12-01-2022, 06:08 PM | #1 |
152
Rep 328
X5M Moonroof - wind noise
Hi Guys,
First time SUV guy here and picked up my 23 X5M Comp few months ago. I'm noticing wind (light howling noise) from the moon roof of the car. Is this something "normal" or would this be a fit and finish issue? The noise is always at highway speed and def more noticeable now in the cold months. Don't think I heard it back in October when it was still warm out. Edit: X6M (Like I said, new to this whole suv thing )
Wife: X6M Mistress: S1000RR
12-01-2022, 06:45 PM | #2 |
Self-Deprecating Narcissist
7266
Rep 6,561
You can attempt a reset on your own with the interior switch to see if it sets itself properly.
01-09-2023, 06:20 PM | #4 |
152
Rep 328
Just updating for anyone experiencing this in the future. After few visits to the dealer:
1st visit: Changed the outer seal of the moon roof and it actually made the noise worse. 2nd visit: Found a 10mm gap in the inner seal and they changed it. No more wind noise.
01-02-2024, 03:03 PM | #6 |
Rep 209
I got the same issue now, hearing wind noise from the moon roof, once I open the sun roof , it disappears. I will check with the dealer.
X5 xDrive 40i 2022 / Phytonic blue / Tartufo / Carbon Fibre
01-02-2024, 07:44 PM | #8 |
Rep 1,082
I had the same issue when I purchased brand new (back in 2019) a X3 M40i, the doggone rubber seal had "shrunk" almost 1/2 inch. Was replaced by BMW dealer under warranty, of course.
2021 Jeep Grand Cherokee SRT Black 2006 Ford Mustang GT Convertible (car-show car) |
01-21-2024, 08:26 PM | #9 |
17
Rep 31
Same issue here. This is from my 23 X5 M50 after about nine months. I try to avoid dealers as much as I can so I replaced it myself for $40. Pretty easy install that only took about 15 minutes. The replacement piece was actually a bit longer than what was needed so I had to cut it to fit correctly.
Tejas1836996.00 |
01-21-2024, 10:05 PM | #10 | |
Rep 825
Sunroof Frame Gasket - BMW (54-10-7-485-602)
Two is One and One is None
MADBMWX5MC742.50 |
01-23-2024, 08:50 AM | #13 |
Rep 8,815
I ordered this part which shows replaces the part number above
Seal Glass Roof Front 548520 - BMW (54-10-5-B32-973) Genuine BMW Seal Glass Roof Front 548520 - Part Number 54-10-5-B32-973 Replaces 54-10-7-493-155 The strange thing is that my car always had the small gap on the sunroof ever since it was brand new so makes you wonder if it was meant to be there to release any pressure build up or if it was part defect. I feel like most people posted that they had the same gap in that spot. Alan
01-24-2024, 07:29 PM | #14 |
Rep 8,815
Just got the part in today and swapped mine out. simple install but takes alittle time to make sure its on securely. 15mins sounds about right.
The updated part was also a bit too long so i snipped maybe .25" off at the end with a regular pair of scissors. I had noticed a small whistling sound after i installed my ski racks and now its completely gone. Worth the $42 bucks.
01-24-2024, 07:30 PM | #15 | |
Rep 3,933
01-24-2024, 07:33 PM | #16 |
Rep 8,815
Weird. I know my car had it since new because I noticed it when I was applying ceramic coating up there. All good now. The new trim not only fills in the gap 100% its also thicker compared to the old one which got flattened over time so the seal should be better regardless now.
01-28-2024, 04:50 PM | #18 |
Rep 1,082
Well heck, you made me look. I too have a 1/4 inch gap on my 2023 X5MC...off to the dealer for fix
[url=https://flic.kr/p/2pv1B85]
