04-08-2024, 05:38 PM | #1 |
Rep 254
Valved Exhaust wired to M button?
Is it possible? Is it practical? Is it a waste of effort?
Seems pretty nice to just press one steering wheel button. To make it work, there'd have to be some type of signal from the computer that is controlled when in m-sport mode. One that you could tap into to control a switch of some sort. Does that exist? The rest would be just like normal. Why? just wondering if it's possible.
-Thumbie
2011 Jerez E90 M3 6-speed Competition Package |
04-09-2024, 09:18 AM | #3 |
Dont listen to me
810
Rep 579
The potential problem you could run into is interfering with the M button's primary function of switching driving modes.
The M button's standard operation does not function as a normal switch per se. Instead, depressing the M button triggers the SZL module (clock spring, steering angle sensor thing behind the steering wheel) that a change is necessary, and the SZL module sends an "on/off packet" through the car's CAN network to the DME (car's ECU) to change the driving mode. I know the actual M button is a simple switch that completes a basic circuit to the SZL to signal a change request, so it may be possible to splice into the actual switch wiring. What I don't know is what happens if you add a simple power or ground circuit into the factory M button circuit between the physical steering wheel button and the pins on the SZL, and what it could do to the SZL->DME CAN bus communication. You also have the issue of running new wires and 'bridging the gap' between a rotating steering wheel and fixed steering column.
Instagram: @thatwhitem4
Thumbie100.00 |
04-09-2024, 10:28 AM | #4 |
Rep 254
Hmmm ok. Just was something I was thinking about the other day.
I wonder if there's something out of the steering column and on the ECU that you could tap into...but MineralWhite's comments about adding voltage is basically telling me to stop thinking about this. I have heard these cars are very sensitive to the slightest change in voltage. Moving on then. Appreciate the insight. Another idea: I installed coilovers and coded out EDC. Maybe using the now-unused EDC button would be better. Overall this idea came from minimizing buttons to press.
-Thumbie
04-09-2024, 04:11 PM | #5 |
Rep 119
Now thats an idea.And just get another button 3d printed and rename it.Would be unique,but then again why?1day when u want to put everything back to stock,will be easy if u keep it original.
04-09-2024, 09:58 PM | #7 |
Rep 504
Drives: 2009 E93 M3 DCT
04-10-2024, 06:56 AM | #8 | |
Rep 7
Drives: 2011 M3 Coupe
04-10-2024, 07:16 AM | #9 |
Rep 936
Drives: E90 M3
Same here, I also had EDC and was gonna reuse the button or add one near the seat warmers. The garage door opener button takes about 30 seconds to set up, no wires or coding.
04-10-2024, 01:42 PM | #11 |
Rep 254
I wish I had homelink, I saw elsewhere people have done that.
I think EDC button is the move. This guy set up his cutouts to a spare button next to the auto start/stop, also a clean option. Or the rear sunshade I guess but same button bank, depending on your M3. Overall, some good options besides using whatever aftermarket button comes with the exhaust. Or a tacky key fob. Wait, is the key fob how you program to homelink??
-Thumbie
04-10-2024, 08:18 PM | #12 |
Rep 4,181
This is what I did. I think it looks quite OE+. I wanted a button which I could see if it was enabled or not. You can buy the button off AliExpress.
https://a.aliexpress.com/_onjorcy |
Thumbie100.00 CamasM3e933224.00 |
04-19-2024, 01:55 PM | #14 |
Rep 459
There's room for it on the steering wheel and you could easily disassemble the button and use it as a traditional gating switch, which likely would't interfere with function, but all steering wheel data gets sent through the clock spring, which is a long ribbon cable that allows it to function throughout the rotation of the wheel, you'd have to route and hide a bunch of extra cable length so it doesn't break. if you check my thread, I used a dummy button under the CD slot, where the auto start stop button is / power rear sunshade / heated seats on older model years.
04-22-2024, 01:08 PM | #15 |
Rep 254
Yes I did see your thread and really like what you did. I believe what you did may be the cleanest option.
-Thumbie
04-22-2024, 01:20 PM | #16 |
BimmerPost Supporting Vendor
1446
Rep 1,614
The M button emits a message on the PT-CAN bus. My friend may know what it is, but I don't. Getting a sniffer on the PT-CAN bus is easy to wire in and there are DIY's out there for that. You can sniff the PT-CAN for the message, then trigger a 5V output which would then control your valved exhaust. It's actually pretty easy, but you have to be very tech and electronics savvy to do it.
04-22-2024, 02:32 PM | #17 |
1446
Rep 1,614
I asked...here's what I got.
M Button is part of the steering wheel buttons group on the PT-CAN bus. Function: M-Button pressed PT-CAN Address: 0x1D6 Start location: bit-14 Size (in bits): 1 Hook up a can bus sniffer to the PT-CAN bus, and you can see this bit toggle when you press/release the M-Button. What you do with it...is up to you. |
