05-06-2021, 01:25 PM | #23 | |
Rep 115
Thanks for the newb clarity. |
05-06-2021, 01:42 PM | #24 |
Rep 275
05-06-2021, 02:06 PM | #25 | |
Rep 8,559
Drives: eVeRyOnE mAD!
while I'm not certain what option 1 gives you, the equalizer doesn't look different from the HK equalizer TBH. I believe option 2 gives you the different sound profiles. one of the options (don't know which one) changes the sound menu background to a perforated speaker grille though maybe that was there even with HK. sorry I couldn't be much help. Just code both and be happy! One major benefit I noticed by doing this is that the system is a bit louder at the same volume setting. Last edited by nZtiZia; 05-06-2021 at 05:04 PM.. |
05-06-2021, 07:27 PM | #26 | ||
Member
892
Rep 2,029
Drives: 2019 X5 40i M Sport
Garage List 2023 BMW M2 (HEA) [0.00]
2021 330i xDrive [0.00] 2019 G05 X5 M Sport [0.00] 2017 Jeep Grand Che ... [0.00] |
2019 X5 Alpine White M-Sport
Software Version 11/2022.31 2023 M2 (HEA) Brooklyn Gray 2021 330i XDrive Alpine White M-Sport |
05-07-2021, 05:29 PM | #28 | |
Rep 115
05-07-2021, 06:16 PM | #29 | |
Rep 8,559
I can confirm these are definitely not available with stock HK settings because when I got my vehicle back, they updated the firmware and I lost all my BimmerCode. I verified this when I went through all my known changes including the sounds menu which was back to stock HK. the equalizer should be located below the adjustment bars. Scroll down further and click on Equalizer. |
05-08-2021, 09:02 AM | #30 | |
Rep 115
05-08-2021, 09:40 AM | #31 | |
Rep 8,559
https://f92.bimmerpost.com/forums/sh....php?t=1706832 |
05-08-2021, 10:18 AM | #32 | |
Rep 115
nZtiZia4592.50 |
01-10-2022, 12:24 PM | #33 | |
Rep 105
I've seen Option 2 listed as HU_MGU > Expert Mode > 3000 HMI > HIGH_END_AUDIO_MENUE and as HU_MGU > Expert Mode > 3000 HMI > HIGH_END_AUDIO_B_AND_W. Does anyone know which is correct?
01-10-2022, 12:48 PM | #34 | |
235
Rep 372
Will take a screenshot of the option when I get a free moment.
2021 G05 X5 s40i Phytonic Blue | Ivory White Vernasca | Anthracite-Brown Poplar Matte Trim
2015 F10 535i M-Sport Space Gray | Black Nappa (Gone) |
01-20-2022, 01:57 PM | #35 |
Rep 153
Can anyone help with coding these via Bimmercode:
1. Comfort Individual (I have coded Comfort Plus, but i can't customize that) 2. Does anyone have a list of Expert Mode Codes? I know they are scattered all over the forum, however, thought i'd ask |
02-05-2022, 06:22 AM | #37 |
Rep 153
03-28-2022, 01:17 PM | #38 |
23
Rep 39
Drives: 2022 BMW X5 xDrive40i
So I picked up my new 2022 X5 xDrive 40i from the dealership on March 23. I did some initial coding in Bimmercode and I have a question about one of options. I see that "Adaptive" driving mode is one of the options that can be set as the starting drive mode. However, I do not have an adaptive button on my console. I have Eco Pro, Comfort, and Sport. If I code the starting drive mode to "Adaptive", will it really use the adaptive setting?
03-28-2022, 01:21 PM | #39 | |
12885
Rep 19,397
2021 BMW G20 M340i xDrive - Verde Ermes/Black - 03/2023.67
03-28-2022, 01:36 PM | #40 | |
23
Rep 39
03-28-2022, 02:52 PM | #41 |
23
Rep 39
FWIW, I coded for Adaptive mode on startup. It does show on the instrument cluster as suspected, but I have no idea if it is actually running in Adaptive mode or not. I drove the car afterward, and nothing seems odd or really that different from comfort mode from what i can tell. Of course, if you switch to another driving mode while the car is running (like Comfort or Sport), there is no way to get back to Adaptive mode until you turn the car off and turn it back on.
03-28-2022, 05:29 PM | #42 | |
12885
Rep 19,397
Hopefully someone else, Auricom are you out there, will chime in.
04-04-2022, 06:11 PM | #43 | ||||
Rep 4,246
You can code ADAPTIVE mode but you want to test if it works, there's the thread way back when where in ADAPTIVE mode and Speed Limit Assistance is set to adjust speed to route - coming to stop light intersections or stop sights - vehicle should slow down. If it doesn't then enjoy the coded ADAPTIVE mode lights in the dash.
Tch-Nrd118.50 PrinceChaos1.50 |
