F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > FAQ: BMW iPhone 5 and iOS 6 Functionality, Bluetooth and Y-Cable Overview
Extreme Powerhouse
      10-15-2012, 12:57 PM   #1
Jason
Administrator
Jason's Avatar
Drives: F80 M3
Exclamation FAQ: BMW iPhone 5 and iOS 6 Functionality, Bluetooth and Y-Cable Overview
BIMMERPOST NEWS
106
COMMENTS
Apple recently introduced the new iPhone 5. There are three key differences between it and earlier iPhone models that affect its integration in BMW vehicles. First, the physical dimensions of the body of the new phone are thinner and longer compared to the iPhone 4/4S. Second, the iPhone uses a new 8-pin connector in place of the traditional 30-pin connector used on all other iPhone variants as well as iPod touch and iPod nano. The third is the elimination of the analog video signal.
Taken together, the result is:
1. iPhone 5 is not compatible with any of the current snap-in adapters available through BMW.
2. The PlugIn feature as a means of accessing one’s music library is not available on the iPhone 5. (Owners are still able to access their music library using a USB cable, see details under “Will I need an adapter to use my iPhone5?”.)
3. Also, watching videos stored on the device, on the car’s screen while parked is no longer possible.
FAQ
Below is an FAQ regarding the use of iPhone 5 and iOS6, as answered by BMW:
Can I connect my phone via Bluetooth to make phones calls, see my contacts and play music?
• Yes.
Can I still play music from my iPhone 5 in my BMW?
• Yes, via the External Devices menu in iDrive.
Will I need an adapter to use my iPhone 5?
• This depends on the options in the vehicle:
◦ No, if you currently use an Apple "white cable" to connect your iPhone to your vehicle. In this case, all you need is the new Apple Lightning cable, included with your iPhone 5. (See our member's DIY guide for creating a cradle and integrating the lightning cable)
◦ Yes, if you currently use a Y-Cable to connect your phone. In this case, you will need a "Lightning adapter" to connect your iPhone 5 to the Y-cable. (See "USB vs. Y-cable" on below to determine when a Y-cable is needed for MY 13 vehicles.)
◦ The "Lightning adapter" is an adapter available via Apple to convert the old 30-pin plug to the new 8-pin connector or "Lightning cable". It is already on sale by Apple and retails for $29.99 (for the adapter) or $39.99 for the adapter cable.
Can I use PlugIn and/or play videos from my iPhone 5?
• No, the iPhone 5 Lightning connector does not support analog video, therefore making the PlugIn feature and video playback incompatible.
• PlugIn and video playback are still supported when using an iPhone 4/4S with iOS 6.
When will the iPhone 5 Snap-In Adapter be available?
• BMW's official word on this is that there is currently no timeline set for the release of the iPhone 5 Snap-In Adapter, but as we recently reported, our sources indicate that its currently in developemtn and to expect it sometime around June 2013.
Is "BMW apps" compatible with iPhone 5 / iOS 6?
• Yes, owners with iOS 6 (incl. iPhone 3GS/4/4S/5) and a "BMW apps" equipped vehicle can continue enjoying the same great app integrations, just as they did with iOS 5.1. This includes Pandora, MOG, Aupeo, Stitcher and BMW Connected.
• Pandora is still not compatible with the New Navigation Professional System (SA609) vehicles, but an update is expected from Pandora by November 30, 2012.)
Can I use Mobile Office with iPhone 5 / iOS 6?
• With the release of iOS 6 (incl. iPhone 3GS/4/4S/5), Mobile Office is now supported for Text Messages and iMessages. This is available in cars with option code 639 / 6NL "BMW Assist with Enhanced Bluetooth". Owners will be able to see their text messages / iMessages on the screen,
and can have them read aloud. (Read-out of messages also requires Navigation.)
• Not all of the Text Messages / iMessages on the phone will be displayed in the vehicle. Only new messages received while the phone is connected to the vehicle will be available in the vehicle.
• Owners will have to configure their phone as follows to activate this feature:
1. Pair the phone to the vehicle as normal.
2. Under "Settings" and "Bluetooth", press the blue arrow to the right of the paired vehicle:
3. Then turn on "Show Notifications":
4. Also,notifications must be turned on for "Messages" as well:
5. Owners then have to reconnect their phone to the vehicle. This is done by scrolling over the paired phone in the vehicle’s “Bluetooth” menu and pushing the iDrive controller.
6. Returning a phone call via the displayed text message / iMessage is not possible. Owners should either dial the number directly or select a contact from their address book using iDrive.
Y-CABLE / BLUETOOTH
USB vs. Y-cable:
USB is offered standard on all 2013 BMW models, but the available functions differ based on vehicle equipment. Audio playback through the USB port is always included, but may require the Y-cable accessory in combination with an iPhone / iPod. The BMW Apps features are only available in combination with option 6NR "BMW apps". Some of the app features are accessible using the Apple cable, but video playback is only possible with Smartphone Integration (6NF) in combination with the appropriate snap-in adapter.
