09-26-2022, 07:51 PM | #1 |
Rep 81
Drivetrain Malfunction
Anyone else get these?
Comes up occasionally with aggressive driving but not really pushing the vehicle hard realistically. Message comes up, nothing in check control, check engine light goes away. Took it to local BMW and they couldn't find anything logged/stored. Any thoughts before I take it in and have them not find anything again? 315/30/22 - 285/35/22 MSS GTS Black Thanks *edit* BMC Filter FI catback Catless secondaries Last edited by irpirate; 09-27-2022 at 06:46 PM.. |
09-26-2022, 08:24 PM | #3 |
3201
Rep 1,866
I get this as well when driving hard and suspect it's a combo of racechip and intake and dp. I usually reboot the car and it goes away.
09-26-2022, 08:39 PM | #4 |
Unapologetic Tool Hoarder
736
Rep 966
I can almost guarantee it's related to the RaceChip. As onfireX5 said, probably map setting or octane related, possibly overboost. If you have BimmerLink, you can run some logs and check the values and try to correlate with when you get the malfunction. Not sure of the RaceChip app allows logging like JB4, otherwise you'll be relying on the "fudged" boost numbers versus actual.
09-26-2022, 11:08 PM | #5 |
Rep 2,699
Drives: 23 X5MC
Can you remove the race chip and see if you get the error? If not then that would be the cause
09-27-2022, 11:33 AM | #7 | |
Rep 4,532
I’ve run 93 octane and level 7 since 2016 on 3 different BMW’s without an issue. Odd that 93 and 5 might be a problem unless other mods are there. |
09-27-2022, 06:46 PM | #8 |
Rep 81
09-27-2022, 07:02 PM | #9 | |
Rep 4,532
If it goes away with the bypass, it could be the cat less secondary could be causing a spike overboost in conjunction with the RaceChip at low rpm, tip in boost. Just guessing……. |
09-27-2022, 08:46 PM | #10 | |
Rep 25
09-29-2022, 11:57 PM | #11 |
13122
Rep 18,794
Scan the car and find out what's the reading.
Also take pictures on your installation. Drivetrain Malfunction can be anything, I've had few Drivetrain Malfunction on stock car before. Maybe BMW uses cheaper chipset due to chip shortage.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com Memorial Day SALE!! 05/24 - 06/03 • Coupon Code: "MEMORIAL" MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri Active Autowerke • KW • H&R • Ohlins • Remus • and more... |
10-01-2022, 02:07 PM | #12 |
Rep 6,771
Drives: 2016 BMW i8
Garage List 2012 BMW e92 M3 [0.00]
2021 BMW X5M [10.00] 2015 Porsche 991 Tu ... [10.00] 2015 Porsche 991 GT3 [10.00] |
Would a RaceChip by itself (no other mods) ever throw a code? I did Race map 7 on 91 octane 100 degree F day on my f85 X5M and tried to get it to throw a code and it wouldn't no matter how long I went WOT over and over again. Put it though a brutal test. Had it for a year and could never get it to throw a code at all.
I re used the same hardware with the F95 maps on my 2021 X5M and while I haven't had it for long, had a 90 degree F day and ran it Map6 on 91 hard and no codes. So far so good.
Current BMWs: 2022 X5 40i, 2016 X5 50i
2015 Porsche 991 Turbo S 1979 Porsche 911 Turbo (930) a couple others IG: longboarder949; YouTube: https://www.youtube.com/channel/UCT1...eoFBszPIK0gf9w |
11-04-2022, 12:43 PM | #13 |
Rep 6
Hello, have you taken out an extended warranty on the car? If yes, then in this case you just need to contact the company with which you have concluded a contract. Otherwise, I would recommend that you take out an extended car warranty contract. For example, I have a contract with Select Auto Protect, which specializes in digital warranties, to cover costs such as general maintenance costs.
11-05-2022, 07:59 AM | #15 |
736
Rep 966
Different measurement depending on where you live. Some countries use AKI and others use RON.
87 AKI = 91 RON 91 AKI = 93 RON 93 AKI = 98 RON When folks in the US say they are running 91 or 93 octane maps, they are talking about AKI. 91 octane AKI is the highest you can buy in some US states. |
11-05-2022, 08:50 PM | #16 |
Rep 81
I drive out of my way to fuel up and have run nothing but 93 octane/AKI.
I'm out on business but could not replicate the error before I had left. I'll try again when I'm back. Thanks all for the input! |
11-06-2022, 07:11 AM | #17 |
Rep 4,532
11-07-2022, 05:29 PM | #19 |
Rep 67
11-07-2022, 05:30 PM | #20 | |
Rep 67
11-10-2022, 08:32 AM | #21 |
161
Rep 344
Drives: 2019 BMW M760li
What are the codes you get when a drivetrain malfunction occurs? I might be able to help
06-17-2023, 09:51 PM | #22 |
Rep 16
Bringing this one back, was there any update on this issue? Just curious, I have a 2019 x5 50i and I’m getting engine malfunction with the racechip gts black on settings 3 and 5 with 93 octane.
