09-17-2019, 12:23 PM | #23 |
Registered user
78
Rep 422
Drives: G05 3.0d MSport / F23
Spotify integration sounds interesting. Would you please post a couple of pics of where and how that looks.[/QUOTE]
It took two calls to the BMW CONNECTED team to get Spotify App to reappear, apparently it is a known issue with the latest connected drive app. Hopefully it will stay in the menu. Will post some pics when I can work out how... Last edited by speuk; 09-17-2019 at 12:39 PM.. Reason: Attaching images |
LexxM31697.50 |
09-17-2019, 01:17 PM | #24 | |
Rep 2,609
Not sure if I missed it stated, but on iOS or Android? Update my own answer: you've previously indicated Spotify on Android for this example. Thanks.
09-17-2019, 02:05 PM | #25 |
Registered user
78
Rep 422
Yes I'm using an Android device but works the same with ios if you don't want to use Car Play. Set up is the same as o365 when you first log in it presents you with a QR Code to scan which then logs you into your Spotify account
marcosg24.50 |
09-17-2019, 04:19 PM | #28 |
Registered user
78
Rep 422
09-17-2019, 04:21 PM | #29 | |
Rep 90
Is it only available in 07/2019.47 or also in earlier versions 07/2019.39. |
09-17-2019, 04:30 PM | #30 | |
Registered user
78
Rep 422
I had 11/2018.57 before so I'm not sure when Spotify was introduced. Best to speak to the connected drive team. |
marcosg24.50 |
09-19-2019, 11:52 AM | #31 | |
Rep 106
Interesting. I got .53 today in UK and there's no sign of BMW Experience Apps. I read somewhere they may update overnight, so will update if this happens.
09-19-2019, 01:40 PM | #32 |
Rep 430
09-20-2019, 12:50 PM | #33 |
Member
893
Rep 2,029
Drives: 2019 X5 40i M Sport
Garage List 2023 BMW M2 (HEA) [10.00]
2021 330i xDrive [0.00] 2019 G05 X5 M Sport [0.00] 2017 Jeep Grand Che ... [0.00] |
Had the X5 updated to 07/2019.47 and I finally got the features I was missing such as Experience Modes and Caring Car. One thing to point out is that if you had coded the car previously using the BimmerCode App that coding gets erased and the only thing that becomes available is the ability to turn off the Auto Start Stop.
2019 X5 Alpine White M-Sport
Software Version 11/2022.31 2023 M2 (HEA) Brooklyn Gray 2021 330i XDrive Alpine White M-Sport |
09-20-2019, 02:27 PM | #34 | |
224
Rep 350
09-20-2019, 10:11 PM | #36 | ||
Member
893
Rep 2,029
09-23-2019, 08:55 AM | #37 |
Rep 106
09-23-2019, 09:34 AM | #39 |
13171
Rep 19,660
09-23-2019, 03:04 PM | #40 |
Registered user
78
Rep 422
09-27-2019, 02:22 AM | #41 |
270
Rep 376
Picked up my G05 after the latest update to .53. I reset iDrive but still don't see the Spotify app. Has anyone who has it had to do anything to get it to show up? Thanks!
09-27-2019, 02:50 AM | #42 | |
Guest
Rep n/a
Drives:
In Media, check the 'Personalise Menu' option or similar. Do you have a checkbox for Spotify? If yes, then you need to start the Spotify app on your phone, make sure Car view is enabled in the app, then connect to the car via BT. If Spotify doesnt appear, you can try an Update Apps and Services from the Apps menu. If it still doesnt appear contact the Connected Drive department and ask them to fix it. Or use CarPlay if thats an option. Assign a shortcut button to CP in Media. It now defaults to last used media app with iOS 13.x e.g. Spotify |
mnewnam269.50 |
09-27-2019, 03:17 PM | #43 | |
Registered user
78
Rep 422
