08-01-2021, 11:51 PM | #155 |
Rep 481
That might be the case, but why only does it happen with comfort access? I say it's some sort of bug. If the 12v battery would be low, it will result in an event in the onboard computer. But there is nothing there after it happens. So the computer does not see it as an error.
08-02-2021, 01:19 AM | #156 | |
Rep 2,420
Personally I think it is related to comfort acces like we tested but also driving in all electric mode for longer time and the car requesting for driving with ICE. |
ikheetleon218.50 |
08-02-2021, 03:59 AM | #157 |
Rep 481
This Friday the dealer will try to enable comfort access in my car again. They will leave the datalogger in my car to record the event when/if it happens. Will be on holiday the two weeks after, so plenty of time to test.
X5 45e1090.50 |
08-02-2021, 10:38 AM | #158 |
Rep 481
Against all odds, my car just started in hybrid again. Had a small 3 km trip, stopped the car, locked it. Went away for about 15 minutes, started the car again for a 3 km trip. Stopped the car, locked it. Came back 4 minutes later and there it was. Started up in hybrid. So this event has been catched by the datalogger. But now I'm curious why it happens way more often with comfort access instead of keyfob.
X5 45e1090.50 |
08-03-2021, 11:40 AM | #159 |
Rep 2,420
I have been driving around in Italy for 3 days now. I was able to charge at a public parking for 4 hours and the rest I had been driving sport mode, adaptive with gear in manual or battery hold in order to keep my battery charge for preconditioning.
I always used comfort acces and it never started in hybrid always in electric individual. I never ended my trip in EI always in the mode I was driving in. |
ikheetleon218.50 |
08-06-2021, 05:54 AM | #160 |
Rep 481
Visited the dealer this morning to get comfort access enabled again. It appears that when the datalogger is connected to the car, comfort access does not work. So that will make it very hard to reproduce the issue. I have 1 incident so far, hopefully there will be more. I've now enabled "unlock on approach" again. Will disable it after a couple of days and hope it somehow triggers the issue.
08-06-2021, 08:17 AM | #161 | |
Rep 2,420
When I opened with the key after a short stop it started in EI. I did drive in sport so the battery charged to 15% before stopping the car. |
ikheetleon218.50 |
08-06-2021, 08:43 AM | #162 | ||
Rep 481
08-06-2021, 09:00 AM | #163 |
Rep 8,767
Drives: eVeRyOnE mAD!
I have frequent trip interruptions almost daily: work > summer camp > groceries and enabled 'unlock on approach'. I rarely get the switch to hybrid.
X5 45e1090.50 |
08-06-2021, 09:03 AM | #164 |
Rep 481
08-06-2021, 09:07 AM | #165 |
Rep 8,767
yes, I drive EI almost exclusively. the last time I used the ICE or any other driving mode was over 2 months ago. The last time mine switched to hybrid was a month ago while I was coding
08-06-2021, 09:08 AM | #166 | |||
Rep 2,420
ikheetleon218.50 |
08-06-2021, 09:14 AM | #167 |
Rep 481
Thanks, so we can scratch those two from the list. Same for level of hv battery. I've had it with full and almost empty battery. Same for weather (hot/cold).
10 minutes ago I went for a short trip and the steering wheel did not extend. This was the first startup since I modified the "unlock on approach" setting to "enabled". When the issue's happened on the 2nd of august, I just disabled that setting. It seems like different startup sequences are used depending on how the car was unlocked. Fiddling with the "unlock on approach" setting does seem to have influence. |
X5 45e1090.50 |
09-21-2021, 11:42 AM | #168 |
Rep 481
Data logger has been removed from my car today and send to BMW DE for further analyses along with my report and pictures about the issues/occurrences. My car is now on 07/2021.46 software, Comfort access is working again. I should get an update in about two weeks.
09-21-2021, 11:47 AM | #169 |
Rep 203
Switching to hybrid happens to me as well if driver switches the profile associated with the key/digital key to another profile in the car. It doesn't happen if each person use their own key/digital key and use the profile that is loaded automatically.
SteveIsles32.50 |
09-21-2021, 12:16 PM | #170 |
Rep 8,767
Randomly switched to hybrid twice in the past two weeks. I just felt the suspension was softer, looked at the IC and saw it was in hybrid. I clicked on electric and it reverted back to hybrid. no reasons that I could think of that would obviate operating in electric from the get go as that's the driving mode I have programmed on startup and no extreme temperatures, either
12-11-2021, 06:58 PM | #171 |
Rep 25
This is still happening and it’s now Dec 2021.
Set as Electric Individual (and my ambient lighting was also set to orange). I get in the car and it starts in hybrid driving mode and not EI AND my ambient lighting is now blue. EI setting is no longer checked and ambient lighting setting is now blue. Has happened to me every time in the past two days or so. Previously it rarely happened. Did everyone else with this issue give up? |
12-11-2021, 07:09 PM | #172 |
Rep 477
For me it has happened but only when I have already been driving.. if I stop, turn car off, get out and lock then come back to the car is a short period of time it starts in Hybrid instead of Electric as set in my settings. Doesn't really bother me like I'm reading for others… small little hiccup it seems like.
12-11-2021, 07:56 PM | #173 | |
Rep 25
12-11-2021, 08:11 PM | #174 | ||
Rep 477
volodp199.50 |
12-11-2021, 08:44 PM | #175 | |
Rep 8,767
when mine randomly goes into Hybrid, I'm still in my driver profile with all my settings, ambient lights, radio stations, everything. |
12-11-2021, 09:45 PM | #176 |
Rep 25
I am in my profile. It says my name at start up each time.
