06-22-2019, 05:32 PM | #1 |
Rep 23
2019 X5 air conditioner
Just purchased a new 2019 X5 and noticed that the air conditioner is not cooling like it should, anyone else have air conditioning issues?
06-22-2019, 05:55 PM | #2 |
13183
Rep 19,668
Sounds like you may not have your air temperature set correctly for the vents. Once set, it will freeze you out in no time. Here is a thread where it is discussed.
https://g05.bimmerpost.com/forums/sh....php?t=1622719 |
wrickem2101.00 |
06-22-2019, 06:14 PM | #3 | |
Rep 684
2019 G05 X5 40i, Phytonic Blue, Black Extended Merino Leather Interior
wrickem2101.00 |
06-22-2019, 07:32 PM | #4 | ||
Big Beaver Smile
2101
Rep 3,791
gpitts247.00 |
07-03-2019, 07:28 PM | #7 |
Rep 6,121
It should be nice and cool, I measured mine at 7.6C ~45.68F which is great for hot days! This is while the AC was set to low i.e 60F cabin temp
07-04-2019, 03:45 AM | #8 |
Rep 506
Drives: 2019 X5 xDrive40i
Make sure your AC is on.
I actually didn't know until after a week that your center "fan screen" has to show "AC" in the middle when the AC is on. You can turn it on by pressing down (up is for menu, down is for AC) on the "MENU / AC" button. |
07-04-2019, 01:10 PM | #11 |
Rep 6,121
No, but it won't blow nearly as hot from the top vents if you don't
07-04-2019, 01:37 PM | #12 |
Rep 602
Thanks. Sounds like I do then. I don’t recall this being a requirement in any previous car I’ve owned. Doesn’t the X7 have a touch display dedicated to this control? I believe I saw this in a video review of it somewhere.
07-04-2019, 01:53 PM | #13 |
2436
Rep 1,945
That is in the new 7 series. I really would have liked for this setting to not be buried in the settings the way it is but it is not a big deal.
07-04-2019, 11:50 PM | #15 |
Rep 3,506
If you have a blank button for the pre-sets you can set it to the screen to allow for adjusting.
2022 M8 Comp Convertible
GTF370.00 |
07-05-2019, 09:53 AM | #16 |
Rep 602
07-05-2019, 10:15 AM | #17 |
2436
Rep 1,945
You have to go up one menu item to get it to save. You then have an extra click to do to get to the setting which is not ideal but better than going through the entire menu to get there.
07-05-2019, 10:29 AM | #18 |
Rep 602
Thanks. I thought I tried back one level as well but I’ll try again. I’ve tried saving many functions to those buttons and always get that message. It’s poorly implemented like much of idrive.
07-05-2019, 10:47 AM | #19 |
2436
Rep 1,945
Maybe it was 2 levels back... I set it up pretty early on after getting the car so i am not sure at the moment. I tried to set the shortcut directly on the vent temp setting/button, and when it did not work, I just went up one level, tried to save again. And if that did not work, went one level higher. I can double check this evening and let you know.
07-05-2019, 11:17 AM | #20 |
Rep 1,064
I have mine mostly set up to call contacts. Works perfectly
2018 M3 6 spd
2017 M3 AW/SO 6spd 2014 435i M sport BSM/Coral 6spd (retired) 2013 550i M sport Alpine White/Cinnamon (retired) |
07-05-2019, 12:26 PM | #21 | |
Rep 602
