      05-30-2010, 09:50 PM   #23
supradriver
supradriver's Avatar
Drives: 11 328i
Originally Posted by bdkevoIX View Post
Do YOU know the difference between the two?
2jz-gte not only has stronger rods, lower compression pistons than 2jz-ge, it also has oil squirters, more efficient head, different intake mani, and other list of things that are much more suited for F/I application.
Tell me 1 STOCK 2jz-ge motor that made over 800whp?
Why would the 2jz-gte become such as sought after motor if 2jz-ge can do the same?
Yes I do know the difference between the two as I had one of the fastest bpu cars in the country a few years ago. I like how you get on everyone else about not sticking to the actual argument. You stated the that 2jz-ge is hella weaker that the gte. I am pretty sure the rods are the same unless your referring to the IS300 variant which has vvti. You are correct about teh lower compression, the oil squirters, the head, and the intake mani. However, like someone stated earlier oil squirters are not needed when building a motor. A lot of the high horsepower/big shop cars have used a GE block to make big power. I am a big fan of the GTE but there is no reason to make a ridiculous claim about the GE being "hella" weaker.
      05-30-2010, 09:57 PM   #24
Mnut
Germanized
Mnut's Avatar
Drives: e90 335i
any numbers as far as 1/4 mile or top speed? I have gone 9.90's with 560rwhp @135 on drag radials in my mustang 700 should be good for low 9's . I really liked my 04 IS300 the car is built very well ..
E90 335i blk/blk sport/step
JB3 2.0 pnp
BMS dci
Ultimate Racing DP's
Intercooler???
      06-01-2010, 03:26 PM   #25
b0bab0i
Drives: 03 TiAG z4 3.0i w/ hardtop
2JZ > 4G63
