ONR + dirty black car (56K warning)
03-02-2008, 11:42 PM | #46 |
Rep 278
Great info. I may need to check ONR and a sponge out.
I've read a lot of threads from detailers on this forum and many recommend wool mitts or other products that draw the dirt away from the paint & into the longer fibers. That sponge looks scary. I only imagine grit getting ground into the paint under the sponge. Do the detailers I've been reading on this forum (picus,david,sheer, etc) use sponges? I dont think my car is sponge worthy, I may need to stick with wool. At one point BK brought up negative parts of ONR mentioned on autopia. What are some of the more serious negatives about the product? What should I be looking out for or trying to avoid? |
03-03-2008, 12:17 AM | #47 |
Pirate
113
Rep 1,395
A grout sponge is a different animal in the sense it acts totally different when being used as a wash media. I have used grout sponges, wool mitts, sea sponge, MF, ect and with the right mind and sense, neither has contributed any more marring than the other, if any.
I would not be soo concerned as to what another detailer uses, but as to what works best for you. You can never copy the exact formula. I personally was scared to use it until I put my fear aside.I liek it because it rinses clean and uses less wash solution. I don't like the fact it doesn't get crack really well without using pressure and the lack of "give" when sliding it across the paint, like a wool mitt does.
03-03-2008, 12:58 AM | #48 | |
Smiling politely
167
Rep 7,931
Also, you can't tell from the photos, but my finish is good, but not perfect, so I intend to polish in the spring, anyway. As a result, I was probably braver than I would have otherwise been. Nevertheless, I haven't seen any new marring from the ONR and GS combo. The little marring I have is all old -- from a few "scratch the hell out of my car" auto washes over the past year or so , and some claying where I was a little too aggressive a few months ago. The reason I used a GS with ONR is because it rinses out so well. ONR tends to bind the dirt into the wash media more than soap does. A MF or wool mitt is harder to rinse free of dirt with ONR than when using regular soap (not impossible, just harder). The GS rinses out really easily. Interestingly, I thought the use of GS was something new. But if you search old Autopia threads, some detailers have been using them for years. I even read one older thread where someone recommended a GS inside a wool mitt as his wash media, because the GS holds so much water and soap in it. I'm not that hardcore or knowledgeable; I'm just a newbie who was trying it because others had spoken so highly of it. It worked fine and I'm going to continue using it for ONR. I have wool and MF "dreadlock" mitts I like when I wash with soap. As far as negatives on ONR, it mostly boils down to the fact that some people just don't like it. It's hard to get past the feeling you're washing with just water, and that puts some people off. Also, you can only clean what you touch, so you can't, for example, spray off the undercarriage. And it's harder to clean a muddy car, or clean the wheels and wheel wells, IMO, because you can't spray with a hose. I just ONR-ed again today, and I have to say, a warm water mix with ONR sure is better than freezing my butt off trying to hand wash in the cold.
E90 330i Black Sapphire 6MT | 991.1 C4 Platinum Silver 7MT
03-16-2008, 08:16 PM | #50 |
Free Your Heel
10
Rep 309
Great write-up and beautiful car!
I've been using ONR this winter and I love it. I pre-soak each area I work on using a garden sprayer loaded with the ONR wash mixture. The stuff beads and helps lift the dirt away from the paint before you wipe. I've been using an MF towel, but I may try the sponge. What I really like is that I can wash my car in half the time of the hose method. I may stick with this method year around. But any tips on getting dirt out of cracks? For example, it's hard to get the dirt that's on the door sill, below the hinge. That's where I miss having some water pressure.
2007 E90 335xi || Sparkling Graphite || Terra || Burl || 6MT || Premium || Sport || Cold Weather || Sirius || Comfort Access
ED May 2007 Report |
03-17-2008, 09:48 AM | #52 |
Rep 4,178
Drives: E90 325i, E82 135i
Their is a picture of the bottle on the first page of this thread!!
http://www.autogeek.net/optimum-no-rinse.html |
03-17-2009, 10:14 PM | #53 |
Rep 5,382
great write up. i'm buying a bottle right now!
