04-18-2019, 12:50 PM | #1 |
Rep 3,507
Adaptive Drive Mode Opinion
So like tittle says, I have been using adaptive drive mode now for about a week. I know not much time but curious if anyone else notices the same as I do. I may be overly simplifying what it actually does but this is what I can feel while driving.
Driving highway at steady pace I'm seeing estimated 20-23mpg instead of the comfort 17-19. Not sure if it is putting in eco mode or something? It is very consistent though. When getting onto the freeway on ramp the throttle response is awesome, and shifts are better. Almost as if it was in sport. Taking highway corners that show a stupid 45mph sign at 65mph feels more planted than typical comfort mode. Steering gets tight and accurate. Is there anyway to just have this thing be always in adaptive and not mess with comfort or eco? I really believe I would simply rather have adaptive on all the time!
2022 M8 Comp Convertible
04-18-2019, 02:08 PM | #2 |
Big Beaver Smile
2101
Rep 3,791
Do you use Adaptive while you have your Nav running?
I've got rural winding roads and it really makes a difference with Nav running vs without in adaptive mode since "upcoming road sections are considered". It knows before I get there where it should do its thing.
04-18-2019, 02:12 PM | #3 |
13265
Rep 19,785
Adaptive mode is a mix of all of them and it changing all the time. It not only adapts to your driving style but also the upcoming roads (possibly only using navigation but not sure) hence what you feel on the on ramps and curves.
I would imagine you can have it coded to default to adaptive but that option is not native due to EPA standards and how the car was tested. |
04-18-2019, 03:50 PM | #4 | |
Rep 3,507
04-18-2019, 05:20 PM | #5 | ||
Big Beaver Smile
2101
Rep 3,791
04-18-2019, 05:59 PM | #7 |
Big Beaver Smile
2101
Rep 3,791
Actual route guidance running. I know my way home from work but I use it so I get the most out of my fun twisty rural route home in adaptive mode. I wish my other cars had it.
X5_CC288.50 |
04-18-2019, 07:00 PM | #8 | |
Rep 165
Drives: 2019 BMW X5; 2017 Audi Q7
04-18-2019, 07:04 PM | #9 | |
13265
Rep 19,785
04-18-2019, 07:08 PM | #10 |
Rep 165
ok thanks. My Q7 will slow you down in a curve if you don't brake. I was wondering about this in the X5 since it hasn't done it. I am almost spoiled by the Q7 in this regard going into curves.
TurtleBoy13264.50 |
04-18-2019, 11:12 PM | #11 |
Rep 6,121
Adaptive = a mix of comfort and Sport. It has a softer suspension and lighter steering when needed but can change both alongside transmission + engine response when you need it. I normally drive in adaptive so I'm used to how it performs. If I know the road is very rough I'll use comfort.
04-18-2019, 11:13 PM | #12 | |
Rep 6,121
04-19-2019, 04:32 AM | #13 | |
Big Beaver Smile
2101
Rep 3,791
04-19-2019, 10:48 AM | #14 | |
Rep 494
2019 BMW X5 40i Phytonic Blue/Tartufo
2016 BMW X3 35i M-Sport, Dinantronics (sold) 2012 BMW X3 28i (sold) |
04-19-2019, 02:09 PM | #15 |
Rep 6,121
Mine is the opposite, maybe a 50i thing
04-19-2019, 02:39 PM | #16 |
Rep 533
So with air suspension + adaptive mode, does that mean system will shift height of car along with changing mode ? Like:
Comfort => Sport => comfort => .... Level 3 => level 2 => Level 3 => .... |
04-19-2019, 07:14 PM | #17 | ||
Rep 155
Drives: 23 X3 M40i 24 X3 M40i
04-20-2019, 01:13 AM | #18 | |
Rep 494
04-20-2019, 02:52 AM | #19 | |
Rep 3,406
wrickem2101.00 |
04-20-2019, 07:48 AM | #20 | |
Rep 4,246
Air suspension ride height follows it's own logic: Normal (up to 87mph) > Dynamic (87-124) > Normal (up to 87mph) Normal > Dynamic > Sport (over 124mph) > Dynamic > Normal When driving without a preset program, the vehicle level is adapted automatically, depending on the speed. This reduces drag and increases the driving dynamics of the G05. If the various driving speeds are undercut, the previous ride height is set. Dynamic level If a driving speed of roughly 140 km/h (87 mph) is exceeded, the "Dynamic level" (–10 mm) is set. The "Dynamic level" cannot be approached manually and the driver is not notified about this ride height. The following table shows the control strategy (hysteresis) of the dynamic level. Speed Time Driving level > 160 km/h (>100 mph) Direct lowering Dynamic level (–10 mm) 140 – 160 km/h (87–100 mph) > 170 s Dynamic level (–10 mm) < 100 km/h (<62 mph) Direct raising Normal level (+/–0 mm) 100 – 120 km/h (62–75 mph) > 20 s Normal level (+/–0 mm) Sport level The "Sport level" is set above a driving speed of 200 km/h (124 mph). The Sport level can also be set manually by pressing the SPORT Driving Experience Control switch or the ride height rocker button, irrespective of the speed (from 0 to maximum speed). The LED on the ride height rocker button indicates which sport level is activated
MPoweRo428.00 |
04-20-2019, 03:13 PM | #21 |
Rep 127
AndroidRobot4331.50 |
04-20-2019, 04:57 PM | #22 |
Rep 6,121
it's tuned differently because the 50i is heavier and has a different weight distribution to name a few. I use adaptive a lot depending on where I am. I wish there was just a straight induvidual option like Audi has so I could do sport steering, adaptive suspension, sport + engine and comfort transmission
