-27-2023, 08:44 AM | #8 |
Rep 92
09-27-2023, 08:48 AM | #9 |
1228
Rep 1,350
09-27-2023, 08:50 AM | #10 | |
Rep 92
Yea! I already have the plug in my garage from my Tesla. I had to purchase an adapter for the Tesla travel charger as well. I guess I will sell the Tesla one on eBay or something... haha. |
09-27-2023, 09:19 AM | #12 | |
Rep 99
(*) Yeah, yeah, total waste heat is roughly the same. But by lowering the rate it allows the garage to better keep up with its convection cooling rate. |
09-27-2023, 10:00 AM | #13 | |
301
Rep 382
FWIW most people in Germany that are charging at home have a 11kW Wallbox fed by 3x230V/16A phases (400V against each other with 120° phase-shift) which is more than the car can do anyways. |
nZtiZia4674.00 |
09-27-2023, 10:18 AM | #14 | |
Rep 8,724
after my wife got her 530e, we tried sharing our one JuiceBox, but it became an inconvenience, so I got a second one which shares the load on the same circuit. now we can charge simultaneously. |
bono279.50 |
09-27-2023, 10:20 AM | #15 | |
1228
Rep 1,350
09-27-2023, 10:23 AM | #16 |
Rep 8,724
09-27-2023, 10:32 AM | #17 | |
Rep 6,838
So, it's more like nearly 7x faster in the USA with a level 2 cord with the FFC. |
09-27-2023, 11:29 AM | #18 | |
Rep 571
Thanks. 50e replaces 530e, so no issue then. Thank you!
09-27-2023, 11:51 AM | #19 |
Rep 18
Hi, Rather new here and I have a new 50e. About chargers, the charger I got came with a charger capable of 40 Amps at 240 volts. It only came with the 120v pigtail. I order a leverl 2 pigtail but it is for a nema 6-20 plug which is rated 16Amps at 240. is there a pigtail for the 40 amp (I think limit is actually 32 amps) for the BMW supplied charger? I suppose it would be a 14-50 or something?
09-27-2023, 12:41 PM | #20 | |
Rep 8,724
the 14-50 adapter for the FFC 2.0 is rated to 40A |
09-27-2023, 03:50 PM | #21 |
Rep 6,838
Across the world, there are like 15 different pigtail adapters to handle various local plugs and standards. The pigtail you got is for the FFC version 1 and won't even plug into the FFC you have. Right now, there are only two pigtails for US style plugs, the one that comes with it is for 10A/120vac. The other is for 40A/240vac, and that's what you want for level 2, as it's the only other one that will work with your FFC. Depending on where you live in the world, your choices will differ.
09-27-2023, 06:54 PM | #22 | |
Rep 18
https://parts.bmwnorthwest.com/p/BMW...oaAvd0EALw_wcB What I can't find is the pigtail with the 14-50 plug that fit the charger. Actually though, I only have a dedicated 20Amp circuit at this time, so 16A will suffice. I just want to be ready for when I upgrade. Thanks |
