07-13-2021, 11:10 PM | #1 |
Rep 109
So after checking couple X5 M50i cars i find out this BS is real, we frying our cars from factory on photo you can see that oil coolers are covered with some plastic from inside… and my friend who ordered same car same specs one side is open like it should be and other is covered ( mine is covered from both sides its crazy)… i just have feelings thats they just forgot to knock that plastic out… here is photos mine white M50i and same M50i at the dealership.Is anyone have same crap???
07-14-2021, 02:26 AM | #2 | |
1416
Rep 1,564
With the G05, the oil cooler for the M50i has been changed to a oil/water heat exchanger located in the valley of the engine under the turbos. This allowed the elimination of the oil cooler radiator, so BMW moved the aux radiator from the drivers side over to the passenger side and it appears the drivers side no longer has any aux radiator. It also appears that the aux radiator that is now on the passenger side was only installed with the S3ACA, S840A, or S8SLA build options. This most likely accounts for why some are vented and others are not. |
07-14-2021, 08:48 AM | #3 | |
Rep 525
BBHMM34.00 |
07-14-2021, 12:13 PM | #4 |
Rep 103
Drives: M550I/X6M50I/G83
same here ^^ G06 M50I
07-14-2021, 12:31 PM | #5 | ||
Rep 109
07-14-2021, 05:37 PM | #6 |
1416
Rep 1,564
Interesting, can you see if the auxiliary radiator is installed behind the blocked vent on the passenger side?
