      04-21-2019, 11:07 AM   #23
bichoo
bichoo's Avatar
281
Drives: BMW X5 40i M-Sport
Originally Posted by Charles549 View Post
I agree, adaptive not softer in 50i. Might be the M suspension?
Interesting..must be a 50i thing. My 40i is M suspension. I'm also on 22s.
2019 BMW X5 40i Phytonic Blue/Tartufo
2016 BMW X3 35i M-Sport, Dinantronics (sold)
2012 BMW X3 28i (sold)
      04-21-2019, 11:43 AM   #24
Wild Blue
Wild Blue's Avatar
Drives: 2021 X7 M50i, 2004 330i w/ZHP
So... to get adaptive drive, you have to have an active route going in Navigation? So to make it work for your daily drive to and from work, you have to have a navigation route going every time, and Betty giving you constant voice directions that you don't need, since you already know where to go?
Am I missing something? That seems like that would get annoying.
      04-21-2019, 12:50 PM   #25
wrickem
Big Beaver Smile
wrickem's Avatar
2101
Drives: What he wants to
It'll adapt without route guidance, but it'll adapt quicker and more enhanced with it running because it knows what's coming up.
I just turn off the voice instructions if I know where I'm going.
Current- '21 430 , '19 911, 07 M6 ,'17 Jeep Wrangler, "23 Bronco OBXluxsquatch
      04-21-2019, 08:26 PM   #26
lumpydog
lumpydog's Avatar
691
Drives: 2019 X5
I love the idea of adaptive drive - in theory... but BMW's track record on this vehicle with anything software related... I'm not trusting BMW to make any software-based decisions for me. I stick to the fixed drive modes and switch manually.
      04-22-2019, 11:16 AM   #27
2019x5User
146
Drives: bwm x5
Originally Posted by Auricom View Post
Originally Posted by 2019x5User View Post
So with air suspension + adaptive mode, does that mean system will shift height of car along with changing mode ? Like:
Comfort => Sport => comfort => ....
Level 3 => level 2 => Level 3 => ....
Electronic Damper Control (EDC) continuously controls the air suspension dampening which is adapted to road conditions.
Air suspension ride height follows it's own logic:
Normal (up to 87mph) > Dynamic (87-124) > Normal (up to 87mph)
Normal > Dynamic > Sport (over 124mph) > Dynamic > Normal
When driving without a preset program, the vehicle level is adapted automatically, depending on the speed. This reduces drag and increases the driving dynamics of the G05. If the various driving speeds are undercut, the previous ride height is set.
Dynamic level
If a driving speed of roughly 140 km/h (87 mph) is exceeded, the "Dynamic level" (–10 mm) is set. The "Dynamic level" cannot be approached manually and the driver is not notified about this ride height.
The following table shows the control strategy (hysteresis) of the dynamic level.
Speed Time Driving level
> 160 km/h (>100 mph) Direct lowering Dynamic level (–10 mm)
140 – 160 km/h (87–100 mph) > 170 s Dynamic level (–10 mm)
< 100 km/h (<62 mph) Direct raising Normal level (+/–0 mm)
100 – 120 km/h (62–75 mph) > 20 s Normal level (+/–0 mm)
Sport level
The "Sport level" is set above a driving speed of 200 km/h (124 mph). The Sport level can also be set manually by pressing the SPORT Driving Experience Control switch or the ride height rocker button, irrespective of the speed (from 0 to maximum speed). The LED on the ride height rocker button indicates which sport level is activated
I did not see it lower down when speed > 87mph.
      04-22-2019, 05:35 PM   #28
tastes jigga
tastes jigga's Avatar
Drives: '19 750i xDrive
It doesn't show the -10mm drop. Try going above 124mph and report back.
      04-22-2019, 11:43 PM   #29
2019x5User
146
Drives: bwm x5
Oh, I see
      04-23-2019, 04:47 AM   #30
Auricom
Auricom's Avatar
Drives: 2020 X5 xDrive40i M Sport
Oh, I see
"Dynamic level" cannot be approached manually and the driver is not notified about this ride height. You'll also have to be over 87 for 2min 50secs LOL.
The air suspension level indicators are:
Off-road level <> High level <> Normal level <> Sport level <> Load level
Hit 124 and you'll see the indicator change from Normal to Sport.
      04-23-2019, 06:15 AM   #31
tastes jigga
I don't understand the waiting period for the air suspension. If BMW thinks the vehicle handles better with the 10mm drop above that speed, then I want the car to begin adjusting immediately!
      04-23-2019, 10:38 PM   #32
2019x5User
146
Drives: bwm x5
Adjusting height also takes time, it makes sense to have a timer for speed threshold before triggering adjustment, so you won't feel riding on horseback
      04-23-2019, 11:03 PM   #33
cataitu
Luxembourg
43
Drives: X5 F15 M50d
To me the most interesting part of adaptive was the drop in fuel consumption. I would normally get an average of 10l/100km but see the pics...drove through Germany respecting construction areas and most speed limits and then usually 150-170 km h where there were no limits (the car is still below 2000 km on the clock) and averaged a bit over 8l/100km. When driving through Austria which is plagued with fixed cameras and policemen with laser guns the fuel consumption went to 7.3 l. Average speed was quite ok for Germany given the facts I had quite a few construction areas and that lowered the speed to below 100. Impressive car...it feels completely different than the f15.
      04-24-2019, 06:24 AM   #34
AndroidRobot
AndroidRobot's Avatar
  [0.00]
As mentioned it gives better throttle and engine response so if you're doing anything other than set cruising more fuel will most likely be used.
      05-25-2019, 08:27 AM   #35
grahamcoxon
Drives: BMW X5 G05 3.0D M Sport
I really like Adaptive.
My question is, do I have to switch it on every time I get in the car? The default appears to be Comfort.
      05-25-2019, 08:38 AM   #36
tastes jigga
You can code it to default to Adaptive using Bimmercode and a OBD adapter.
      05-25-2019, 09:00 AM   #37
X54TH
Member
X54TH's Avatar
893
Drives: 2019 X5 40i M Sport
I don't think we have the ability just yet to code that.
2019 X5 Alpine White M-Sport
Software Version 11/2022.31
2023 M2 (HEA) Brooklyn Gray
2021 330i XDrive Alpine White M-Sport
      05-25-2019, 10:13 AM   #38
SHAWN 212
Drives: 2019 BMW X5 XDRIVE 40I M SPORT
2019 BMW X5  [0.00]
Can it be coded to sport mode?
      05-25-2019, 10:53 AM   #39
X54TH
Member
X54TH's Avatar
893
The BimmerCode App the OBD MX+ Adapter does not give us the ability to select a default drive mode.
