03-23-2020, 10:04 AM | #1 |
Rep 413
Need help with some gremlins
Hi all,
I've encountered three issues that seem to be persistent and was wondering if anyone has a fix for them. 1. Automatic time change: Even though I have this option selected, I've found that my time does not change when I cross time zones unless I manually de-select and then re-select the check box for auto time change. 2. Car turning off when opening driver door: I have de-selected the check box option for my car to turn off when I open the door. However, roughly 75% of the time, my car still does that. It's a bit of a hassle to have to keep turning the car back on just because I'm stepping out to check the mail, etc, and want to keep the car running. 3. When I used to shift the car from reverse to drive, my camera view would switch from the back view to the front. Since my last oil change a few months ago, it no longer switches the view. I even re-set iDrive but to no avail. Any help with the above would be appreciated. |
03-23-2020, 11:08 AM | #2 | |
1053
Rep 1,952
2) The feature you're turning off is not what keeps the engine running. What that option does is shut off iDrive if the car is not running and you open the door. If you want to keep your car running when you open the door you need to turn off ASS. 3) This is a known issue that doesn't have a resolution outside of some higher level coding through Esys. |
