08-11-2023, 12:38 AM | #2 |
Rep 3,686
It has curb weight of 2.4 ton. You left a bit more than half the weight at once, so I would say a 2 ton jack will be minimal, I would get 3 ton. Car clearance is high, so no need to get low profile jet. Not much requirement. Anything 3 ton should work, home depot, oreily, harbor freight, costco ... remember, you should never just use jack to support he car, you lift the car, put jack stand under.
2022 G05 B58/PHEV
+ a few very old BMWs |
08-11-2023, 10:51 AM | #3 |
Rep 1,009
Big fan and highly recommend AC Hydraulic DK20 and splurge and get the padded jack pad while at it. My only issue is the wheels on these...stupid O ring on the wheel.
Otherwise, a Harbor Freight Super Duty Jack is great |
08-11-2023, 11:25 AM | #4 | |
Rep 415
Mark
2022 X5 45e - Wife's daily driver
2023 GX460 - My daily driver 1988 4Runner on 40's - Off-road trailer queen 2001 PSD Excursion - The slave that drags the queen |
08-11-2023, 12:25 PM | #5 | |
Rep 4,354
https://www.amazon.com/Alltrade-6409...zcF9hdGY&psc=1 I also have a couple of floor hydraulic jacks. I place one floor jack under the rear passenger or drivers jack point, lift high enough to get the front jack point a couple of inches higher but still with the tire on the ground, slide this jack stand under the front jack point and then let the floor jack down and remove it. I then jack up the jack stand till I can get the second jack stand under the rear jack point. Then I simply lift both front and back high enough to get the tires off the car. Depends on why you're jacking up the car but that's how I do it for tire rotation, wheel cleaning, etc. I also use them when changing the engine oil. . |
LuckyBrand1354.50 |
04-08-2024, 12:50 AM | #6 | |
Rep 5
04-08-2024, 10:32 AM | #7 | |
Rep 3,686
If you are reasonably careful putting Jack stand at the right place, and chock the car, it is highly unlikely the car will slip. The top of this Jack/stand is not much different from normal Jack stand
2022 G05 B58/PHEV
davchr80.50 |
04-08-2024, 05:02 PM | #9 |
Rep 4,354
04-08-2024, 10:00 PM | #10 |
Rep 61
Where do you place the jack stand with the floor jack occupying the jacking point? I’m guessing as close to the jacking point as possible so that you can ensure the stand can take the load if the floor jack should fail. Your thoughts?
1975 3.0Si E3 Jade Green
1985 535i E28 Schwarz 2002 M5 E39 Carbon Blue 2016 M4 Convertible F83 Alpine White 2020 M5 Competition F90 Donington Grey |
04-10-2024, 07:55 PM | #11 |
Rep 3,937
There is a flat spot under the center of the front end where a floor jack can lift the front end up so jack stands can be placed under the front lifting pads. In the rear, place floor jack pad under the rear differential housing and lift.
LuckyBrand1354.50 |
04-10-2024, 08:16 PM | #12 | |
Rep 4,354
https://g05.bimmerpost.com/forums/sh....php?t=1824810 |