* Plug-In is not currently compatible with the new Navigation Professional system (SA609); a fix is expected later this year.
The Y-cable is needed unless the vehicle is equipped with 639 or 6NL "BMW Assist with Enhanced Bluetooth and USB", which is standard equipment on all MY 13 5 Series, 5 Series GT, 6 Series, 7 Series, X5 and X6 models. On most other MY 13 models, 639/6NL is offered in combination with 609 "Navigation system" and/or in the Technology Package and/or as an option. See the chart below for more details about each model’s Y-cable dependency.
Bluetooth:
Bluetooth comes standard on all 2013 BMW models, but again, the available functions are dependent on vehicle equipment. Please refer to each vehicle’s ordering guide to determine which options are available.
      10-15-2012, 02:10 PM   #2
1230vani
1230vani's Avatar
660
Drives: G05 40i LCI
Sound is better via snap-in adapter. Thanks for posting FAQ.
      10-15-2012, 02:10 PM   #3
TurboSpecC
Bavarian Wolverine
Drives: 2015 428 Gran Coupe
It took me a few years, but I finally understand which cables allow you to do what in each model/model year. This is very helpful for the newbies, though!
I ended up keeping my iPhone 4 to use as a music hard drive in my 2009 M3, and with iTunes Match turned on, it automatically syncs my music and playlists with all my other devices/iTunes when I park at my apartment and the iPhone 4 sees my router. Alternately you can use your 5 as a Wifi hotspot to update the music/playlists on your 4 if you continue to use it as a hard drive.
Euro Delivered: 15 428i xDrive Gran Coupe M-Sport EBII
Past: 12 VW GTI, 09 E93 M3, 07 E92 335i, 06 WRX STI
      10-15-2012, 02:28 PM   #4
Bomb617
Drives: 2011 Alpine White 535i M-Sport
Anyone experience both phone call and audio at the SAME time when I pair my iPhone via bluetooth instead of using the apple cable? I mean I was listening to audio via bluetooth and when I receive phone call...I will hear both sources at the SAME time in the car...caller seems to get my voice only from the other end...anyone?
      10-15-2012, 03:16 PM   #5
dc_bmw
Netherlands
15
Drives: BMW 330e
Great summary!
Unfortunately the procedure for showing text messages doesnt work for a iPhone 3GS with iOS 6 in a F30 equipped with 6NL and 609.
The phone does not show the option " Show notifications" under the paired device". It does show "Synchronize contacts" and that works fine.
Anybody with different results?
(Car bt software updated using upd1005.bin)
      10-15-2012, 03:49 PM   #6
G2G
Sold: E46 330CI, E90 320dA with 270000km
G2G's Avatar
Austria
9
Drives: 1M
2015 BMW 118d  [0.00]
2011 BMW 1M  [10.00]
Im getting my BMW 1M (production date - 04.2011) next week!
It has Navigation Profesional.....but i have no clue how much I will be able to do with my iPhone...?!
      10-15-2012, 04:21 PM   #7
Dark_Knight_335
Came to the N55 Darkside
Dark_Knight_335's Avatar
Drives: 2011 335 E93 M-Sport
Can't shuffle via the USB cable, which sucks.
Bluetooth is flaky too. I have had to forget my BMW Bluetooth and repair to get Bluetooth audio more times than I can count (this is most likely an iOS 6 issue) and occasionally the audio crackles too via Bluetooth.
Ah the price we pay for new tech...
      10-15-2012, 04:26 PM   #8
Bayern1
Drives: 2015 BMW 550i
I can't pair my iPhone 5 with bluetooth. Had no trouble with 4. 2012 335is.
Does anyone else have the same problem?
      10-15-2012, 05:23 PM   #9
mrringodi
Drives: e90 M3
Will the iPhone 5 work with an 08 m3?
      10-15-2012, 05:34 PM   #10
pbw
pbw's Avatar
United Kingdom
248
Drives: bmw 240i xdrive g42
Paired my iPhone 5 via Bluetooth on my MY2012 Z4 at the weekend. Phone book, telephone & playing back music works a treat. Will wait for a Y cable.
      10-15-2012, 07:13 PM   #11
b33g33
Give '///M' Hell!
b33g33's Avatar
Drives: Einser Rex
iPhone5 works great on my 1M with the lightning cable. I never used the video out before so I can't comment on that but MOG, Sticher, BMW Connect and BMW Remote work without any issues.
Even Siri works fine over BT (You can turn this on/off on the phone itself).
Also, congrats on your 1M. Don't forget to come say hi on the 1M board.
The 1 series M is the most badass, coolest, sickest BMW to debut since the 1988 M3. The E30 M3 finally has a successor. Please welcome the stupidly fast, wickedly tempered, awkwardly named, possibly perfect little son of a benchmark - Automobile Magazine, August 2011
      10-15-2012, 08:30 PM   #12
jtuds
71
Drives: 335rwd Dinan S2
I dont think we can even get navigation professional in Canada.