03-17-2009, 11:04 PM | #55 |
Rep 1,074
Great write up BK. I might just have to order a bottle myself. This seems like a good, quick way to do some weekly washes in the summer between 'normal' washes. Sometimes I just have a little layer of dust that really doesn't require a full wash but it still bothers me, so this seems like a good solution for those weeks.
'06 325i - AT (bite me!) - Jet Black - Black leatherette - Aluminum Trim - Blacklines - 189's - M3 Spoiler |
03-18-2009, 12:34 AM | #56 |
68
Rep 382
It doesn't scratch, it only left swirl marks. My friend was arguing with me on how swirl marks were already there on his car before using ONR. Few months later, after his car was polished, I asked him to do a demonstration and BAM there were light swirl marks! Shine a spot light directly on the paint and you will see what I'm talking about.
03-18-2009, 09:25 AM | #57 | |
Smiling politely
167
Rep 7,931
ONR won't swirl your car, provided you use soft wash media (like the Lowe's grout sponge I used) and use it gently, rinse the wash media often, and so on. I have a black car and polish a few times a year, using halogens and with careful examination of the paint. ONR does not swirl any more than "regular" washing and drying, which is to say very little or not at all when done correctly. I don't sell ONR or have any interest in whether others buy it. I'm just saying it's easy to be skeptical of it -- I certainly was. However, I was willing to give it a try based on positive reviews from detailers I respect. My experience with it has been terrific. I've been using it over a year now (see the date of the first post in this thread), and have nothing but praise for it.
03-18-2009, 01:33 PM | #59 | |
68
Rep 382
I'm not against ONR, I'm in fact, a big fan of it. I just want to put a true word out for others to know. Consider pros and cons before you make the purchase and keep in mind, a proper wash is always the best. Also with polishing, taking swirl marks and scratches off is a simple process, anyone can do. Properly seal and protect the paint afterward is hard. If you have too much fun polishing the car a few time a year, soon, your clear coat is all gone and your paint is worse than one with no polishing done. |
03-18-2009, 02:14 PM | #61 |
Rep 465
I gotta try some ONR I just bought 5 Pro Line sponges from Lowes, it looks like your car came out great
"Barzini is dead. So is Phillip Tattallgia. Moe Green. Slacci. Cuneo. Today I settled all family business so don't tell me that you're innocent. Admit what you did"
03-18-2009, 02:40 PM | #62 |
168
Rep 10,406
Drives: N/A
is the car JB?
03-18-2009, 04:18 PM | #63 |
Rep 6,594
According to BK's signature, the car is Black Sapphire.
I bought a bottle of ONR last week after reading a countless number of articles/threads praising it. Haven't used it yet, but I'll give it a try with those GS sponges from Lowes this weekend. May use a two bucket system instead, but it's tough to argue with BK's method and results. Looks fantastic.
X7 LCI // Incoming C7 ZR1 ZTK // Sebring + TRX // Hydro + Raptor Gen1 Roush // Tuxedo |
03-18-2009, 04:48 PM | #64 | |
168
Rep 10,406
Drives: N/A
03-18-2009, 05:29 PM | #65 | |
Smiling politely
167
Rep 7,931
I should add that for cars with heavier dirt, several of us who use ONR will take care of the heavy dirt first -- for example, drive through a "no touch" spray wash, then ONR. Or pre-treat panels with a spray bottle of ONR solution (just dunk the bottle in your bucket) prior to cleaning that panel. I don't get the reference to polishing being easy but sealing being difficult. Frankly, I think it's the other way around -- paint prep being where the work should be focused and where expertise makes a difference. Also, as far as polish thinning the CC, unless you're compounding, it's a negligible amount. You can use a light polish twice a year for a dozen years without concern.
03-26-2009, 09:29 AM | #66 |
Close to bein Bannned
106
Rep 5,068
+1 on ORN I used this stuff yesterday and it's awesome!
