01-10-2020, 03:53 PM | #771 | ||
Rep 252
From memory those option are in the 3000 subset. |
01-11-2020, 08:35 AM | #772 |
Rick James
305
Rep 784
Dumb question, but does the supported features list on the bimmercode.app site stay up to date with releases? I am still on the fence with taking the plunge, but see there's only one or two features in the non-expert mode I would use. Thanks.
01-11-2020, 11:53 AM | #773 |
Rep 647
Think it takes while to re-validate or make changes as needed. After my last update several items you could easily code aren’t available at the moment in basic/standard mode (not expert).
randybobandy304.50 |
01-13-2020, 12:32 AM | #776 |
Rep 202
Drives: 2023 BMW 760xi, 2024 BMW 530i
01-13-2020, 04:14 AM | #778 |
1202
Rep 1,587
01-13-2020, 04:23 AM | #779 |
134
Rep 326
It slows down for junctions (Y and T) and certain turns, and turns directed by the nav system when applicable in 09/2019.55 for me
01-13-2020, 04:41 AM | #780 | |
1202
Rep 1,587
Ive had some AUSY testers report changes in junction approach behaviour between 07/2019.x and 11/2019.x. Is 09/2019.55 a typo? |
01-13-2020, 06:53 AM | #781 | ||
134
Rep 326
It is post coding, US specs has no auto speedlimit anything, it's either the speed you set or it takes the speed from the signs after hitting "set" for each change. I can't wait for it to actually stop for lights and stopsigns... |
01-13-2020, 07:41 AM | #782 |
Rep 1,352
Drives: 2018 M3 CS
Any idea when the Driving Mode at Startup option (Sport/Adaptive/etc) might come to BC? I emailed them a few weeks ago and they said it was in the works, but had no timetable. Also, BDC Body module is unable to be read, so I can't access Expert Mode to make any changes myself, to this or any other component in the module.
2018 M3 CS F80 l SMB l EXEC
2020 X5 M50i G05 l MW l BLACK l PREM l DHP l 22” l PARK l EXT S-LINE l LASER l TH l AG |
01-13-2020, 07:55 AM | #783 |
Rep 276
Drives: 2019 X5 50i
01-13-2020, 08:30 AM | #784 |
134
Rep 326
Instructions are a whole laundry list of settings in an excel sheet. PM me your email address and I'll send it to you. You'll need esys or esysx
01-13-2020, 08:38 AM | #785 | |
1202
Rep 1,587
Not an exact science on these codes and not neatly packaged by BMW for retrofit so higher risk. I have the full codes for adapting the aSLA for Traffic Lights/Stop signs, but while they activate in the iDrive interface, they didn't work on 07/2019.x, I haven't had chance to test 11/2019.x but until BMW formally announce support on at least 1 production model, it's unlikely to be supported in the i-step firmware. |
01-13-2020, 08:55 AM | #786 | ||
134
Rep 326
01-13-2020, 10:59 AM | #787 | |
Rep 202
01-13-2020, 12:03 PM | #788 | |
Rep 71
Hi ifr, I am on 11/2019.40 and yes it does slows down on junctions/cross roads. Please can you kindly share the codes for aSLA for Traffic Lights/Stop signs I want to try on 11/2019. Thank You |
01-13-2020, 12:20 PM | #789 |
Rep 143
I’ve been seeing some video post on FB about “Comfort Plus” on a G05. Is this available for bimmercode? If so, which option to enable? Thanks!
https://m.youtube.com/watch?t=58s&v=rgP6ELhzt5s#menu Last edited by twinturbomann; 01-13-2020 at 12:23 PM.. Reason: Add link |
01-13-2020, 12:25 PM | #790 | ||
1202
Rep 1,587
I don't share/publish codes unless I know they 1) work and 2) are control tested |
01-13-2020, 12:31 PM | #791 | |
1202
Rep 1,587
The consensus was we couldn't tell the difference between comfort and comfort plus. I certainly couldn't |
twinturbomann93.50 |
01-13-2020, 12:35 PM | #792 | ||
Rep 143