      10-15-2012, 10:22 PM   #13
mmzcee
Drives: Silverstone 2001 M5
How bout an update for ip5s bigger screen on the bimmerpost app?
      10-16-2012, 01:00 AM   #14
zamboni
I want to drive a Zamboni
zamboni's Avatar
Drives: 13 E93 M3 18 F80 M3 16 K71
16 K71 F800GT  [10.00]
2018 F80 M3  [10.00]
2013 BMW E93 M3  [10.00]
Having trouble with white cable on my 09 E82 can only charging but can't connected to USB on idrive. With MY12 E93 had no problem at all.
18 F80 Imola Red 6MT
16 K71 F800GT Montego Blue
13 E93 M3 Melbourne Red
2000 E46,2006 E90,09 E82,13 E93 328i,14 F30 335i,18 F80 M3
My next vehicle would be a Zamboni
      10-16-2012, 01:11 AM   #15
rallybull
rallybull's Avatar
Drives: F30 335i w/PPK
I still can't get messages and emails to work with my iphone 5 and my f30 335i
      10-16-2012, 07:28 AM   #16
Mr Kleen
teh porcupine
Mr Kleen's Avatar
South Korea
97
Drives: 2020 Tesla 3 LR AWD
2013 BMW X1  [10.00]
Question
Any way to have txt messages display without navigating the iDrive to the office menu, then the phone menu, then the message menu? I would like the message to display over what ever iDrive screen I happen to be on at the time. Navigating all those menus to get the txt message sort of defeats the purpose.
I have a 2012 135i with iDrive and NAV, and an iPhone 4 with iOS 6 installed.
      10-16-2012, 09:01 AM   #17
panoz7
Drives: 135i
Sorry for the potentially stupid question, but what does PlugIn actually mean?
I have an iphone 6 with the y-cable. If I get the thunderbolt adaptor will I still be able to browse through the songs on my iDrive screen, or is that what PlugIn means?
      10-16-2012, 09:12 AM   #18
SamS
Drives: Tesla M3 Perf + '18 X3 M40i
PlugIn is the interface shown below. You need 6NR option.
Dang you have the iPhone 6!
      10-16-2012, 09:24 AM   #19
panoz7
Drives: 135i
Thanks. So I should still be able to browse files, I just won't be able to see album art or use the iphones interface on the screen (which I wasn't able to do before anyway).
Shhhh... don't tell anyone else.
      10-16-2012, 10:24 AM   #20
jphughan
jphughan's Avatar
Drives: '16 Cayman GT4
If you use a Y-cable, that may be true (although I think those cars use analog audio through the snap-in too, but I'm not sure). But if your car can pull audio using just the normal white USB cable, then sound quality should be identical since it'd be digital audio in either case.
Nope, music always stops when a call comes through. How odd.
I have Show Notifications, but displaying texts and emails is still finicky. Maybe try deleting and re-pairing your phone since you installed that BT update? It may still not work (expectation is that it's an iOS bug since it worked on early iOS 6 betas), but that should at least get you the Show Notifications option.
Shuffle absolutely works when connected to USB. Go to External Devices, press the Option button, and choose Random. The issue is that that setting isn't maintained after you turn the car off or disconnect the device (can't remember which), so you have to keep enabling it. As for BT audio, the only issues I've seen are occasionally losing the ability to jump between tracks (though audio continues working) and yes occasional crackling, but those are rare and actually they haven't happened at all since installing iOS 6 on my phone and the latest BT software for the car.
Can't imagine why not.
Nope, that's a limitation of iDrive's interface. Easiest workaround is to assign one of your shortcut keys to the Messages area. However, you DO get an envelope icon when you have a message waiting, which appears either along the top edge of the interface (for most iDrive pages) or in the gray box in the upper-right corner of the map area when you're in Nav view, so at least you don't have to check the Messages area proactively.
      10-16-2012, 11:03 AM   #21
Mr Kleen
teh porcupine
Mr Kleen's Avatar
South Korea
97
2013 BMW X1  [10.00]
Not the answer I was hoping for but a good idea nonetheless. Thanks!
      10-16-2012, 02:43 PM   #22
Sedan_Clan
Law Enforcer
Sedan_Clan's Avatar
Brazil
25170
Drives: '22 Chalk Gray Porsche C2S
Great info!
Tags
bmw ios 6, bmw ios6, bmw iphone, bmw iphone 5, bmw iphone 5 adapter, bmw iphone 5 bluetooth, bmw iphone 5 cradle, bmw iphone 5 snap in adapter, bmw iphone 5 y-cable, bmw iphone adapter, bmw iphone snap-in adapter, bmw iphone5, bmw iphone5 adapter, bmw iphone5 bluetooth, bmw iphone5 cradle, bmw iphone5 snap in adapter, bmw iphone5 y-cable, ios 6 bmw, ios6 bmw, iphone 5 bmw adapter, iphone 5 bmw cradle, iphone 5 bmw snap in adapter, iphone bmw adapter, iphone bmw snap in adapter, iphone5 bmw adapter, iphone5 bmw cradle
f30post
