01-06-2022, 11:59 PM | #2 | |
Rep 4,246
- Wired CarPlay sends 16b / 44.1-48 LPCM - Wireless CarPlay transcodes and sends 16b / 44.1-48 as compressed AAC-LC To listen to songs at sample rates higher than 48 kHz, you need an external digital-to-analog converter. For Hi-Res audio, I plug my Fiio M17 into the USB port and enable Vehicle mode and play Hi-Res DSD256 audio that's stored on my microSD. Otherwise I'll use my iP12Max or S21 Ultra to listen to downloaded Apple Lossless or Tidal Masters and connect to HK via USB.
01-07-2022, 06:39 AM | #3 | |
Rep 747
01-07-2022, 03:26 PM | #4 |
Rep 285
X5 doesn't have an auxillary analog input so external DAC will not work unfortunately unless you are able to hardwire an analog input to X5's audio system.
Also, we need the specs on X5's internal DAC as well as that may be a limiting factor when direct input through a digital player or storage media. Last edited by edtreo; 01-07-2022 at 03:36 PM.. |
cptcolo102.00 |
01-09-2022, 12:44 PM | #5 |
Rep 913
I've played a bit going between dropping flac onto the local hdd, streaming lossless from my phone, and wireless streaming (aac) and can honestly say that unless you're parked, the deteriorating impact of road noise, however little, on SQ is enough to reduce the difference in perceived quality to diminishing returns. I can hear it, but it's not a compelling enough difference to bother plugging my phone in.
2020 bmw xHippo, v8tt edition
