10-23-2023, 02:23 PM | #1 |
Rep 36
Nail in tyre...Ugh
Was greeted to a low pressure warning this evening upon returning from work.
Drove home very carefully watching the Vehicle Status screen and pressure on relevant tyre didn't fall below 1.1 Bar. Got home safely and upon further inspection spotted a nail. This is a really silly question but assuming pressure didn't fall assume I have Run Flats ? I checked the they're wall and can't see it stated explicitly. If I do, can it just be a standard puncture repair ? Car is a new 50e, only 400.miles on it |
10-23-2023, 02:34 PM | #3 |
Rep 408
Assuming that the nail in not close to the sidewall and that the sidewall didn't get damaged on your drive back, sure. Not all repair shops may be willing to patch but it should be patchable.
It would be good to re-inflate the "Tire" some before driving out to the repair shop to reduce any chance of sidewall damage. |
eelnoraa2058.00 |
10-23-2023, 03:20 PM | #5 |
199
Rep 328
Just buy a tire repair kit and DIY. It's easy and a good skill set to have with RFTs.
Some people say not to do it, but the worse that could happen when it's not in the sidewall is that you still have a slow leak (or perhaps a slightly faster leak). |
X6ix GTA142.00 |
10-23-2023, 03:33 PM | #7 |
Rep 3,708
The nail location is repairable. As long as you didn’t drive it “flat”, it is entirely ok to repair tire. Same applies for non RFT
2022 G05 B58/PHEV
+ a few very old BMWs |
10-23-2023, 04:03 PM | #9 |
Rep 910
While you can do a DIY kit a professional repair (which unmount the tire, apply the plug and also apply a sticker patch from the inside) would be better. If you live in State side Discount tire/America tire and some chain would do it for free.
eelnoraa2058.00 |
10-23-2023, 04:51 PM | #10 |
Rep 6,881
A plug installed from the exterior is considered a temporary patch...the industry only considers one done from the inside as a permanent repair.
The issue is, the tire repair shop cannot tell if the vehicle was actually driven while it was flat or not on a RFT unless it was abused...then, it could be full of rubber chunks, which is pretty obvious. So, from a liability standpoint, many will not patch a RFT. But, if it was not driven flat, like most tires, depending on where the puncture is, it can be repaired. You might have to search around for someone willing. During the first year, direct from Pirelli, they will replace a RFT with a puncture if the tread wear is not excessive. The BMW dealer would want you to buy a new tire but a Pirelli dealer would replace it for free. |
10-23-2023, 05:01 PM | #11 | |
Rep 4,416
That said, its better to pull the tire from the wheel and patch on the inside either in combination with a plug or just the patch but I've never done it that way since all mine happened while I was on the road and I needed to make the repair and get back on the road. The only trick is to be sure you don't push the plug too far such that it goes into the air space of the tire and not fill the hole the screw made. The remaining plug that is left sticking out of the tire can simply be trimmed flush with the tread with a razor blade and Bob's Your Uncle. Anyway, here is a pic of a typical plug kit. Use plenty of glue, it initially acts as a lubricant to get the plug in place and then it fills gaps and becomes one with the tire. Instructions should be included. The round black disks are for optionally patching the inside of the tire, sorta like we did as a kid with our "tube" bike tires . |
10-23-2023, 05:01 PM | #12 | |
Rep 3,708
American tire will do it if they check and determine side wall isn’t compromised. I have used them quite a few times.
2022 G05 B58/PHEV
10-23-2023, 05:36 PM | #14 |
Rep 910
10-23-2023, 05:56 PM | #16 | |
Rep 3,708
Just notice OP is in UK. I googled continental eco contact 6. It is supposed to be run flat. It is called SSR. Maybe in UK, the marking for runflat isn’t the same. This size is also only available in Europe for some reason. We cannot have it in US. What is more weird is this tire is claimed to be summer touring, but looking at the thread pattern, there is nothing summer about it. It has all season tread pattern. It also has snow grid and ice grid designation too. I will call this all season tires. I think those of us in a different country where rules are very different for driving, we don’t even drive on the same side, we probably are not providing info accurate to you location. From the look of tire, definitely repairable tho.
2022 G05 B58/PHEV
10-23-2023, 06:15 PM | #17 | |
Rep 85
I don't believe its recommended by BMW or the tyre companies but £10 v £200+. However, I believe the UK spec 22inch are non RFT so tyre may have to come off for repair but definitely repair. Last edited by Zorrotwo; 10-23-2023 at 06:21 PM.. Reason: Update |
10-24-2023, 02:50 AM | #19 |
Rep 36
Thanks again for all the replies.
Did some more googling and don't think my tyres are RFTs, for Continentals they would have "SSR" printed on the sidewall which doesn't seem to be the case. Hopefully get it repaired in the next day or two |
10-24-2023, 07:11 AM | #20 |
Rep 1,095
I've experienced nails in tires that are nearly self sealing -- the tire will lose only a bit of air pressure over several days. I've used plug repairs, but no longer do as the rasp tool tears through the steel belts, and that's not good. If you can't drive on the tire, remove the wheel, take it to a tire shop and have it patched from the inside. RFT or not, an interior patch is the way to go.
10-24-2023, 08:54 AM | #21 | |
Rep 4,416
