Dealing with the alphabet soup EGR/DPF/SCR
02-23-2015, 06:18 PM | #67 |
Rep 3,556
Mik325, I don't have a specific procedure to follow. I can only look at real OEM like the rest of you guys. I've poked around up in there but haven't pulled the tanks. The starting point is to remove the exhaust. There are 2 corrugated panels covering the active and passive tanks. Pull those and you will have access to the tanks. Beyond this, I don't have any specifics.
03-01-2015, 11:49 AM | #68 |
Rep 1,191
I decided to wait with pulling the SCR tank until Iaknown's free-flow exhaust is available.
But I did find some info on how to do it: |
HairyCannonball4.50 |
03-06-2015, 06:25 PM | #71 |
Rep 1,191
Still waiting on the tune as I am trying to combine a work trip to Brampton with a visit to Jarek.
In the meanwhile I decided to put everything back together, completely disabled the SCR system and take the car for a spin. While I'm now getting 15 DTCs and SES light on, the car behaves mostly normal - no difference in drivability noticed and no limp home mode after 75 miles multiple key cycles. The only strange thing is that it every now and then heats up the exhaust to 520°C for about 1 minute and then returns to normal exhaust temps around 200°C. Fuel mileage is about 32 mpg. Here's the list of DTCs (sorry for the German): |
03-23-2015, 03:49 PM | #72 | |
9
Rep 43
I want to replace my fuel filter and run the lift pump to bleed the system before starting. Is there a way to use EDIABAS to activate the lift pump? I am not interested in spending money on a BT cable when I have a EDIABAS cable order from eBay, a BT dongle, and BMWhat. |
03-27-2015, 01:12 AM | #73 | |
Rep 1,191
03-27-2015, 01:40 PM | #74 | |
9
Rep 43
BTW, I just completed the DPF delete and I printed your tread and had it with me. Fantastic and helpful post. |
03-28-2015, 09:03 AM | #75 | |
Rep 1,191
Darkswarmer3.50 |
03-28-2015, 11:40 AM | #76 |
798
Rep 1,630
Fuel pump activation is in INPA. Unfortunately, the menus seem to be different depending upon which version you have. I found it just the other day - sorry I'm not able to check it out right now. I know this only partially helps, but if you take a gander I think you will find it without too much trouble?
03-28-2015, 12:14 PM | #77 |
Rep 49
I'm in the process of taking out the DPF. Lenny did the tune for me yesterday, will report back on the progress/ impressions. For now I have a question:
What did you guys do for the exhaust gasket? The scr mixer, if that's what it's called, was acting as a gasket between the DPF and the rest of the exhaust. What are my options? Thanks in advance. Need something soon as I'm about to get the dpf out of there |
03-28-2015, 12:22 PM | #78 | |
Rep 2,408
Anyone know if the BMWhat app will do this as well?
2011 335d 11.68 @ 125.71 mph 1/4 mile NHRA certified track
Ram Cummins with lots-o-mods |
03-28-2015, 12:48 PM | #79 | |
Rep 2,615
BMWHat does not have a feature to activate lift pump. I just did a redneck method of running 9v/2a directly to it and it worked. Made a mess with a bunch of spilled fuel of course
03-28-2015, 01:19 PM | #80 | |
Rep 49
As I'm doing it there are a few nuances, regarding the DPF removal, that weren't mentioned in this thread. Could've saved some time, I'll post those once I'm done with this thing. Thanks. |
03-29-2015, 06:15 AM | #81 | |
Rep 847
http://vibrantperformance.com/catalo...8311d69eadc068 I haven't installed it yet but will be doing so shortly. |
03-29-2015, 04:35 PM | #82 | |
Rep 3,556
03-29-2015, 05:10 PM | #83 | |
Rep 1,191
Doing 9mmkungu's downpipe today, I noticed that I didn't post a detail about putting the open connectors (post DPF temp sensor, pre scr temp sensor, metering unit, NOx sensor) in small plastic bags and closing them thight with cable ties in order to prevent them from corroding. Anything else, please post! |
03-29-2015, 09:08 PM | #85 |
Rep 3,556
My two cents on the exhaust gasket. I ordered two of them as the hassle of ordering another and having to pay shipping for it didn't make sense. I figured down the road I would need to pull downpipe to do other work. It's just too cheap to not have a spare on the shelf.
03-30-2015, 07:07 AM | #86 | |
Rep 847
I stopped by rudzielec's shop on Thursday and had the ECU tuned. A few days later, I swung by Mik325tds's house and installed the down pipe. Everything worked on the first try. The exhaust note is very similar to stock; the only perceptible difference is a slight turbo whistle at low speed, noticeable if the window is down. I haven't opened it up, so it might be louder then, but I wouldn't know yet. There is a noticeable increase in exhaust smell as noted by others. It doesn't penetrate the cabin while driving, and didn't seem to enter the cabin while idling at most red lights. I suppose it's possible to smell inside the cabin if you're sitting for an extended period of time, but I didn't test it. |
03-31-2015, 09:34 AM | #87 |
Rep 529
A bit envious of 9mmkungfu - I am going to do the delete but would sure like to have some experienced hands and eyes nearby when I start taking my car apart.
I guess I will need to plan a road trip to the northern parts or I could provide an all expense paid vacation to SC for a few guys to come assist on my car. |
