08-13-2019, 05:27 AM | #23 | |
Rep 236
EDIT: Just tried - same behavior regardless of cars ahead of me at the lights. Energy flow keeps saying "Ready to drive" after the car ahead left. Last edited by AustinV; 08-13-2019 at 06:24 AM.. |
03-17-2020, 07:21 PM | #24 |
123
Rep 333
Im not sure if I should start a new thread. I just got my G06 a few days ago and the auto start/stop is very annoying. I know there is a button to turn it off but it doesn’t look like it is permanent, meaning that I will have to press the button again the next time I start the car from a cold start.
03-17-2020, 08:00 PM | #25 | |
1053
Rep 1,952
03-18-2020, 08:20 AM | #26 |
Rep 1,241
I absolutely DESPISE the auto start/stop feature. It was the first thing I coded off when I was learning Bimmercode.
One thing I do like however, is the hold feature when in traffic. Once you stop, you dont have to keep your foot on the brake. Love that one. |
03-18-2020, 09:21 AM | #27 | |
1053
Rep 1,952
03-18-2020, 03:52 PM | #28 | |
Rep 2,071
I'm usually in sport mode but I drove in comfort and noticed the engine kick in everytime the car in front moved off. I had autohold active at the time so that isn't a factor in the behaviour of this system. Unsure why its not working for some. Nice feature. |
03-18-2020, 04:18 PM | #29 |
Rep 7,477
Perhaps the Auto-H being active is the reason the engine starts up when a car pulls off in front of you. Next time you're out...turn it off (Auto-H) for a brief moment...and see if the behavior changes to where you have to lift your foot off the brake for the engine to restart. Report back your findings.
03-18-2020, 04:22 PM | #30 | ||
Rep 2,071
But TurtleBoy said it worked for him with autohold turned off: Quote:
03-18-2020, 04:22 PM | #31 | |
13244
Rep 19,747
03-18-2020, 04:28 PM | #32 | |
Rep 94
If your BMW senses a weak battery store/capacity, the auto off won't work at all. This would kick in long before you find yourself with the series of unfortunate events that you described. Last edited by Skilly; 03-18-2020 at 04:34 PM.. |
03-20-2020, 07:30 AM | #33 |
Rep 682
I've had my X6 now for 5 days and have trained myself and have accepted the fact that starting the vehicle is now a 2 step process. Push the start button then push the off button directly above it. Frustration eliminated.
03-20-2020, 07:38 AM | #34 | |
1053
Rep 1,952
03-20-2020, 05:16 PM | #35 | |
Rep 74
However, like you said I do believe it can be sort of dangerous in some situations. In my current S60 I often use Eco+ to try and get the best fuel economy I can (I like to make it into a game). When Eco+ is active the engine shuts off at about 6 mph or so when you're decelerating to a stop. One day I was decelerating to a stoplight and the engine shut off. However, the light immediately turned green and I let my foot off the brake and the car started to spazz. It turned the engine back one before shutting off completely. The dashboard lit up like a Christmas tree for 5 seconds then the car prompted me to restart it. I was still in drive though. So I had to put the gear lever in park and then press the start button. Meanwhile, the traffic behind me thinks I'm not paying attention and starts honking at me. Not only was it embarrassing but a bit unsettling. That was a while ago and I didn't use start/stop for a while. I still use but know that there's situations where you should deactivate it. I'm not sure about the X5 but I know Volvo has a separate starter battery that it used just for start/stop. If the voltage isn't high enough in that one then the system won't activate. |
03-21-2020, 06:47 PM | #36 |
1165
Rep 1,778
03-21-2020, 08:02 PM | #37 |
Rep 233
I can’t figure out what I did wrong. Always in the past, when I wanted to quit the ASS feature I would just press the button on the console and the engine would start and continue running. Now, that button has no effect at all. Is it possible that certain settings force the engine to stop at all stops?
03-22-2020, 11:38 AM | #38 | |
Rep 7,477
On the F series BMWs...if you select Eco Pro mode...ASS always comes on. Does the same thing occur with the G series BMWs?
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 03-22-2020 at 11:49 AM.. |
03-22-2020, 04:23 PM | #39 | ||
Rep 2,609
03-22-2020, 05:01 PM | #40 | |
Rep 7,477
So the question to polychromatic is to find out if you are using EP mode...which could be causing ASS to turn on by default? .
03-23-2020, 08:39 PM | #41 |
Rep 233
03-24-2020, 02:43 PM | #42 |
Rep 233
Update: Well, no effect by changing selection Eco-Pro to default coding. I could not get any response by pressing the ASS on/off button. Then while I was driving I just reached down and put my finger on it an low and behold it switched to ASS-OFF. HOWEVER, I could not get it to ASS-ON again no matter how hard or where I pressed. Do I have a faulty button?
