11-16-2021, 10:29 PM | #1 |
11
Rep 34
22" 742m's As Winters... To Square Or Not?
I know this is highly contested, but I want the car looking sweet all year long. Since I'm putting 22" Scorpion Winters on, I think it's already accomplishing the "goal" of having the right tire for the right season.
My question is should I go square or should I get the wider 315's in the back like the summer set? Is the squared route only better because you can rotate the tires? Is it because they are a bit less wide so technically a better winter tire? Does anyone know if the square setup looks goofy on the wider rim, even though it technically fits? |
11-17-2021, 08:12 AM | #2 |
Rep 198
I have the 22" 742M's squared up. I have the 9" wide rims all the way around. I did this with all seasons (live in South Carolina).
Benefits I see. - Keep the looks of the 22" - Opens up more tire options (I run the Michelin Pilot Sport All Season Plus 4). - Tire Rotation Downsides. - Back doesn't look quite as aggressive from behind, but not horrible. |
11-17-2021, 08:50 AM | #3 |
Rep 8,691
Drives: eVeRyOnE mAD!
i understand mounting the same tires all around despite the wider rear wheels, but you won't be able to rotate the them because those 10.5" wheels can't be installed in the front despite having the narrower winter tire.
narrower tires are better for snow/ice traction, but if you don't see yourself in those conditions (just getting winter tires for colder temps), then wider rear tires will fit better on existing wheels. the wider the tire, the higher chance for "floating" on the snow/ice. you said "technically fit" meaning the 10.5" wheels won't stretch the narrower tires too much if you decide to go square? |
11-17-2021, 08:57 AM | #4 | |
11
Rep 34
When i say fit, meaning the tire sire for the fronts fits the rears. Are you saying those can't be rotated? Not the wheel, but the physical tire? |
11-17-2021, 09:13 AM | #5 |
Rep 8,691
the offsets for the rear wheels may pose clearance issues if rotated to the front. The best way to negate that is to get a square setup of wheels and tires all around, which means buying an extra pair of front-spec wheels to be installed in the rear.
11-17-2021, 11:35 AM | #6 |
11
Rep 34
If I buy a square setup and 1 season the tires are in the back snd the next season in the front does that work? Tires not wheels, I understand rear wheels can't go in the front.
11-17-2021, 11:58 AM | #7 |
Rep 8,691
so you'll swap the tires that were on the rear wheels onto the front wheels? yeah, that's fine cuz you're rotating the tires instead of the whole tire/wheel setup. seems an inconvenience to some, which is why they would rather get a square setup all around (wheels and tires).
11-17-2021, 10:50 PM | #8 | |
Rep 463
11-17-2021, 11:28 PM | #9 | |
Rep 8,691
further, in his first post he specifically said "wider rim," so why would he distinguish the front tires "technically fit" the rear wheels if all the wheels were the same width as you say? the narrower front tires would just fit IF all the wheels were the same. he wouldn't point out the difference in the wheels if there were none. the OP wants to know if he can mount the same sized (front) winter tires on his staggered wheels. that's why all those questions on the bottom of his first post. "will they look goofy?" he was also wondering if he could rotate the tires to which I replied he couldn't because of how wide the rear wheels are despite mounting winter tires that are meant for the front wheels. |
11-18-2021, 12:18 AM | #10 | ||
Rep 463
11-18-2021, 12:37 AM | #11 | |
Rep 1,449
This likely won't fly in states that care about inspections if your car came with 22" because door jam would have 22" staggered sizes listed and your square set-up would be below spec in the rear. All depends on how your state inspection is done. In PA this wouldn't fly (although you could find a place to pass you) as liability issue for the places that passes you.
No. Try not. Do. Or do not. There is no try.
-Yoda |
11-18-2021, 12:25 PM | #12 | |
Rep 293
11-18-2021, 01:23 PM | #13 |
Rep 256
Drives: '24 M3 Comp X-Drive
Would I need to get a wider wheel vs 9.5 stock to put the 305/315 size tires on the rear? I have a 2021 F150 with 20x12 with 33x12.5 tires and -44 offset. Getting an X5 I am not too familiar with perfect offset to fenders haha.
Haters gonna' hate, ainters gonna' aint.
11-18-2021, 01:30 PM | #14 |
Rep 8,691
i believe 305 tires fit 10 - 12" wheel widths. 315 tires would need an even slightly wider wheel (?10.5 - 12.5"?). can always double check the specs on the website as they may vary between brands/models
11-18-2021, 01:37 PM | #15 |
Rep 256
Awesome, thanks. First time driving a BMW when searching for a new vehicle for my wife. Sold at first turn, so now I want to really capitalize on the grip that it has.
nZtiZia4652.00 |
11-18-2021, 01:47 PM | #16 |
Rep 8,691
my first bimmer as well. BMW's slogan "sheer driving pleasure" doesn't lie.
they take it seriously too! my vehicle has been at the dealer 1.5 months (and counting) due to a recall so I've had a 2-series loaner. i emailed that it hasn't nearly been the same 'driving pleasure' as my X5. the next day they called and said they've arranged for an X-series loaner swap. "the squeaky wheel gets the grease." lol |
yeetyeet391.50 |
11-18-2021, 02:13 PM | #17 |
Rep 256
Thats actually awesome!
11-18-2021, 03:00 PM | #18 |
Rep 198
Here are a couple pictures of my squared up 22's. Running Michelin Pilot Sport All Season 4 275/35-22 all the way around.
11-18-2021, 05:54 PM | #19 | |
Rep 463
Thanks for the photos. |
11-18-2021, 06:30 PM | #20 |
Rep 198
Side profile looks the same (except I like the sidewall of the new tire better). The staggered rears did stick out a bit further. If it bothers me, I will add a small spacer later.
11-18-2021, 06:55 PM | #21 |
Rep 463
Keep seeing common mentions that people prefer the Michelin sidewall. Any idea why? In photos the conti sidewall looks pretty nice but haven't seen any of these tires in person. Thanks again for the insights.
11-20-2021, 09:22 AM | #22 | |
Rep 1,449
-Yoda |
