04-30-2014, 05:10 PM | #67 | |
Rep 513
04-30-2014, 05:29 PM | #68 | |
Rep 7,640
Having mine installed today. Will speak with the tech.. Sounds too easy.. |
04-30-2014, 05:36 PM | #69 |
1236
Rep 1,963
Any pics of the install? If I can do this I will order these parts today!!!!
04-30-2014, 06:47 PM | #70 | |
European Editor
10616
Rep 22,992
You really need some hands and lots of patience to do this install from above only. Also have a few really LONG and thin needle nose pliers comes in handy. Be sure to have some extra c clips on hand, yellow washers for the linkage, high temp grease, a new plastic bearing(bushing for the new lever) and the SS lever itself.
05-01-2014, 02:10 AM | #71 | ||
Rep 7,640
@Sebilad , man, you must have small hands and some very fancy tools to remove that lower clip.. Its a mere impossibility to remove that clip from inside the cabin, without removing the heatshield from the under carriage.. |
05-01-2014, 01:21 PM | #72 |
Rep 5
Yeah all from inside the cabin, I'm an experienced BMW technician so may have the upper hand! But no special tools, quick pull of the gear knob and gaiter, removed the big grommet, twisted the bush out with a pair of needle nosed pliers, slipped the selector into 1st which moved the lower section to the bottom right position which gave me access to the clip. Extendable magnet on the clip down one side, twist with a screwdriver then pulled it up with the magnet. Removed the shift lever and put back together in reverse order!
Slow and steady to align the clip and hey presto! Short shift linkage, alcantara gaiter and performance gear knob! Highly recommended upgrade I love it! |
05-01-2014, 05:13 PM | #73 | |
Rep 7,640
05-03-2014, 06:13 AM | #74 | |
70
Rep 359
The BMW dealership in Singapore did the same, installing the SSK from the top.. |
06-05-2014, 07:40 AM | #75 |
Rep 180
The SSK is not able to order any longer. Tried to order in Sweden and through dealer in US. Same answer: not able to order it due to no longer in prodduction. What to order instead ?
/Janne
BMW Alpina D5S Touring 2018
BMW Alpina B5 Edition 50 2015 /Janne |
06-05-2014, 09:18 PM | #76 | |
247
Rep 1,585
Drives: 2011 VO 1M
Garage List 2010 Porsche 911 GT3 [10.00]
2021 BMW X5 SD40i [0.00] 2023 Toyota TRD Pro [0.00] 2011 BMW 1M [9.83] 2014 Ford Raptor [0.00] 2005 Ariel Atom 2 [0.00] 2008 135i SOLD [10.00] |
http://hpashop.com/Rogue-Engineering...ssk-e82-1m.htm I will probably go this route, I had the BMW SSk in my 135i; had MUCH shorter throws, however, I did not like the engagement. Felt too notchy in some gears.
///1M #643 of #740
06-10-2014, 02:08 PM | #78 |
Rep 173
FYI, GetBMWParts reported that the BMW SSK parts (not sure about the actual kit) you would use for the 1M are in stock and ready to ship as of today.
06-10-2014, 03:26 PM | #79 |
Rep 3,070
Just a reminder though: they do not ship internationally; a re-shipping arrangement must be done for international buyers.
"The mark of a great car is one whose overall competence exceeds what you should expect from its individual components and the 1M does just that", Chris Harris.
BMW 1M-SOLD-: TECH: Evolve Race+N55mids, Evolve IC, Michelin PSS, ER cp, aFe filter, CDVx, Vorshlag camber plates, BMS OCC EXTERIOR: trunk spoiler, blacklines, black grills, IND goodies INTERIOR: Alcantara steering wheel, steel pedals, custom mats, MPower e-brake. |
06-11-2014, 10:40 PM | #80 |
Rep 547
Has anyone else noted that in the 1m the SSK lever actually angles slightly more to the right than stock (at least for RHD cars), closer to the driver? Almost like it doesn't stand vertically, but leaning to the right. The increase in height of the shifter is not noticeable, but the change in position is. Surprising as I don't remember this happening in my old 135 n54. Different gearbox I guess. I actually prefer this ergonomically, but the notchiness takes some getting used to.
06-12-2014, 02:34 AM | #81 | |
European Editor
10616
Rep 22,992
The N54 use a different gear box. 1M's and N55's use the very same gearbox. That's why the (full)Performance SSK doesn't work on a 1M. But using just the Perf SSK lever DOES work on a 1M.
06-12-2014, 05:27 AM | #82 |
Rep 547
What do you guys think? Has the lever been installed back-to-front? The first pic is in neutral, the second pic in first gear.
Any chance someone with a 1M/SSK can post a similar pic to mine in neutral to compare? If it has been installed wrong way around, it still works as the shift is so short. But just doesn't sit right to me (and doesn't feel right on 2-3 change). Shift though is awesome, and less notchy with each change. |
06-12-2014, 06:34 AM | #83 |
Rep 547
06-12-2014, 06:55 AM | #84 |
Rep 547
I won't say. Only cost $80 BUT not angry. Just annoyed to have to get it pulled out again. If the bearing gets stuffed in the changeover, they better put in a new one.
06-12-2014, 04:56 PM | #85 | |
European Editor
10616
Rep 22,992
I don't know IF this video with help you... but here are the shifter throws on my BMW Perf SSK on my 135i (N54)... Dack
06-12-2014, 07:07 PM | #86 | |
Rep 7,640
When Pete@Advan installed mine, he informed me that he has had to reverse an install, just like yours, that was a DIY job.. |
06-12-2014, 10:16 PM | #87 | |
Rep 547
Getting fixed next week. |
06-13-2014, 04:19 PM | #88 |
Rep 173
For some reason I received a 25110434219 performance shift lever which looks to be for the E90 130i instead of the 25110434217 performance shift lever for the 135i. Does anyone know if first part # will still work in the 1M; it looks to have very slight knee (bend) with a minor tilt back instead of the z bend between the ball and handle I saw in the posted pics?
