12-27-2022, 12:17 PM | #67 |
Rep 20
For anyone curious about the fuel savings, here's a calculator that should help you make some rough estimations. It takes into account fuel/electricity cost, mileage driven in stop-and-go, long trips and a couple other things. I found it pretty useful when comparing plug-in hybrids.
https://fueleconomy.gov/feg/Find.do?action=phev1Prompt Here's a comparison of some various PHEVs against my wife's old Honda HRV. It should be noted that I was conservative with my driving habits and we've consistently done better than the EPA estimates in the 45e. Last edited by RubiconJoey; 12-27-2022 at 12:35 PM.. |
nZtiZia4656.00 Scientifix81.00 |
12-27-2022, 12:49 PM | #68 | |
13
Rep 32
12-27-2022, 12:51 PM | #69 | |
Rep 3,681
12-27-2022, 12:57 PM | #70 | |
Rep 8,700
Drives: eVeRyOnE mAD!
maybe “troll” was a bit harsh, but safe to say, he posts more negative comments about the 45e than not |
12-27-2022, 03:17 PM | #71 |
13
Rep 32
I have a couple final questions.
1. Did anyone get an extended warranty? If so, what company did you use? 2. What Level 2 chargers do you recommend? I am looking at the Chargepoint, Juicebox and Emporia. |
12-27-2022, 03:23 PM | #72 |
Rep 6,805
I did not choose for an extended warranty.
There's a bunch of threads on EVSEs. It would behoove you to check with your utility company to see if they're offering any benefits for particular ones, then you have to decide if you want a smart one, or a basic one...they both will recharge the vehicle just fine. |
12-27-2022, 04:00 PM | #73 | |
Rep 5
12-27-2022, 05:02 PM | #74 |
Rep 6,805
I owned an i3 and now the 45e. The i3, if you didn't learn to drive it well initially had some very aggressive regenerative braking. It took me maybe 5-miles to figure out how to drive it smoothly, but some never did until they dialed it back in a s/w update. The regeneration on the 45e is nowhere near as aggressive. It feels more like a manually transmissioned vehicle when you lift off...not aggressive unless you downshift.
Most vehicles these days with an automatic transmission switch to coasting when you lift off, the 45e in most modes does not. In fact, I'd prefer to have more regeneration. On the i3, if you timed it right, you could mostly avoid using the brakes most of the time...that's much harder to do with the 45e, partly because it has more inertia, but mostly because the regeneration is dialed back considerably. I'd be really surprised if you found it too abrupt. |
12-27-2022, 05:06 PM | #75 |
Rep 21
I like the hybrid /hybrid eco pro mode choices. You can default to either. I would not want more auto regen. If I want to slow more but still be in region mode the gauges shows you the threshold you have before actual disk brakes kick in as you push the 'simulated" brake pedal you are using.
12-27-2022, 06:46 PM | #76 | |
Rep 8,700
ANSWER: Hybrid |
12-27-2022, 06:53 PM | #77 | |
Rep 8,700
i have a small lumbar herniation and tear, and the braking system has never impacted me negatively. I would say seating directly impacts my comfort more than the regenerative braking system’s resistance (again, I actively prevent the vehicle from jolting). that being said, i highly recommend the multi contour seats that have a lot of more points of adjustments than the standard sport seats. |
12-27-2022, 06:58 PM | #78 | |
Rep 8,700
2) I had the Emporía first then switched to the JuiceBox 40 because i got a rebate on its purchase and annual account rebates through my electric company. I liked the Emporía while I had it |
12-27-2022, 07:28 PM | #79 |
Rep 1,115
If you're considering a PHEV and want the deal of your lifetime, get a Grand Cherokee 4xe by the end of the year. The one I got has a $70K MSRP. Leased it for $775/month after $12,000 discounts/rebates.
Chrysler Capital is applying the $7,500 tax incentive directly to the deal which made this possible.
Gone: 2020 X7 M50i, Mineral White, Ivory White Full Merino, Piano Black Trim, Cold Weather, Dynamic Handling, Driving Assistance, Luxury Seating, Executive, 22" Y-Spoke Orbit Grey Wheels Style 758i, Space Saver Spare, Trailer Hitch, Leather Dash, Ambient Air, Bowers & Wilkins, Rear Entertainment, Night Vision, Extended Shadowline, Alcantara Headliner in Upholstery Color.
12-27-2022, 09:27 PM | #80 | |
Rep 145
12-27-2022, 09:46 PM | #81 | |
Rep 5
12-28-2022, 01:47 AM | #82 |
Rep 6,805
FWIW, I had my i3 for about 7+ years, and when I sold it, the battery range was within 10% of the original capacity. The logic on vehicle charging plus the cooling capacity and rates is better than that on something like a cell phone. With the PHEV, you have a very significant backup for anything lost in battery capacity. IOW, I'm not worried about it. I might be surprised, but I hope not.
12-28-2022, 07:42 AM | #83 | |
Rep 213
However, you can easily code Eco Pro as the default startup mode using BimmerCode.
X5 xDrive 45e 2023 / Mineral White / Tartufo / Anthracite-Brown Poplar
12-28-2022, 08:19 AM | #84 |
Rep 8,700
true, but coding isn’t available to everyone nor does everyone want or know how to code, so it’s best to state what’s available in the vehicle without taking extra steps or modifying
RickObe93.00 |
12-28-2022, 08:51 AM | #85 | |
Rep 539
Question: when driving a non-EV car, how does your passenger respond to normal braking when, say, approaching an intersection? In my experience, applying the brakes is more jarring than letting the car slow down by regen coasting. I have come to prefer it. I'm confident that after a few weeks driving the car you'll have a good feel for managing the deceleration. However, nobody has raised the issue of the Adaptive Cruise Control with Driver/Traffic Assist. When activated the car will slow down and stop on its own when approaching a stopped car from behind. But it will maintain its designated speed until it gets within a few car lengths then brake pretty aggressively. It always freaks my wife out going 40 to zero in, like, 3 seconds, so I generally deactivate that feature in those circumstances (which you can do by lightly touching the brake pedal). |
12-28-2022, 12:34 PM | #86 | |
Rep 20
2. I looked at the Chargepoint, Juicebox and Wallbox. Was ready to pull the trigger on the Wallbox, but decided on the Autel MaxiCharger. It was signifcantly cheaper at $447 on Amazon. Looks to have very similar features (most of which I don't need) and has a remote cable holster (which I like). https://www.amazon.com/gp/product/B0...0?ie=UTF8&th=1 That said, here's a great resource for comparing multiple chargers. The link is for the maxi charger, but the page has reviews for almost all chargers on the market. https://insideevs.com/reviews/623242...harger-review/ |
12-28-2022, 01:09 PM | #87 | |
Rep 8,700
12-29-2022, 09:17 AM | #88 | |
Rep 539
For my own sanity, I rarely let the car stop on its own in normal situations. There have been a couple of times when approaching stopped cars at an intersection I was waiting for the car to start slowing down but it just wasn't. Glancing at the dashboard I saw that the drive/traffic assist indicator was grayed out even though it had been active moments earlier. I was able to brake in time only because I was paying attention. It was an "oh sh*t" moment, no doubt for the guy ahead of me too. |
