08-09-2019, 08:53 PM | #1 |
Rep 1,067
Interesting thing about auto start/stop
Ok I'm not entirely sure but I'm 99% sure that when I'm stopped and the engine turns off, it'll turn back on once the car in front of me starts moving; before touching the gas. Am I just imagining things?
2018 M3 6 spd
2017 M3 AW/SO 6spd 2014 435i M sport BSM/Coral 6spd (retired) 2013 550i M sport Alpine White/Cinnamon (retired) |
08-09-2019, 08:57 PM | #2 |
13220
Rep 19,698
No, you are correct. When it sees the car in front of you moving and you don't let off the brake, it will start the engine in anticipation of you moving.
08-09-2019, 08:59 PM | #3 |
Rep 236
It’s very well possible because it’s logical to expect that car will now have to continue driving. And all technology and sensors are already there to support such anticipation in feature design. I will check with my car tomorrow.
08-10-2019, 03:47 AM | #4 |
Rep 454
There is one more interesting start stop trick, which people are not aware of.
If system decides not to turn off the engine when you stop (after a few stop and go-s), you can force it to by firmly pressing the brake. |
eagle_bmw182.50 thereef5101165.00 |
08-10-2019, 09:01 AM | #5 |
13220
Rep 19,698
I found that last month while on vacation. This is my first auto stop/start system and so far been really impressed with how it works. It is very seamless and hard to tell it is even happening. I have had numerous passengers not even know it was stopping and starting.
08-10-2019, 03:40 PM | #6 | |
Rep 236
08-11-2019, 10:47 AM | #7 | ||
Rep 7,467
If your engines are restarting because the car in front of you has driven off...and your foot is still on the brake...how long is the interval before you take off? Is this happening after perhaps "dawdling" and you're kind of holding up traffic? (not trying to be funny...just trying to understand your experience because this has NEVER happened to me). Again, the only time my engine restarts but my foot is still on the brake...only occurs when the electrical draw is starting to drain the battery. My car has never started when a vehicle in front of me has started to pull forward and my foot is still on the brake pedal. It only restarts when I lift my foot. In regards to turning it off permenantly...I don't think I'd do that...even through coding...but I'd probably code the default mode to be off...then be able to turn it on during those driving situations where I actually desire it (to save fuel). BTW, my tip for the day is...pushing the gear shift lever over into the sport mode position (to disable the auto engine shut off) when pulling into the garage so that I can find that sweet spot to be able to walk around the vehicle when parked in the garage. I hated it when I first got the car and the engine would shut off. For some reason, pushing the gear shift lever to the left is easier than reaching up to shut off the MSA button.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 08-11-2019 at 10:58 AM.. |
fakinit7524.50 |
08-11-2019, 11:51 AM | #8 |
13220
Rep 19,698
I didn't realize you had an G05, if so, you may want to get it checked as it is a standard feature of the start/stop system as far as I know. Audi has the same thing in their new models not sure about MB.
08-11-2019, 01:41 PM | #9 |
14
Rep 48
I Consider the Start / Stop Function To Be a Safety Issue
I understand government mandated requirements for this Start / Stop design for efficiency and/or emission issues; however, the issue that I don’t think they are considering is a safety issue. It is very possible any of us could be in traffic trying to navigate an intersection or such, that has cars coming from many different directions, waiting to cross a train track, etc., and low & behold the car won’t start due to a dead battery. My experience has been that batteries don’t normally give much of a warning when they’re about to die and no longer be able to make the starter motor function. Having a dead battery when I go to start my car in my garage when I want to leave is a big enough inconvenience, but it’s not a safety issue.
