01-10-2022, 10:56 AM | #155 |
Rep 224
Does the bimmertech amp kit come with a ground cable and a fused power cable that you need to run to the battery, or do I need to purchase that separately?
01-10-2022, 11:12 AM | #156 |
Rep 82
It does not and you do not need to add that cable. They use the OEM wiring to supply power to the amp. While the amp may have a rating of over 1000 watts, that is a transitory peak rating. Unless you are running crazy big subs and trying to wake the dead with thumping bass you should be fine.
Sample57.00 |
01-10-2022, 11:31 AM | #157 |
Rep 224
Do all X5s have Active Sound Design (ASD)? I just ordered the bimmer-tech amp because Crutchfield doesn't have the Match7DSP MEC anymore. I did not choose the ASD deactivation cable, but I think BimmerCode can disable it if needed.
01-10-2022, 12:20 PM | #158 |
Rep 15
Silver6495.00 dananelson1226.00 |
01-11-2022, 01:56 PM | #159 |
Rep 193
Okay, have 3 bmws, one of which is a 2012 328 that I am trying to unload.
And, I have been thinking that the Wi-Fi system in my 2022 x6 cannot be really THIS BAD! So, today, coming back home from lunch, I disconnected Apple Play and played my phone music through the iDrive system directly… Boy, what a difference in sound quality! Much much better. Anyway, I believe that the compression is really happening through appleplay, and I encourage all to try the basic Wi-Fi system through iDrive. It really much better, and basically acceptable sound quality, instead f the crap I was hearing. Ps. I consider myself an audiophile, my home system is valve based, and my speakers are custom made.
2022 X6 x40i MSport black sapphire / Cognac
01-12-2022, 05:22 PM | #160 | |
Rep 216
01-12-2022, 11:06 PM | #161 | |
Rep 193
01-12-2022, 11:46 PM | #162 |
Rep 216
Think I misunderstood... you're referring to a USB connection, not a iDrive/BT connection? In fact I recently subscribed to Apple Music and am playing downloaded Apple Lossless music on my iPhone via USB... its really good.
01-13-2022, 12:28 AM | #163 | |
Rep 7
silverstar335501.50 |
01-14-2022, 12:30 AM | #164 |
Rep 224
I should be getting my Bimmer-tech amp soon and have already downloaded the software. The Audiotec Fischer website doesn't have settings for the PP86DSP Amp for BMWs.
Does anyone have sample profile settings for the Bimmertech/PP86DSP amp they can share? I've replaced my Hi-Fi speakers with Focals (including the underseat subs) and I'm looking for settings that I can load for my setup. I would appreciate any settings, including custom ones that I can try out. |
01-14-2022, 10:56 AM | #165 | |
Rep 216
01-14-2022, 03:04 PM | #166 | |
Rep 15
Helpful Tip - Make sure you do not forget to plug in the USB cable into the amp before you install the mounting bracket. Its quite difficult to plug in after you mount. |
01-16-2022, 12:04 AM | #167 | ||
Rep 1,340
01-18-2022, 08:19 PM | #168 |
Rep 224
My G05 originally came with 676 Hi-Fi. I replaced all of the speakers/woofers with Focals. I recently installed the bimmer-tech amp to power the Focals and I don't really notice the blinkers being any louder. Maybe they are, but I wouldn't have known it was an issue if I didn't read this forum. Your results may vary since others have complained about it, but to me it's fine.
01-18-2022, 09:30 PM | #169 | |
Rep 216
01-19-2022, 12:26 AM | #170 | ||
Rep 113
Can you send me a amp file? |
01-19-2022, 09:05 PM | #171 | |
Rep 224
I contacted Bimmer-tech, but they want me to tell them how I want the sound to change, instead of them just sending me a bunch I can load and listen to. |
01-19-2022, 10:07 PM | #172 | |
Rep 6
01-19-2022, 10:15 PM | #173 | |
Rep 224
Audiotech Fischer does have a sample G05 Hifi setup for your 7DSP though. I'm not sure if 86DSP and 7DSP settings are compatible. |
01-20-2022, 08:24 AM | #174 |
Rep 15
Send an email to bimmertech support and ask for all of their tuning files. They will provide you with links to their files shared via google drive.
01-22-2022, 01:14 PM | #175 | ||
Rep 6
If it's not too much trouble, could you DM share your Bimmertech tunes files in a cloud drive link. Bimmertech will not share unless you buy their amp/DSP from them. |
