01-23-2022, 07:17 AM | #1 |
Rep 747
Wireless charging overheating phone
I’ve noticed now a couple times on long trips with Apple Map running on CarPlay through IPhone Xmax that after a couple hrs sitting in the tray, it loses connection and I’ll remove the phone to see the warning on it and definitely confirm by touch it’s hot. I haven’t had this issue in previous vehicle under same conditions. Normal?
01-23-2022, 08:01 AM | #2 |
Constantly Learning
66
Rep 200
I have the same issue (12Pro). For long trips I slide the phone in the center console and plug it in instead of using the tray. It's the one option I would do without. MagSafe charger never gets my phone warm, wireless chi does.
01-24-2022, 03:48 PM | #3 |
Rep 6,806
There's a sweet spot for charging the phone. The LEDs, for me, are hard to see, but check the manual for what to look for. It may be you need to move the phone slightly. Second possibilities, there's a maximum size restriction for what will work along with a maximum thickness of the case listed in the manual.
Carplay while using maps means almost constant data transfer on cellular...that can make the phone hot. |
04-27-2022, 05:44 AM | #4 |
Ex Moddy
119
Rep 145
Is there a setting to disable wireless charging or Bimmercode option to code out wireless charging?
The location is perfect for storing my phone whilst on the move but removing it from the case everytime I want to use it just because it gets hot is not an option + I keep my phone regulalry charged at home so don't need it for charging purposes anyway.
X5 45e in Arctic Grey with Merino Leather, Technology Plus Pack, Comfort Pack, M Sport Pro Pack, Shadow Line Pack, Sky Lounge, Acoustic Glass, Tow Bar, Sun Protection Glass, Sky Lounge, Carbon Mirror Caps and Laser Lights.
04-27-2022, 05:51 AM | #5 | |
Rep 8,700
Drives: eVeRyOnE mAD!
Makefish118.50 |
11-08-2022, 06:02 PM | #6 |
Rep 28
This is driving me crazy $500 upgrade that I can't use
Did anyone find a solution for this? |
kgelfen3602217.00 |
11-08-2022, 07:44 PM | #7 | |
Rep 8,700
but know that the $500 price mainly includes the LTE compensator which has proven more beneficial to many folks |
11-08-2022, 09:44 PM | #8 |
Rep 6,806
FWIW, if you run those apps while not charging, the phone will get hot. Throw in charging at the same time, when the back is in contact and can't radiate the heat away, and it being warm is not unusual. Having the phone in a case makes it worse, as it adds insulation. Now, if BMW actually applied cooling to the charging plate, that might help.
11-09-2022, 01:35 PM | #9 |
Rep 28
Thanks for the replies!
Sadly, I don't plan on using the LTE feature. $15/$25 a month is not worth it when I already have 5G internet on my phone in most of the areas I travel to. I added the option to avoid charging cables. Carplay/navigation was running off my wife's phone. And still my phone heated up in the wireless charging tray. I wish BMW had a better design. |
Beemertj18.50 |
11-09-2022, 01:42 PM | #10 | |
Rep 8,700
mobilejo1114.50 |
11-09-2022, 04:45 PM | #11 | |
Rep 28
nZtiZia4656.00 |
11-09-2022, 08:54 PM | #12 |
Rep 6,806
Cellphones can adjust their broadcast signal strength to help overcome a weak connection with the tower, so having the LTE compensator also means that your phone doesn't have to work as hard when it's in use, helping to keep the temperature down, and use more of the available power to charge the phone versus to keep a hard-working processor going.
As I mentioned, though, even if not charging, running high data volume constantly to support things like a gps and mapping going maybe while playing music is a tough task for any phone, and it will get at least warm...throw trying to charge it at the same time, while in a cubby where there's not a huge amount of air circulation, while also maybe in a case, and it makes the heating issue worse. |
12-20-2022, 06:53 AM | #13 |
Rep 20
I'm not sure about iPhones, but in Samsung phones you can turn off fast wireless charging. I haven't tested this yet to see if it makes a difference, but I hope so. It sucks having to deal with charging cables.
12-21-2022, 02:01 PM | #14 |
Rep 474
Drives: 2022 BMW X5 xDrive 40i
Maybe related, maybe not. But whenever I use my Verizon/Android wireless charging stand for my work iPhone, the phone gets really hot, whereas the Samsungs and now Pixel never have.
They must draw a different wattage or whatever during a charge.
2022 X5 xDrive40i
Black/Black/Black |
02-23-2023, 07:27 AM | #15 |
Rep 6
I have samsung Fold 4 and it gets way too hot to a point where the phone displays that it is hot and turns of wireless charging until it cools down a bit. Once it cools down under threshold, Wireless charging starts and phone gets hot within a minute and stops again. This is a constant cycle once the phone gets hot the first time you place it in the tray and it is very annoying. I am pretty sure it will damage my phone in long run.
02-23-2023, 09:19 AM | #16 |
981
Rep 1,560
There is a member (Kwajtrader) in the Z4 forum who built a fan to cool the phone while charging. It seems to be a solution that several people like.
https://g29.bimmerpost.com/forums/sh...harging+%2Bfan
2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, HT, TC Kline DA Shocks & Camber Plates, w/H&R Springs, Stromung Exhaust, SSR Type C. Looking for new home.
2022 Z4 M40i, Misano Blue Metallic, Driver Asst Pkg, Prem Pkg 2023 X5 M50i, Phytonic Blue, Black Extended Merion Leather, Driving Asst Pro Pkg, Park Asst Pkg, Exec Pkg, Climate Comfort Pkg. |
02-25-2023, 10:24 PM | #17 |
Rep 825
Your phone will automatically cycle off if needed due to excess heat. I've never had that happen except when I inadvertently leave my phone sitting in the sun during the summer.
Two is One and One is None
03-06-2023, 04:45 PM | #18 |
Rep 82
Aftermarket Wireless Charger
Just incase anyone is checking out this thread and doesn't want to pay $127 for what Amazon has. I am selling mine. I got a new X5 that comes with wireless charging so I don't need it anymore. It has a little fan that keeps the phone cool.
https://g05.bimmerpost.com/forums/sh....php?t=1998250 |
11-09-2023, 01:26 PM | #19 |
Rep 65
Just picked up my 2024 X5 last night. Used the wireless charger and my phone overheated , disconnected my call and couldn’t use until it cooled down.
Any solutions to this ? Thanks 😊 |
11-09-2023, 03:22 PM | #20 | |
Rep 8,700
the charger is only 5W and essentially needs near-perfect placement of the residing phone. I stopped using it after a week then mounted a MagSafe charger which has been going strong for almost three years here’s a more recent thread on the same subject https://g05.bimmerpost.com/forums/sh....php?t=1976640 |
11-27-2023, 06:47 PM | #21 |
Rep 172
Anyone talk to the BMW dealer about this overheating?
I had a long drive about 3 hours and was running the BMW nav and also Waze at the sametime. When I stopped to get lunch, I took my iPhone out and it was very hot and the display said it was hot and to let it cool off.
11-28-2023, 12:10 AM | #22 |
2JZ-GTE
3045
Rep 3,997
normal with BMW wireless, not sure if normal as I have never used wireless charging except on my iWatch.