I have a 2020 X5 on order, and my intention is every time I get in that car I will push the button to defeat that Start / Stop function. I want to know the engine is running & ready to go when I push on the accelerator pedal. Obviously this is not at all a BMW design that I'm blaming them for, I just think in general it's not well thought out and I'm glad I'll be able to defeat it. Last edited by THinthedesert; 08-11-2019 at 01:49 PM.. |
08-11-2019, 01:48 PM | #10 | |
13220
Rep 19,698
Obviously you have to do what makes you feel the safest but the odds of any of the above scenarios happening and it being an at risk situation are very, very small to the point of not being worth considering in my opinion. There should be numerous warnings if a battery is failing/low and I'm pretty sure it will not engage the stop/start system if the battery is in need of a charging. |
08-11-2019, 02:19 PM | #11 |
Rep 236
Unless you are on the racing track, Start / Stop is really barely noticeable and engine feels as ready to go without any delays. It takes fraction of a second to restart and picks up immediately. If you need that much of a precision just drive in SPORT mode when Start / Stop is off all the time.
08-11-2019, 02:26 PM | #12 | |
Rep 2,609
For the record, I am with you on the ASS function for stated, long term wear/tear/reliability, and sport driving style reasons. But to each his own. In that context, what I won't tolerate in a society I live in, however, is lack of individual choice. Those that want to use it, should have it. Those that don't want it, should be able to disable it. The stock implementation makes disabling inconvenient (and easy to forget every time) and that's wrong.
kkratochvil313.50 |
08-11-2019, 09:15 PM | #13 | |||
Rep 1,067
2018 M3 6 spd
TurtleBoy13220.00 |
08-11-2019, 09:56 PM | #14 | |
13220
Rep 19,698
I was curious as to whether the X5 had this feature so purposely stayed on the brake when the car in front of me started moving. |
08-11-2019, 11:05 PM | #15 |
Rep 430
I love the start-stop feature except in the situations when I approach a STOP sign and hit the break to check for safety and every time I hit the brakes and lift off of it and try to move forward, the engine keeps stop/start/stop and so on. There are times when it looks like we are playing with the engine.
08-12-2019, 07:31 AM | #16 |
Rep 165
Nice catch! I usually disable this within 2 seconds of starting the car, but purposely left it on yesterday and it did restart the engine as the car in front of me pulled away.
08-12-2019, 11:28 AM | #17 | |
Rep 7,467
Auto-hold...this is another feature I've never used because it's relatively flat where I live and 98% of my driving conditions rarely involves creeping along in slow moving traffic...so I've never felt a need to use that feature. You've given me a reason to finally try it out.
08-12-2019, 12:14 PM | #18 | |
Rep 1,067
2018 M3 6 spd
08-12-2019, 12:37 PM | #19 |
Rep 3,507
Or if you are like a recent Tesla driver you can blame it on auto pilot when you blow through the red light!!!! LOL
2022 M8 Comp Convertible
08-12-2019, 08:24 PM | #20 |
Rep 236
OK so I was finally able to test this Start/Stop feature behavior and it's not how it behaves in my car, 2019 X5 at 03/2019.48 I was at the lights for about a minute and was thinking it will just time out and restart on its own when lights turned green and everyone started moving. I was waiting for about 10 sec when everyone ahead of me already left and cars behind starting to get impatient. My engine was still off and only woke up as soon as I took the foot off the break pedal.
08-12-2019, 08:25 PM | #21 | |
Rep 1,067
2018 M3 6 spd
08-13-2019, 03:06 AM | #22 |
Rep 7
IIRC, if you go into Car - Driving Information - Energy Flow, it actually tells you the different reasons why the ASS decided to start/stop/not start/not stop the engine. Possible reasons I’ve seen so far are:
Not stopping engine when coming to complete stop (wording not exact): “Residential intersection detected” (probably in anticipation of quick reaction needed) “Stop sign detected” “Turn indicator on” “Intent to turn detected (steering wheel)” Starting before brake is released: “Vehicle in front started moving” “Air conditioning” I don’t usually drive with ASS on, so there might be other messages the system displays, but I haven’t seen before. Last edited by techc; 08-13-2019 at 04:25 PM.. |
