03-31-2024, 04:38 PM | #1 |
Rep 16
Little "clicking" noise - possibly from door gaskets
Hi,
I purchased a use 2022 X5, the PHEV model back in November. Since I got it, I noticed a a minor "clicking" noise. While I drive, it seems coming from where the seatbelt is. While it is minor, it really drives me nuts. I finally got it to the dealership, and the guy first couldn't hear it at all. He then understood the kind of noise I was trying to point to and he said it comes from the door gasket, basically it is almost like as the body of the car moves a bit, it creates friction or release pressure on the body of the car where it is pushed against. He said that is sort of "normal" and in any case it is not something the warranty would cover. He said he could try to clean the body section for a charge in the hope that it goes away. I did it myself, but no change at all. The other thing I noticed is that when I look at the passenger door from the driver seat, I can literally see a bit of light in one spot where the passenger door (should) seal against the door. I can't fathom that to be normal. I am considering bringing it back and point at that, maybe that would get the gaskets replaced or something. I am wondering if anyone has had some similar experience, thank you in advance! |
03-31-2024, 04:59 PM | #2 | |
Rep 254
04-01-2024, 08:23 AM | #3 |
Rep 16
Thank you for your reply.
I also thought it was some sort of reflection at first, I am going to do one more test, since I remember actually looking through while the car was moving and seeing the light changing and sort of resemble what the outdoor looked like. |
04-01-2024, 09:10 AM | #4 |
Rep 130
https://g05.bimmerpost.com/forums/sh...ing+door+seals
Creaking door seals, you'll need some seal lube. Check that thread |
