05-17-2023, 10:04 AM | #23 | |
Rep 3,681
Yes both ways are not convenient. Please let us know if you find a better way. |
05-17-2023, 04:39 PM | #25 |
Rep 8,698
Drives: eVeRyOnE mAD!
05-18-2023, 12:32 PM | #26 |
Rep 1,154
Just tested in my M50I and engine stays on if door is open and key is in car.i
2024 M60i Frozen pure grey/Black Merino
2023 M50i Tanzanite / Ivory/Night Blue Merino gone 2022 40i G05 Arctic grey/Ivory Merino gone |
05-18-2023, 12:48 PM | #27 | |
Rep 3,681
For 45e, first, it is not straight forward to have ICE on when park. if somehow you mange for the ICE on when park, you can also open door and walk away with key, ICE will remain on. But the nature of 45e is ICE isn't on when park. In this case, car will turn off when door is open.
2022 G05 B58/PHEV
+ a few very old BMWs |
05-18-2023, 04:53 PM | #28 | |
Rep 1,154
05-18-2023, 05:17 PM | #29 | ||
Rep 8,698
05-18-2023, 05:21 PM | #30 |
Rep 1,154
You might be correct, has anybody got a M50 in US to see if ICE shuts off when you walk away from it.
05-18-2023, 05:50 PM | #31 |
Rep 3,681
My only data point with 40i is when I help a friend to park her car, she exit and walk away with key in her purse, I can still park the car. She isn't too far, but definitely key out of car.
2022 G05 B58/PHEV
05-18-2023, 06:19 PM | #32 |
Rep 6,805
So, you're in the vehicle, in the driver's seat, and then she exits? Sounds right...the driver is in the vehicle and his door isn't opened. It would likely shut off when you opened the driver's door.
05-19-2023, 09:28 AM | #33 |
Rep 1,154
I believe I have got to the bottom of this regarding UK cars at least.
. My previous X5 was a 2022 40i with 48V system. My 3 week old car is a 50i without the 48v, have also just noticed it still has a button to disable stop/start. If I have the stop/start disabled you can leave it running with key out of car. If stop start is enabled but hasn't kicked in I can open door without ICE shutting off, if the stop/start has kicked in and the engine has stopped when I open door it shuts down. Another button I am happy to have.
05-19-2023, 09:35 AM | #34 |
Rep 8,698
you mean Auto Start/Stop (ASS)? (not engine Start/Stop)
yeah, ASS is a gremlin all its own made worse when they removed the button in newer models so we no longer have control of it |
05-19-2023, 10:37 AM | #35 | |
Rep 1,154
All the models now have the 48V system hence no button to turn off.
05-19-2023, 10:51 AM | #36 |
Rep 8,698
ah, you originally posted 50i, not M50i, so I thought you were referring to an older second-hand vehicle
05-19-2023, 12:43 PM | #37 |
Rep 91
For both the 45/50e, when the vehicle shuts off, it should offer the preconditioning/ventilation function at the "goodbye" screen that pops up. Turn that on before you exit to keep it climatized for a short time while you're out of it, as long as the battery has sufficient charge.
05-19-2023, 04:07 PM | #38 | |
Rep 8,698
08-28-2023, 08:13 PM | #39 |
Rep 186
In my 50e if I put it in sport and get out with the key it keeps running but honks the horn at me which is obnoxious as everyone looks. Anyone know how to change that?
08-28-2023, 08:34 PM | #40 |
Rep 6,805
Assuming someone is in the vehicle, you could leave the key in it. Note, with the PHEV, it's pretty easy to turn on preconditioning prior to leaving, meaning leaving the engine on at least for that, is not necessary. Letting an engine idle is illegal in some places longer than a set time and that might be an issue.
SwissBeemer301.00 |
08-28-2023, 09:15 PM | #41 |
Rep 8,698
it's a security and safety risk to keep the engine on and idle, so can't be changed (or even coded). as mentioned, if it's for passenger comfort while you step out quickly, turn on preconditioning before you open the door and exit. you just have to ensure (plan) to have enough battery capacity on hand to run the HVAC. otherwise, you'll need to resort to workarounds (not recommended)
SwissBeemer301.00 |
08-29-2023, 01:23 PM | #42 | |
Rep 3,681
This is also true for 45e. If I run down the HVB so ICE kick in, I can open door and exit, ICE and car remain ON.
2022 G05 B58/PHEV
08-29-2023, 01:37 PM | #43 | |
Rep 3,681
As for the honk, I found it only honk when I lock the car from out side if ICE is running. But it is a 45e
2022 G05 B58/PHEV
08-29-2023, 03:40 PM | #44 |
Rep 256
Why to keep the engine running? For HVAC? Just press the fan/temperature button and AC will run for 10 minutes
SwissBeemer301.00 |
