01-26-2020, 01:08 AM | #1 |
Rep 64
Hi has anybody installed wiring for a fridge direct to the battery in an X5 2019 G05. . I just completed doing it . Seems ok . Was expecting some issues with faults but nothing. Connecting the earth was a little bit tricky, had to use body earth mount for earth wire connection.
01-27-2020, 09:31 AM | #2 | |
Rep 4,333
01-27-2020, 05:33 PM | #6 |
Rep 4,333
The purpose is to keep Popp cold. Sorry Popp, just couldn't resist a little American humor. I recall Nanatoa also put a fridge in her X5 and my brother in law has a Ford Flex that came with a mini fridge AND freezer from the factory that sits between the rear captains chairs and it works great! I can easily see the desire for a fridge when on long trips.
01-27-2020, 05:34 PM | #7 | |
Rep 810
A simpler solution may be to just replace the fuse(s) for that outlet with a higher rated fuse. I'm assuming there's a fuse (or fuses) associated with the 12V outlets in the car. For a short trip or maybe a day trip, you would get away with it. If this fridge is a permanent thing, then you will kill your battery real quick. |
02-01-2020, 07:52 PM | #8 | ||||
Rep 64
TSMC55126.50 |
02-01-2020, 07:58 PM | #9 | |
Rep 4,333
02-01-2020, 08:00 PM | #10 | |||
Rep 64
02-01-2020, 08:09 PM | #11 | ||
Rep 64
02-01-2020, 11:17 PM | #14 |
Rep 252
I ended up putting a redarc dual battery charger onto the battery. I have an Anderson plug off it which I can plug the fridge into. Alternatively I can plug in my spare AGM battery (which is in a removable battery box for camping) which charges whilst driving.
The benefit is if the main battery gets too low, the redarc cuts off the feed. It means my beer would get hot if parked for a while but at least the car will start. I am also in Australia, so I know why you are doing this but I think you are being pretty brave going direct off the main battery. Especially if you end up outback with no phone reception and no ability to start your car in the morning. Though I do concede hot beer truly sucks! |
02-03-2020, 04:02 AM | #15 |
Rep 64
02-03-2020, 04:07 AM | #16 | |
Rep 64
02-03-2020, 06:53 AM | #17 |
Rep 252
If you google redarc or dual battery systems you will get a fair few systems which attach to the main battery but only charge the 2nd battery or fridge etc when there is sufficient charge on the main. Some have an ignition wire which also monitors when the ignition is running. They range from about $300 to $1000AU installed. It will go between the battery and your current circuit. I also have them install a self reset fuse on the 2nd battery side in case the wire to the 2nd battery or fridge gets pinched etc to avoid possible fires etc.
In my view it is worth it and you can always remove it and install on the next vehicle if/when you change them over. |
Arfy22.00 |
02-04-2020, 08:59 PM | #18 | |
Rep 64
02-05-2020, 01:27 AM | #19 |
Rep 2,499
This is a great setup. As long as you run it with that diesel motor running, you shouldn't have any problems. Sounds like it can last a while on just pure battery as well. You'd probably want to install a device that detected low battery voltage and automatically shut off the fridge if you run it like that often. I'd imagine these things are made to run as efficiently as possible, but you probably don't want to be stranded to keep your beer cool.
You should always use the car chassis to ground (earth) electrical accessories. That's just standard practice. The steel (aluminum is better) chassis of the car has more than sufficient conductivity. Also, the IBS (battery sensor) measures the current through the ground. So you wouldn't want to connect directly to battery ground terminal anyway. Did you connect the +12V lead to the battery or did you find a spot on the fuse panel? |
02-08-2020, 12:38 AM | #20 | |
Rep 64
1. constantly on ( cuts out if battery level get to low) 2. Turns off when it senses no charge is going to the battery. The wire harness is also has a fuse. I didnt connect into an existing fuse box or outlet. Yes earth is direct to car body ( where car battery is also mounted to body). Obviously positive to + battery. Are you suggesting this is not a good spot????? |
02-08-2020, 01:21 AM | #21 | ||
Rep 252
02-08-2020, 01:52 AM | #22 | |||
Rep 64
